my mk1 indicator stalks abit tempremental
im on my second this last 12 months bad contacts etc
only to be expected at 40 years old
any one tried fitting one of these
http://www.ebay.co.uk/itm/LAND-ROVER...item416e8dfbd8
Nearly, I have put Landrover wiper stalks on the other side of the Mk1 column.
I have a rally car & I wanted to have a wiper & wash switch within easy reach on stage. I also wanted to make it look 'period'.
They also have a 'pull once for single wipe'
No real issue fitting them but I had to cut a hole for them as they stick out a bit...but there is more space on the indicator stalks side so it may not be an issue.
Hope that helps
thats what i was thinking
they look the right style
and must work better than my old ones as the one i currently use (3rd) feels notchy like its about to break and the dip beam went the other month in a cloud of smoke
my first one snapped befor i even used it and the second one had bad contacts on the points
cheers
As above, adding relays for the dim/dip and horn will help prolong the life of the switchgear.
That land rover switch does look like a good match though, I suppose you'll only know for sure when it turns up
http://escort.accelerator.org
Para, may I ask you exactly which gen Landrover this is from? It's just what I'm about to do to my escort and I'm looking for this, It's how I came across this thread, now Im searching for this wiper stalk and I'm not sure which one this is, I read some are only two speed without the ppull for single wipe option which I'd like to have Thank you for the answer! cheers
