i am going to take the plung and buy a brand new set i think as i can't get hold of a second hand pair and can't be arsed to mess about making a set. The tappets you accutally just hit on a hard surface that won't damage the tappet and the middle bit falls out. After that you pull them apart with your fingers untill you get to the small ball bearing non return valve then you pull that out with a pointy nose pliers.
Should be looking at 220bhp with the 45's i hope should be running around 240bhp with bigger induction but we shall see.
