Results 1 to 33 of 33
Thread: 2l duratec
    Oct 2011
    uk
    168
    20
    2l duratec
    2l duratec, unknown from a mondeo
    home made exhaust, omex 600 and jenveys
    happy chappy
    just need brakes now
    Attached Thumbnails Attached Thumbnails duratec2.jpg‎
    Dec 2007
    Dubai
    1,678
    29
    Re: 2l duratec
    Very nice, pop a Raceline spec Caterham R400 cam into that with a set of valve springs and it should go nicely to around 210
    www.gulfpetrolheads.com
    Nov 2003
    Wirral UK
    6,740
    257
    Re: 2l duratec
    Impressive power from a bone stock engine! Nice torque curve too!
    http://escort.accelerator.org
    Oct 2011
    uk
    168
    20
    Re: 2l duratec
    drives very well
    bit worried about the blue smoke trail i leave,,,,
    if i can scrape it thru the mot i will run it to destruction
    and keep an eye out for another lump
    Nov 2013
    Germany
    Re: 2l duratec
    I also have the Omex 600 but don't installed it till now.
    The Engine is standard with Cosworth Roller Barrel (fitted in a Lotus Elise S1)
    Maybe you can help me with mapping the ECU. Should be almost the same as yours.
    I got a startup calibration from Omex but I am not sure because the fuel mapping.
    Do you use the standard injectors?
    I am from Germany - maybe my English is not good enough to understand what the programm want me to do
    thanks in advance
    Regards
    Fabs
    Dec 2007
    Dubai
    1,678
    29
    Re: 2l duratec
    I would contact Omex, they will have a base map. The most important thing is not the state of tune, but your fuel pressure and injector size, the ratio between these two will need to match that of your base map for it to run at all well
    Nov 2013
    Germany
    Re: 2l duratec
    do yo work with omex ?
    I got the base map - calibrated coolant and air temperature sensor, throttle position sensor
    So far so good
    But now I don't know how to do the basic fuel and ignition setup.
    And what about battery voltage compensation - do I need this and how does it work?
    Dec 2007
    Dubai
    1,678
    29
    Re: 2l duratec
    never looked at an Omex, Emerald is my weapon of choice
    3,241
    Re: 2l duratec
    Was the ECU delivered from Omex to suit the install? - most manufacturers have a list of applicable maps to install if they know what is to be used, certainly enough to start and run until it can be dyno'd. Battery compensation is required - it works by increasing the injector pulse width with declining voltage to ensure the correct fueling is maintained
    Nov 2013
    Germany
    Re: 2l duratec
    @ anguz
    can you send me your calibration - maybe I works
    Otherwise I have some values to compare
    would be nice
    Nov 2013
    Germany
    Re: 2l duratec
    sorry
    Nov 2013
    Germany
    Re: 2l duratec
    but
    Nov 2013
    Germany
    Re: 2l duratec
    I need
    Nov 2013
    Germany
    Re: 2l duratec
    Nov 2013
    Germany
    Re: 2l duratec
    to
    Nov 2013
    Germany
    Re: 2l duratec
    send a
    Nov 2013
    Germany
    Re: 2l duratec
    private
    Nov 2013
    Germany
    Re: 2l duratec
    message
  19. #19
    Nov 2013
    Germany
    Re: 2l duratec
    and I
  20. #20
    Nov 2013
    Germany
    Re: 2l duratec
    found
  21. #21
    Nov 2013
    Germany
    Re: 2l duratec
    no
  22. #22
    Nov 2013
    Germany
    Re: 2l duratec
    other
  23. #23
    Nov 2013
    Germany
    Re: 2l duratec
    way
  24. #24
    Nov 2013
    Germany
    Re: 2l duratec
    so
  25. #25
    Nov 2013
    Germany
    Re: 2l duratec
    I
  26. #26
    Nov 2013
    Germany
    Re: 2l duratec
    had
  27. #27
    Nov 2013
    Germany
    Re: 2l duratec
    to
  28. #28
    Nov 2013
    Germany
    Re: 2l duratec
    act
  29. #29
    Nov 2013
    Germany
    Re: 2l duratec
    like
  30. #30
    Nov 2013
    Germany
    Re: 2l duratec
    this
  31. #31
    Nov 2013
    Germany
    Re: 2l duratec
    sorry
  32. #32
    Nov 2013
    Germany
    Re: 2l duratec
  33. #33
    Mar 2007
    Hartwell
    166
    Re: 2l duratec
  34. The Following User Says Thank You to packman For This Useful Post:
