Results 1 to 11 of 11
Thread: nodiz pro thoughts
    Aug 2012
    se london
    nodiz pro thoughts
    Evening all
    I am in the process of building a mk2 more door.
    It will be running a 2ltr zetec , i have been looking at megajolt/megasquirt to run it as these seem the most easiest and most common. How ever a new ignition managment has come up, it is called nodiz pro.
    It seems like it might be a new alternative to the usal mega stuff. I have enclosed the web link to see what others think , as it is new there is not to much about it yet ,however i know chester sport (i think thats there name) has got a 2ltr zetec running on it and ment to be running well. They are setting up group buys for clubs at the mo to help get there name out there i guess.
    I am thinking about buying it but couple more ideas would be nice
    http://www.nodiz.co.uk/
    Aug 2012
    se london
    Re: nodiz pro thoughts
    Just to add I am not linked with nodiz in anyway, just was thinking of other ideas to get my zetec up and running.
    Nov 2003
    Wirral UK
    7,322
    259
    Sounds interesting, from a quick look through the specs on their website it seems to have most of the features you'd want for an ignition controller.
    However, where Megajolt scores at the moment is that it's MUCH better supported, and the mapping software is excellent. Also it's all open source.
    Not knocking the nodiz at all, just pointing out some basic facts.
    http://escort.accelerator.org
    Aug 2012
    se london
    I do also agree, for the price megajolt seems to be better, as long as you can get a edis cheap as nodiz has the built in coil drivers. I already have edis and loom so megajolt would be cheaper for me.
    Give it a good year or so and i think nodiz might be better supported.
    For now i might have to go with what is tried and tested with many differnt zetecs and open source maps, ive still got a few months befor i need it anyway.
    Nov 2011
    Buckley north wales
    94
    Quote Originally Posted by Ross Bunce View Post
    Hi I work at chester sportscars and yes we do have a nodiz fitted to one of our cars (more of our demo cars are being swapped over as we speak )
    the system is very good in comparrision to the megajolt we use different features are mainly listed below
    16x16 map (megajolt is 10x10)
    hard and soft cut limiters (megajolt is soft cut )
    launch rpm control
    can switch cooling fan through the ecu via temp sender
    the main thing is theat the nodiz is wireless connection for mapping via bluetooth and also has the added feature of an android app for your phone for a didgi dash display that shows rpm, water temp, air inlet temp, throttle load, ignition advance
    we sell the ecu in the same way as we sell the megajolt (which we still sell) for the same spec ecu its the same price. if you want the added water temp and air temp senders and assoicated loom we do them too
    the mapping software is pretty easy to use you can download the mapping software from the nodiz site if you want a look
    I think the group buys have stopped now was just a launch offer they had
    if anybody wants to have a chat about it either give us a call at chester sportscars or give matt at m tech a ring he desigined the whole system and their support is top class with more features being added and with feedback from customers he is also looking at other things to add
    the edis 4 module is the main cost that pursuaded us to have a look at the nodiz as they are becoming more and more expensive even on e bay the prices have risen now nearly 3 times as much as when we started
    Aug 2008
    Queensland,australia
    483
    Hi guys I was wondering if anyone had any updates on using this Ignition ECU on a Duratec with carbies.? Is it any good.? Does it have decent mapping.? How about the Bluetooth issues.?
    May 2004
    Norn Iron
    886
    Quote Originally Posted by smicker View Post
    If you're really at the budget end of ignition.....Spitronics make cheap stuff ( fuel and sparks, but you could just use it for sparks )
    http://spitronicsau.com/product/saturn-standard/
    Although I see on their own website there is no image of the Saturn, and the Pluto now seems to be their budget offering.
    Or Megajolt....is pretty well tried and tested.
    Havent heard of many using Nodiz, but on paper it looks fine.
    Aug 2008
    483
    Thanks Stevie will have a look
    May 2004
    Norn Iron
    886
    Although more expensive, even a Link Atom would do, and would be a local supply. Even something second hand although most ecu's tend to hold good resale values
    Aug 2008
    483
    Has anyone used the Motorsport Electronics ME100 ECU.?
    Aug 2015
    Leeds
    770
    There’s a tuner near me that uses the nodiz systems, he’s does a lot with bike carbs and throttle bodies.
    DanST Engineering. Might be worth a call.
    http://danstengineering.co.uk
  12. The Following User Says Thank You to Warrior For This Useful Post:
