Do you mean slanted like the picture below? Because if so yes you are correct it will actually be a true reading on the oil level if slanted. Whereas the 4AGE installed level will be false due to the sump bottom not being level and oil finding its own level within the space. In the picture of mine below the dipstick is the topside of the slant and therefore if I was to level the engine, my true oil level would be lower if level than if it was slanted for the same reading from the dipstick (full mark). Might not be much but its always worth checking
