Results 1 to 4 of 4
Thread: S2000 Air Pump Removal in the UK - Technical Content
    Apr 2003
    Essex
    137
    Hi. I've an S2000 with stock ECU in an escort. I've one remaining fault code which is stopping me running the keep alive memory to the ECU.
    (Right now I've no keep alive so it resets on every key start - means I have to let it warm up with the mil on, the restart to reset it - also means that it maybe starts from a base map and this is why it's so limp wristed when driven in a sprited manner (I hope!!))
    So. Anyone know how the UK air pump circuit works?
    Or. If anyones got a UK airpump relay (&/or the bit of loom it plugs into) I would happily buy it.
    Be aware that there is a USA worksop manual out there, which shows a feedback circuit that the UK cars do not have. I'm just starting out on this one. Will happily share what I know with likeminded souls. I'm only really interested in the technical stuff though - thanks to all who read.
    Rich B
    (I wish I was)
    Jan 2007
    Weston Super Mare
    1,056
    77
    Re: S2000 Air Pump Removal in the UK - Technical Content
    I have a couple of standard s2000 ecu's for sale if that is easier?
    Dec 2011
    Northamptonshire
    733
    You need the loom and relay connected then you just bridge the connector with a resistor this will fool the ECU the air pump is there something like this http://www.ebay.co.uk/itm/3801079029...d=441146223309
    Jun 2008
    Dunfermline, Fife
    459
    62
    Hi there, how did you get on with this ?
