Hi Guys.
Received an ARP front crank bolt #251-2501 from Burtons with no instructions. Does anyone have a copy of or know the official ARP fitting instructions for this bolt? I have emailed ARP but am still awaiting their repying, so thought one of you guys might be able to help in the meantime and let me get cracking with my install.
Torque setting:
Google led me to Biggles' page that suggests 112 ft/lbs with ARP lube
http://www.docstoc.com/docs/88610949...s---Bigglesnet
This advice from Kent Cams says 145 ft/lbs with ARP lube and 185 ft/lbs with engine oil (I pressume)
http://rsmotorsport.com.au/forums/vi...2489&start=300
Which is correct?
Torque setting aside, I assume the ARP lube is applied to both the thread and under the bolt head? Are there other more commonly available lube options that can be used instead of the ARP lube or would a threadlocker like a loctite still be suitable? It's a bit of a struggle to find ARP products stocked locally here in sleepy old Perth Aus! If it makes any differerence I wont be using the washer either as I'm running a small dry sump pump pulley under the crank bolt which won't fit the washer.
BTW I wish Ford (mazda) used a keyway in their cranks!
Cheers guys!
