Results 1 to 12 of 12
Thread: hi has any1 stuck a civic ep3 rwd ergent
    Jun 2012
    bridgend
    21
    i bought a civic type r ep3 engine 5 months back ready for a mk2 thinking it was the same as a s2000 but looking through her and it says it isnt is there any way 2 convert it rwd in my mk2 if any1 can help it will be appriciated thanks dan
    Nov 2009
    essex
    7,020
    355
    Re: hi has any1 stuck a civic ep3 rwd ergent
    its been done, engine spins the wrong way round hence why its not used, but some cleaver irish blokes managed to get it running spinning the other way round.
    Mar 2009
    scunthorpe
    78
    67
    The Honda K20a2 engine fitted to the Honda civic type r (EP3) turns clockwise the correct way for rwd. You may have problems with bell housing/adapter plates, i would check with dmrr( see link below)
    http://www.dmrr.net/
    ncoll
    Norwich
    500
    17
    Surely they all run clockwise, I know the engine and box is in backwards but I sure they don't run backwards
    Nov 2009
    essex
    7,020
    355
    Mar 2009
    scunthorpe
    78
    67
    The link above makes reference to a b series 1600 engine pre 2001, and yes they do turn anticlockwise, hence the gearbox at the drivers side. In 2001 the k series engine was introduced and it turns clockwise. I have a 2003 honda civic type R (ep3) with a K20 a2 engine, and I can assure you it turns clockwise, hence the gearbox at the passenger side.
    ncoll
    Nov 2009
    essex
    7,020
    355
    i thought the only one that tuned clockwise was the s2000 lump, all other's B series or K series turned anti clockwise
    i'm gonna do some googleing.
    Nov 2009
    essex
    7,020
    355
    found on honda tech
    if i remember correctly , B,D,H spin counter clockwise and the K and V6 spin clockwise when viewed from the front of the engine (pulley side).
    Jul 2010
    South Wales
    32
    4,840
    222
    The K series in the EP3 and EP4 civic spin the right way the same as the F series in the s2000. If you look at the ep3 and 4 engine bays the engine is on the 'right side' so the engine spins the 'right' way. If you look the b series the engine is on the 'wrong side'.
    Mar 2009
    scunthorpe
    78
    67
    hi gretto123
    If you look on the link below, especially posts 13 and 30, it maybe of help when you come to put your K20a2 into your escort.
    http://www.k20a.org/forum/showthread.php?t=53638
    ncoll
    Bodger evobda2's Avatar
    Sydney, Australia
    180
    Theres a few forums that have done it.. google is your friend here..
    This example being a K24 into a s2000...
    http://www.k20a.org/forum/showthread.php?t=101190
    Jun 2012
    bridgend
    21
    Wink Re: hi has any1 stuck a civic ep3 rwd ergent
    Thanks everyone for your help I'll do more research and if no luck run something else lol
