did you have a look at this shop as well? great quality parts and i think he is a little cheaper than torques too
https://www.facebook.com/kiwimotorsp...?tab=page_info
No but we use Torques as we know a man who knows a man if you get my drift and he doesn't list AN12 stuff
Are you going to mount the fuel regulator on the inner wing Paul, as i have heard of them snapping off on the fuel rail when fixed directly. You might already know this mind you!
Yep it's going on the inner wing or bulkhead
you could be even cleverer and put it in the boot and only run 1 fuel line through the car and put the msa fuel take off on the end of the rail as a way to bleed all the air out on first start up? cuts down on weight and cost of extra fuel lines
is that the oil lines??? looks quite small???
Geordie.....you can't do that as there needs to be a feed back to the tank for excess fuel as the pump just flows at a set rate.
AN-12 oil lines 3 Runs front to back "eek". The two runs of AN-8 Teflon with no bulkhead conectors as they restrict flow, I have a great idea for that issue :-) ay Rob :-)
ahh but if you put the regulator at the back with the pump the 1 line to the front will have regulated pressure in it! one of mine is done like that!
it cuts down the need of 2 fuel line runs the extra weight of fuel in the system its not like a dry sump system it doesn't need to return anything if the pressure is being controlled elsewhere the sump does need to return the fuel will be used eventually so less heated fuel as when the fuel is pushed through the lines through the hot fuel rail it goes back to the tank and vapourises as it is warm/hot
Drivers side seat brace in now
World cup crossmember towers now removed and capped as gone chassis mount
And we have modded my gearbox tunnel cock up after I was originally going to put a 5 speed Tran-x SL72 dog box in the car then changing my mind after the tunnel was fitted to go with a Tractive Gearbox which was too tight on the rear of the box for the gear change mechanism now we have a far bit of room now with the extended side and this is still a slightly not so in your face than the ugly Tractive tunnel
Next job start fitting the oil lines in
I'm using a group 4 fabrication fuel pump bracket and filter kit with an internal swirl pot in a Squires supplied fuel tank running two lines of AN-8 to feed the fuel regulator then onto the front of the fuel rail and the other is the return from the fuel rail to the tank which will feed into the swirl pot so that tops it up as well
cheers i get it now.
looking good! what are the dimensions of that fuel tank???
Top work, can't wait to hear her scream !!
It won't be the car screaming it will be me screaming as I'm running out of talent lol
Cool buildlove the engine
4 doors for the lanes........and shopping
Hux,
Can you give me the dimensions of your rear tubs (diameter, depth etc) as I want to make a set but am struggling to find any info on sizes.
Sorry I forgot when I'm up next Ill get them for you if you haven't got them already was up there tonight but forgot "it's an age thing LOL"
Thanks hux. I don't have them yet!!
Paul
Its looking like a car again now mate well done
Thanks Andy getting there slowly just wish I had 3.5k for a paddle shift system
I wish lol still a fair bit of expenditure to go yet
Have a read of this Paul.... http://www.bmw-rallying.co.uk/viewto...2379&start=945 I'm sure a man of your caliber can knock one (two ;-) of these up? and i will make a carbon paddle??!!
Hmmm now that's got me looking on RS lol
Lol but need to sell my New DTA S60 pro then
Be worth it though!
what was them new isolators you showed me ???
Here you go http://www.farnell.com/datasheets/1719942.pdf
the spec sheet doesnt say how it is opperated?? i.e are the coils powered to hold it in? and you de-energise it to shut down or is it 1 press on and another press off?
1 press on 1 press off
12+ Coul links to the battery feed and the 0 v goes to the switch
Nice project
