A load of boxes turned up today so let the work begin we'll after the Malcolm Wilson Rally anyway
Another load f panels turned up for the weekend so I now have all the panels to do most of the car a few bits to get from Group 4 Fabrications
Where are the pictures!
Right repaired the hinge panel under the wing another job ticked off the vast list lol
Great welding
Another job finished, splash panel fitted, ready for the front floor section
And the rest Paul did with the 1980's spot welder. My wife's spot welder as well!!
It may be a 1980 and Robs wife's but it it works very well not quite sure it would meet today's safety standards !
good progress there now
DSRESTOS
Near side splash panel finished and primed
Good to see you are progressing. Looks like you are doing a great job!
well boys you are draging your arses like dog with worms!!!!
he's getting there
An update inner wing strut tower fitted and strengthening top plate and seam welded nearly ready to fit them to the car !
Not sure on the colour.
Still haven"t got a clue what colour to paint the old girl ?
Well that's nearly another strut tower fitted to the inner wing just a bit of seam welding to do a get them fitted
Another good night in the workshop both inner wings now fitted trial fit of the front wings, slam panel and front panel with a little bit of bashing should be a good fit
looking good boys!!!
Just got in from the workshop 02.30 !!!! Up at 6 no problem anyway started on the floors and inner sills and having to do running repairs on one of the 4 angle grinders we have on the go just debating where to do the join for the new floor to the new sill ?
Pics to follow later
Got the driver side floor in just a few bits to finish it off then start on the inner sill then start the other side then cut the tunnels out for the new ones
Drivers side inner sill done now to start on the other side
Looking good!!
Some lovely work there
Your doing a great job and really enjoying this build
The passengers floor is nearly done should finish it tonight
Passengers side now in front bulkhead in front of the floors to do why oh why don't the make the front floor sections longer everyone knows the always rot in front of the floor section !!!
Shaped bulkhead gussets done both sides
Near side floor in
Bulkhead to shaped to get the block back a bit more just have to fit the strengthening plate once the new gearbox tunnel goes in
Heater bowl repair done just some grinding to finish off
Shaped gussets in just some grinding to do to finish them off
All in all a good night in the workshop "Cheers Rob"
The latest shopping list from Group 4 Fabrications
1 x Gearbox Tunnel (60G type)
1 x Centre tunnel
1 x Diff tunnel(chamfered)
1 x Rear Turrets 15"(Round/Pair)
1 x 15" Rear Tubs(pair)
1 x Alloy rear lamp protectors.BLACK ANODISED
1 x Watts linkage riased boot floor box
1 x Watts towers (RH exhaust)
4 x Radiator Gusset
1 x Spring Hangar Skid
2 x 4 link box (reinforced)
1 x Gearbox alloy plate
Eek that hurt the wallet !
Well with the arrival of the tunnels soon I thought I would attack the old one with the cutter
Lots of little bits done tonight like the old holes on the front floor pan which go into the chassis rail plates made and welded on lots of other holes welded and ground back so were getting there slowly
Your making some great progress!
Bet you can't wait for the new bits to arrive...
One draw back of getting all the new shiny bits is that the have get attached to the car somehow LOL
But we're getting there slowly
Making some good progress there! Keep it up
Tonight we filled a load more old pipe holes and filled the holes in the rear quarters where the old X-Pack wings used to be riveted plus some of the old holes on the rear panel, looks a lot better with the holes filled !
Also picked up the bonnet from X-Sport in Basingstoke "thanks John"
Tadaa
At least some Irish Motorsport suppliers come up with the goods !!
Looks like we could be busy in the workshop
Exhaust tunnel ordered picking it up from the plains rally
has that carbon panel arrived yet?????
