Results 1 to 13 of 13
Thread: Afr gauge
    Oct 2018
    Midlands
    291
    Afr gauge
    Hi after some advice on fitting afr gauge and lamda sensor kit iv seen some on ebay around £170. Its for my mexico mk2 is it just matter of driling hole in exhaust weld nut on to fit lamda? Also wheres best place to fit? Just after join from manifold to exhaust? Thanks for any advice/help
    Pole Position Decade Plus User M11rf's Avatar
    Apr 2004
    Bangkok, Thailand, Thailand
    4,346
    479
    Re: Afr gauge
    If it's N/A you can fit it after the manifold anywhere. If it's turbo they suggest you fit it down the pipe a little, to stop the sensor getting too hot.
    You can get a nut and weld it in or you can buy the round collar, which looks nicer when welded in.
    Apr 2013
    S Wales
    233
    432
    Re: Afr gauge
    This is where I put mine on my Pinto.
    It only reads 2 cylinders in this position, but this is making the assumption that the carbs are all set up equally, which they are.
    Click image for larger version Name:	IMG-20180319-WA0025~01~01.jpg Views:	83 Size:	141.7 KB ID:	83587
    Oct 2018
    Midlands
    291
    Re: Afr gauge
    Cheers guys.its n/a so anywhere on exhaust is ok? I ask as if its by gearbox i can run wires through gearstick hole and under consol
    4,889
    Re: Afr gauge
    Mount it in the manifold an inch or so after all pipes come together into one.
    If you have a heated lambda sensor it will read the mixture soon after startup. If you have an unheated sensor (1 or 2 wires) then it can take some time to heat up and read mixture especially if it is in one of the two downpipes an just gets the "heat" of 2 instead of 4 cylinders.
    3,239
    Re: Afr gauge
    Quote Originally Posted by Miniliteman View Post
    One thing from that - any sensor with less than 5 wires will be a narrow band type and as such can only indicate the gases are or are not stoichiometric ie. 14.7:1 - not a sensor to use for tuning.
    4,889
    Re: Afr gauge
    Indeed, but a normal sensor is good enough to "keep an eye on the mixture" .
    3,239
    Re: Afr gauge
    Not really - it'll just reliably tell you you are running rich / fat but with no numbers - NB guages are usually a series of coloured LEDs - Red Amber and Green then Amber again with green being the 'ideal'. If its important to you to know - get a wideband that will provide useful info and a number!
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    502
    Re: Afr gauge
    Probably an obvious answer due to ground clearance issues but don't mount it below 10degrees from a horizontal plane. This is due to condensation contamination on start up.
    Oct 2018
    Midlands
    291
    Re: Afr gauge
    Thanks for all the info guys. Not going to use it as tuning aid just to keep an eye on the webers etc
    Oct 2018
    Midlands
    291
    Re: Afr gauge
    Also looking to fit vacuum gauge can i put t piece in brake servo hose or is that a no no.cheers
    4,889
    Re: Afr gauge
    That's just what I meant with keeping an eye on the mixture.
    Re: Afr gauge
    Dont fit it too close to the collector on the manifold, you want it far enough downstream in the single pipe section so it will measure the average AFR of all 4 cylinders, defo dont fit it anywhere in the manifold as stated above otherwise you will be measuring AFR from from not all of the cylinders, also mount it above 3 or 9 oclock otherwise the sensor gets wet and gives false over rich readings, Innovate wideband ones work well, ive had one fitted for years.
