Results 1 to 12 of 12
Thread: anyone straightened warped fiberglass panels?
    Jan 2009
    London
    219
    Got a car with widearch fb panels but are warped - anyone ever straightened them??
    Been warped i'd say for 17 years or so - panels are pop riveted to shell and are painted. .
    Some research shows heating them and setting in a jig might work but any first hand exp will be great.
    Have pics if it helps
    Feb 2011
    newbury
    64
    117
    17
    Re: anyone straightened warped fiberglass panels?
    As a composite material, you will probably struggle to get them straight again but you have little to lose by tipping a kettle of boiling on them and supporting as they cool in the right position eh.
    Nick
  3. The Following User Says Thank You to norsa For This Useful Post:
    Jan 2009
    London
    219
    excellent thanks a lot for the reply. had a few ideas like filling and shaping it to the correct shape (will be more than an inch of filler) then using this as a mould for making a cast - to make a new panel. . .
  5. The Following User Says Thank You to contax For This Useful Post:
  6. #4
    Nov 2003
    Wirral UK
    6,740
    257
    Might also work if you leave them in a low bake oven (spray shop) for an hour or so, then take them out and prop them in their desired shape to cool.
    http://escort.accelerator.org
  7. #5
    Jan 2009
    London
    219
    thats a good idea will defo try it. thanks a lot for the replies.
  8. #6
    Spanner Monkey longlegs's Avatar
    Jun 2010
    Herne bay Kent
    270
    What about getting some 1/4 inch flat bar pop riveted across the front of the panel bend the bar first to pull panel to the shape then fiberglass matting to the rear to strengthen the panel and keep the new shape .
    Then when the fiberglass has totally cured for a few days drill out pop rivets and remove bar.
  9. The Following User Says Thank You to longlegs For This Useful Post:
  10. #7
    Jun 2010
    New Zealand
    33
    i had a set of guards that were concaved and all i did to get them close to a fair line was pull them straight with a batten on the outside of the panel and lay more glass on the inside to give it the rigidness to hold the shape then i just did any minimal filling to get it perfect. panels are still fair and they've been on the car for 4 years or so.
  11. The Following User Says Thank You to 81esky For This Useful Post:
  12. #8
    Jan 2009
    London
    219
    that sound great. thanks a lot mate - have you got any more info or fotos?
    can post up my panels and see if u think this method will wirk on mine?
    cheers
  13. #9
    Jun 2010
    New Zealand
    33
    ive only got photos of them painted in undercoat sorry, but post some photos up anyway ill have a look. Cheers
  14. #10
    Jan 2017
    Romania
    36
    Hey Contax! Did you straighten them yourself or was anyone here able to help?
    ______________________________
    Dumitru
    Revetementagro panels
  15. #11
    Nov 2008
    Bored
    1,380
    Quote Originally Posted by Dumitru Ivanov View Post
    Dumitru
    Last Activity:14-06-2016 15:47.
  16. The Following User Says Thank You to Sweetcorne For This Useful Post:
  17. #12
    3,641
    Bear in mine that fibreglass composites are thermosetting, they will most probably crack with any heat application and flex
