I have a Iveco Dailey 1993/4 on a L reg which im needing to sell to raise cash for another van for work, may P/x deal on a small to medium van as my clutch / gearbox has crapped itself on my T4 !!!
The truck is all ready for a mot after having new rear shocks, brake cylinder and some part worn tyres fitted, it's currently plated at 4.5T the only reason i havent mot'd it was because i've been told i need a operaters licence or downrate to 3.5t for what i wanted to use it for ?
I have a normal speedo to replce the tacho if this was done.
I have a Pdf file that explains that it onlt needs 2x 15mm spacers under the bump stops to do this and a visual inspection from Vosa to confirm, then they will plate it at 3.5T.
This was originally a Box removal van and had been well looked after, cab & seats need a clean but not damaged, i bought it as a unfinished recovery truck conversion with a nice alloy bed to go on it, a mate finished it off for me so it's all complete & working with a brand new winch & some rather heavy ramps, which i was going to replace with alloy ones.
All the rear was painted before the body was fitted it's very good & strong as is the cab with just a small scab on the door but bonnet was jet washed which peeled the paint off.
Located in South Oxfordshire 07770978154 please only ring between 8:30 am & 9pm as i have younger kids
I'll let the pics tell the rest i'm looking to get my money back £1500 as it stands or a deal on a van i have some cash if needed, it will start & drive fine (smokes a little from cold) no MOT or TAX.
When my mate was building it:
Good interior but needs a clean
Current weight cert.
