Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 241 to 280 of 291
Thread: Road Rally MK2 4 Door (XE powered)
  1. #241
    Spanner Monkey lukem30's Avatar
    Jul 2012
    Uk
    35
    408
    78
    Yes fella, seems to work well.
  2. #242
    Spanner Monkey redhf's Avatar
    Jan 2006
    uk derbyshire
    58
    479
    164
    Yes looks well.
  3. #243
    Jul 2012
    Uk
    35
    408
    78
    Repairs have started
  4. #244
    Jul 2010
    South Wales
    4,689
    221
    Quote Originally Posted by lukem30 View Post
    I was waiting for the update. She's looking good and You'll be a pro at wing changing soon.
    Did the wing offer up straight away?
  5. #245
    Jul 2012
    Uk
    35
    408
    78
    Already had a chat about the above in work John.
    Couple more good pics from pembrey
  6. #246
    Jul 2012
    Uk
    35
    408
    78
    She's painted, and entry has gone in for another rally down Pembrey - rally cwm gwendreath.
    I replaced a leaky core plug and found a big air leak on the inlet manifold so I had to replace the gasket. It's running spot on now, can't wait to get out and give it a run.
    On the modification front I decided to fit some new 300 70 long Tarmac inserts. Reason being, I could never identify what rating my inserts were as they weren't stamped with numbers, and at the last rally my understeer reared its head again, the inserts were the only Unknown.
    When I tried to fit the new inserts into the m10 threaded hole at the bottom of the leg I couldn't get it to line up, upon closer inspection I found that the tube of the leg was bent so I had to replace that too. I found it odd that the bent tube was on the passenger side (which I didn't hit down pembrey) so who knows how long it has been bent. I also suspect that the insert was jamming in the leg due to the bend and could be the cause of my understeer. I'm waiting on a new spring seat so I can go out and try it.
  7. #247
    Jul 2012
    Uk
    35
    408
    78
    Last thing was to swap the castle nuts on the steering arms for nylocs, as the split pins had siezed when i needed to change the steering arm quickly at the last rally.
  8. #248
    Jun 2012
    ireland
    1,158
    where did you get the new tubes? they look like a nice job! did you just cut the old one off at the hub and but weld the new one on? will it be strong enough?
  9. #249
    Jul 2012
    Uk
    35
    408
    78
    I got the tube from Peter Lloyd rallying, but I am told they get them in from rally design. They come with the bushes and seals already fitted which was handy.
    I ground the welds off the original tube, then cut it shorter and smashed it out of the hub with a drift, tapped the new one in and welded either side of the hub. Should be strong enough as the original was only welded on the one side.
  10. #250
    Jun 2012
    ireland
    1,158
    ah cool thats what i was wondering, nice job!
  11. #251
    Jul 2012
    Uk
    35
    408
    78
    We had another eventful day at Rali Cwm Gwendrath on Sunday. It was wet, miserable and cold, to be expected for February in Wales I suppose. We were seeded at car 40 and looking forward to a challenging day.
    Stage 1 - Stage 1 didn't go well at all. We got stuck in some traffic very early on, not long after our intercom failed, and just after that we went off the road and got stuck in the grass. After a top job by the very few people standing there we got the car back out just in time to take a stage maximum, and we were OK to continue the rally.
    Stage 2 - after our problems on stage one we really backed off a lot to get round as the stage was very slippy. We took no risks and got round with no dramas, which was nice.
    Stage 3 - it was drying out slightly by now so we started to build the pace back up, all went well and the car felt a lot better in the drier conditions.
    Stage 4 - we started off well and came out immediately in traffic, but pretty soon into the stage the gearbox gave up and we lost 3rd/4th gear, and we could only get second with a big struggle. So with only 1st and 5th gear we retired.
  12. #252
    Jul 2012
    Uk
    35
    408
    78
    Meaning as the box broke it gave me an excuse to try this
    Which I expect will keep me busy for a while.
  13. #253
    Jul 2012
    Uk
    35
    408
    78
    Phase 1
    Plate has been test fitted and holes marked up
    Rather than make a spigot extender I've taken the bell housing off the gearbox and sent it off for machining. 15.5mm to be removed from the the bellhousing flange and dowel holes re drilled.
  14. #254
    9,204
    does the xe require a longer input shaft compared to pinto etc ?
  15. #255
    Jul 2012
    Uk
    35
    408
    78
    Yes, it needs to be extended by over 20mm
  16. #256
    Jul 2012
    Uk
    35
    408
    78
    Bell housing is back from machining and trial fitted on my spare engine first for fitment, after a few little mods for starter motor clearance it fitted up nicely. I also made a few minor adjustments to the plate, these have been passed on to John to get the plates 100% perfect.
    Next it was offered up to the engine to see how it fitted in the tunnel
  17. #257
    Oct 2015
    Essex
    347
    33
    How did it fit looks tight
  18. #258
    Jul 2012
    Uk
    35
    408
    78
    Quote Originally Posted by Ianbavs View Post
    It went in fairly easy to be honest, I think the camera angle makes it look a lot tighter than it is, plus the box was jacked right up so it touched the top of the tunnel in the pics.
  19. #259
    Jul 2012
    Uk
    35
    408
    78
    It lines up nice in the gearstick hole too
  20. #260
    Oct 2008
    whitley bay
    2,436
    89
    Have you tried it yet
    How does it feel?
    You had a look at your 5 speed to see what's up with it?
    Hexham and District Motorclub
  21. #261
    Jul 2012
    Uk
    35
    408
    78
    How does it feel?
    Not yet mate, still got to modify my pedal box to accept hydraulic clutch and get a prop made up. My tran x has gone off to the gearbox builders for repair and full rebuild, I haven't got time to do it myself this time.
  22. #262
    Jul 2012
    Uk
    35
    408
    78
    The box is now fully mounted.
    Rear mount I made up
    Fitment through the gearbox hole is excellent
  23. #263
    Oct 2008
    whitley bay
    2,436
    89
    Looks good
  24. The Following User Says Thank You to mexicotait For This Useful Post:
  25. #264
    Jul 2012
    Uk
    35
    408
    78
    Made a start converting the pedal box to accept hydraulic clutch today
  26. #265
    Jun 2012
    ireland
    1,158
    loooking good luke! im watching this with real interest and on the lookout for a cheap box - i think il do this in the summer and sell on my long first t9 for double the cost of this conversion!
    im interested to see first how the ratios will suit the XE, what diff ratio are you running luke?
  27. #266
    Jun 2012
    ireland
    1,158
    p.s are you running a large tunnel?
  28. #267
    Jul 2012
    Uk
    35
    408
    78
    The ratios are very good if you ignore 1st gear, 2nd to 6th has almost identical ratios to my tran x type 9, that's what made me go for it.
    I'm on a 4.6cwp and a large grp4 tunnel. My only concern is strength, but freddy68 has tested his and its stood up to the punishment well.
  29. #268
    Jul 2012
    Uk
    35
    408
    78
    Pedal box conversion is done and ready to refit after a quick coat of paint
  30. #269
    Jul 2010
    South Wales
    4,689
    221
    Fairplay that pedal box is pukka! Won't be long and you'll be up and running, you'll never look back then.
  31. The Following User Says Thank You to freddy686868 For This Useful Post:
  32. #270
    Jul 2012
    Uk
    35
    408
    78
    I hope so after all this effort
  33. #271
    Jun 2012
    ireland
    1,158
    really looking forward to seeing how this pans out, im running a 4.1, im thinking the 2nd might be too long for that, what are the ratios do you know?
    lovely job on the pedal box
  34. The Following User Says Thank You to onecamohv For This Useful Post:
  35. #272
    Jul 2012
    Uk
    35
    408
    78
    I'm looking forward to trying it. The 6 speed rx8 ratios are - 3.76, 2.269, 1.645, 1.187, 1.00 .843.
    John ran a 3.89cwp at first with his rx8 box and found it too long for stage rallying, he has since changed to a 4.6 and find it brill now. Take a look out onboards to see the difference in the cwp's. Something to think about.
  36. #273
    Jul 2012
    Uk
    35
    408
    78
    Another step closer, pedal box is in and hydraulic clutch pipped up.
    Last thing to sort now is the propshaft, it's 45" from my atlas to the gearbox which I belive is about an inch to short to use the rx8 Carbon prop. I'm waiting on some measurements from John to confirm. Looks like I'm going to have to get my original prop shortened.
  37. #274
    Jun 2012
    ireland
    1,158
    why dont you use an alloy machined spacer between the prop and the diff? seen it loads of times on rally cars to get as much prop in the box as possible if the engine location is not ideal
  38. #275
    Jul 2010
    South Wales
    4,689
    221
    the carbon rx8 prop is too long in the first place or i would have done this :/
  39. #276
    Jul 2010
    South Wales
    4,689
    221
    i was running a 3.75 too luke so even longer again .
  40. #277
    Jun 2012
    ireland
    1,158
    Ah sorry I thought the prop was too short not the distance for it! How do you think the 4.1 would be John?
  41. #278
    Jul 2012
    Uk
    35
    408
    78
    Had the prop back from bar propshafts in neath, shortened with an rx8 end fitted, very speedy service at a good price.
    A little bit of tinkering left, then to fill the box with fresh oil and give it a go.
  42. #279
    Jul 2010
    South Wales
    4,689
    221
    I'm not sure really i haven't had any experience with the x flow engine. I think a 4.1 behind lukes xe would be perfect though. But sometimes you just have to suck it andsee
  43. #280
    Mechanic azz259's Avatar
    Aug 2009
    west wales
    487
    10
    How much was it to modify the prop luke? I need mine shortened and a type 9 end fitted on , do you have a type 9 end going spare now ?
