God that's cool, does it weigh much ? Does it run continuously or only after the reservoir begins to discharge at a specific amount ?
Well chuffed with it bit on the weighty side but it's solid as it's rated as 100% duty cycle, 200psi max I'm going to get a 1ltr bottle for it and a pressure switch which will be about around 120psi to be confirmed, the weight isn't much of an issue as I would rather have long term reliability than some cheap thing that won't last no time at all, believe me it is built like a brick sh1thouse one guy on the DTA forum is running one of these already so it's his fault lol
looking good
Well we have been busy on the old girl lots shopping done latest bit done we set up the tractive gearbox lever but it was a lot of work, but done just need to get the stainless rods machined on the final fit up and get the block for the tower drilled to take out some metal
And a nice small lightweifgt compressor for the boot NOT !!!
Is it worth changing the compressor For a lighter one?
Naa I can't be bothered it may a bit big but it will never be overloaded or wear out and I haven't got the box anymore
slow but progress is made!
So we have sort of finished the lever for the Tractive just need to machine the proper rod for the lever when it's finished video clip of the lever in action
http://smg.photobucket.com/user/Huxl...52DE3.mp4.html
Air cylinder fitted just the connector to fit and get it repowder coated
When are you starting the wiring Paul? You must nearly be there now?
the updates seem to have slowed down!!!
Come on Paul
You need to get this in pent what colour you going
yea!!! what he said!!! getting less updates too!
Yes PLEASE...
Just building there... Something in my head, in there --->
Yes yes I know but we are all having the issues with Photobucket holding everyone to ransom over picture linking I need to work out the picture uploader on here and ill get back on topic but lots if progress since the last update though
http://media.turbosport.co.uk/uploader.php
Get cracking then
img]http://media2.turbosport.co.uk/2013/11/2017092708006940245puggy.jpg[/img]
well that was easy!
crack on with the pix hux!
Ideally you want to fit that as close to the front as possible and have a very short run from the bottle, via a regulator into your solenoid valves. I saw earlier that you are planning on controlling the pressure via a pressure switch, you will find your shifting will operate at different pressures doing that, keep the bottle at a higher pressure, and control the pressure to the actuator with a regulator. You also want to keep the air lines large enough all the way through, something like 8mm up the the solenoids, which should be very close to the actuator. Really lovely project, looking forward to seeing more updates
It's sat right above the cylinder on the tunnel we are fitting a regulator before the valve block
I need to find an image resizer as I gave a load of pics to go up but need to use the Turbosport uploaded ad I'm not prepared to be roped by Photobucket to upload pics
Hux,
Can you remember how thick the spacer was on the nose of your gearbox? I am going the same route with mine but need to make a spacer up!!
Ill try and measure it if I can later but it’s all bolted up a the mo, the engine is coming out to go up to Millington to have some bits done on it
IIRC it’s a Retro Ford one
[QUOTE=Huxley;3500088]Ill try and measure it if I can later but it
Any luck with measuring it?
Its about 42mm
Awesome that's great thanks.
Think I Need to add some new pictures to this post
Welcome back Huxley. How's the Car?
So I thought I should bring this up to date
Have a look
https://photos.app.goo.gl/Ws8LR7CKEnfWoB2t6
What a fantastic build, you must be very happy with how its turned out
and still not worked out the pic uploader i see
Well foof me it worked
