Results 1 to 12 of 12
Thread: dont understand
    Mar 2012
    mansfield
    129
    dont understand
    hi all just after some pointers.
    just in the process of fitting a type 9 box, ive seen it working in a car i bought it from but as stood for a while. anyway i took the top panel off looked fine, i could select gears before i fitted to engine (pinto). but now its in, it will only go into 1st, ive got the clutch cable all hooked up but still makes no difference(being honest though the clutch pedal doesnt quite feel rite). have i made a mistake fitting it, i tought it can only go in 1 way? bit lost any ideas would be fantastic thanks.
    Nov 2003
    Wirral UK
    7,322
    259
    Re: dont understand
    Have you put the top plate back on correctly? If you shifted gears with it off you might have not located part of the shifter mechanism properly.
    http://escort.accelerator.org
    Mar 2012
    mansfield
    129
    Re: dont understand
    Yes i put the top back on whilst the lever was still attatched and was fine. I then removed lever to fit the box and then refitted lever and then cant get gears. Weard. Could it be the clutch stopping me now its all bolted up because it was ok when it was seperate from the engine? Also should i be able to move the clutch fork by hand as it feels solid to me.
    Spanner Monkey a.south1234's Avatar
    Nov 2011
    Maldon, Essex
    27
    244
    16
    Re: dont understand
    could it be that when you put gearstick back in it might not of been put in correctly and the fork of the gearstick isnt in the shifter bit properally, i think i did this to mine
    Sep 2006
    chesterfield derbyshire
    2,164
    Re: dont understand
    did you put the clutch friction plate on the right way round?
    Mar 2012
    mansfield
    129
    Re: dont understand
    I thought so. But the more i think the more im un sure. Either way the box as to come off and have a closer look. I might get a new clutch kit to fit also while im at it. After time without use can clutches stop working?? ecause nowing my luck it wouldnt last long.
    Another job then the list gets bigger, hoped for a easy fix.
    west kingsdown kent
    32
    4,250
    Re: dont understand
    it is possible to put the gear lever in the wrong way round but i think it only prevents you selecting reverse.worth a check though
    tommy 2000
    Mar 2012
    mansfield
    129
    Re: dont understand
    Ive taken it back off a couple of times. I think it must be rite because the levers pointing backwards as it should. I will get box off and if i can get gears then its got to be the clutch hasnt it.
    Cant think what else except clutch it could be thanks all.
    Sep 2011
    kent
    143
    Re: dont understand
    try slackening the bellhousing bolts so box can be eased back see if that makes a difference if so something wrong in clutch area
    (engine not running of coarse)
    Mechanic mrjimbo's Avatar
    Oct 2004
    Oxon, England
    787
    11
    Re: dont understand
    Is the little black plastic clip under the gear stick ok/in the right place ?
    Mar 2012
    mansfield
    129
    Re: dont understand
    I had a good look at the plastic bit today. Hard to say if its ok or not as anyone got a picture of what it should look like. It did rotate so a flat bit was faceing up rather than a curved bit? Tried both it felt better when the cutved bit faced up with another part on the left. Sorry abit vague here on descriptions..
    I'll try and slacken the bolts off abit over weekend, could the oil have degraded and would that stop me getting gears.
    Thanks again for all suggestions
    Dec 2006
    Herefordshire
    29
    Re: dont understand
    Can it be the top plate on the wrong way around ? seem to remember something about it but not sure.
