Page 8 of 36 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 ... LastLast
Results 281 to 320 of 1420
Thread: Project more door aka the sh!++3$ for autotests, drift days and road rallys
  1. #281
    Jul 2010
    South Wales
    4,689
    221
    Re: Project more door aka the sh!++3$ for autotests, drift days and road rallys
    the gearbox/engine building bench all cleaned down
    the head has had a slight skim too I have to check the cylinder head cc again now to double check the cr although it should be fine
  2. #282
    Jul 2010
    South Wales
    4,689
    221
    looking through all the stuff I used to make the dta loom I found this
    I forgot I had made an injection loom ready for when I go injection so it is now a case of plug the loom in and play away
  3. #283
    Jul 2010
    South Wales
    4,689
    221
  4. #284
    Jul 2010
    South Wales
    4,689
    221
    Looking down the throttle body to the inlet i wasn't happy with the shoulder it hit ao i blended it out to match the 48's there is a slight rad on the inlet not a straight shank so the air flows somoothly into the inlet instead of hitting a shoulder about 1mm each side. So the air will still be disturbed but not hitting a wall.
    That's the idea any way
    No photos of the finished inlet yet
  5. #285
    TURBOSPORT SPONSOR Turbosport Sponsor
    Mar 2014
    Leeds
    185
    You need to loosen off you manifold and move it a tad then it will have a smoother flow
  6. #286
    Jul 2010
    South Wales
    4,689
    221
    Quote Originally Posted by Andrew@ALD View Post
    yeah i did jiggle it about a bit and got the inlet to match the head, it was the throttle bodies to the inlet (second photo) i wasn't happy with so i have removed some of that material.
  7. #287
    Jul 2010
    South Wales
    4,689
    221
    Bodies matched to the inlet.
    Before
    After
  8. #288
    Jul 2010
    South Wales
    4,689
    221
    I also can't resist a bargin so i bought this
    Bodies trial fitted.
    I have also ordered the linkage bracket to fit the linkage underneath the bodies as the jenvey linkage looks like something you would win in a cereal box and i want to hide it as much as possible.
  9. #289
    Mar 2014
    Leeds
    185
    If I were you I would get a new manifold fabricated up with larger ports that are angled to the same as the inlet port of the head
  10. #290
    Jul 2010
    South Wales
    4,689
    221
    Quote Originally Posted by Andrew@ALD;u2290591
    Yeah i might do at a later date. At the moment i am using the one made for the webers a flat type manifold. We will see how it goes with that. I know the boys on the rs2k forum are using the angled type inlet with good results but they are for the rs2k heads with out the water port on the side :-/
  11. #291
    Jul 2010
    South Wales
    4,689
    221
    Well after speaking to someone on the forum there might be plans to bolt a 6 speed rx8 box up to the new a
    Engine it would be a shame not to use the tran x though!
  12. #292
    May 2009
    Maesteg South Wales
    2,041
    142
    I was thinking when you were on about the size compared to a type 9 the other day what It would take to fit one...
    Do you know the ratios John and what's Involved to fit It?
  13. #293
    Jul 2010
    South Wales
    4,689
    221
    Quote Originally Posted by evans2822 View Post
    basically make an adaptor plate and convert your clutch to hydraulic it is a mazda/ford gearbox at the end of the day
  14. #294
    Jul 2010
    South Wales
    4,689
    221
    basically you should be able too pull of in second on the flat but you always have first. I has closer ratios than a type 9 but 2-6th is pretty much the same as a tran x type 9 1-5th. The rx8 first gear is close to a standard type 9 ratio too so it is like having the best of both worlds a short 1st for hill starts and a standard type 9 5th 0.84 as 6th and a load of close gears in between.
    rx 8 box
    1st --- 3.760
    2nd --- 2.269
    3rd --- 1.645
    4th --- 1.187
    5th --- 1.000
    6th --- 0.843
    tran x
    1st - 2.48
    2nd - 1.69
    3rd - 1.27
    4th - 1:1
    5th - 0.87
  15. #295
    Jul 2010
    South Wales
    4,689
    221
  16. #296
    May 2009
    Maesteg South Wales
    2,041
    142
    Cool I will look Into that If my type 9 goes tits up
  17. #297
    Jul 2010
    South Wales
    4,689
    221
    you'll be fine with the power your running.
  18. #298
    Mar 2014
    Leeds
    185
    Let me know the engine goes when it's up and running.
  19. #299
    May 2009
    Maesteg South Wales
    2,041
    142
    LoL I don't know If the box Is any good never tested It
  20. #300
    Jul 2010
    South Wales
    4,689
    221
    aaaa we could always rebuild it.
  21. The Following User Says Thank You to freddy686868 For This Useful Post:
  22. #301
    Jul 2010
    South Wales
    4,689
    221
    this might be of interest to someone on here I know it is to me!
    plenty of room for the flywheel
    ooooooo the clutch fits!
    so does the spigot bearing!
    Last but not least comparing the actual gearbox sizes
    I have also had my ally carb tank converted to injection too! By Zackham Engineering and the work done is very high standard as always!
    I had to buy a shiny new part too for the new pump and filter set up in the boot.
  23. #302
    Jul 2010
    South Wales
    4,689
    221
    Well i was a happy boy when i got in from work today (vernier in hand) and thats not inuendo. These beuties were waiting for me after about 5 weeks of waiting for them!
    Way too shiney for my liking!
    A nice thick rib for strength ans i noticed the pin mounts are inboard i'm assuming it is to keep the strength in the center of the piston and pin length down reducing the pin weight maybe.
    A nice 12cc crown in them. I will have to remeber that the crown isn't centeral when fitting them into the engine too. :P
    Some new vs old now i just hope they work!
    I'm going to weigh them all up soon with the pins and rings to see if i can match them to a rod so they are all of similar weights.
  24. #303
    Jul 2010
    South Wales
    4,689
    221
    They also come in under budget too which has been rare in this engine build.
    Next up is to order the head gastket, bolts Timing chain and other items. I am hoping to have the engine in the car by the end of next week!
  25. #304
    Jul 2010
    South Wales
    4,689
    221
    Well i weighed them all with the rings pins and the pin circlips and they were all within 0.002grams of each other! And the piston diameters are all with in 0.004" of each other. Now just to match them to a rod to make them perfect.
    All matched to the pistons
    Block is also having a pampering it has been chemically stripped and is going for a paint and a rebore monday :P
    Spottless
    Outsides looking good too
  26. #305
    Jul 2010
    South Wales
    4,689
    221
    I have decided to have the full bottom end balanced too whilst it is at the machine shop as i have heard it makes a big difference. Can anyone tell me what the binifts are of a balanced botoom end are please?
  27. #306
    Ireland
    3,579
    173
    Balanced bottom ends can possibly increase bearing life, lets say the flywheel was well out balance the rear bearing would want to wear more quickly, also the idle rpm will be a little more steady, apart from that no difference, usually std balance is fine unless using very large rpm's over 8k
  28. The Following User Says Thank You to RWD fords rule For This Useful Post:
  29. #307
    25,110
    im with jason.
    very little benefit in my opinion! assuming you dont have any major weight differences in rods and pistons.
    over the years i have had numerous engines which started out balanced and over a period of time they have had rod changes, flywheel changes, flywheels further lightened, then swapped for lighter steel ones,which were then further lightened, and then further lightened, even crank swaps, so ended up baring no resemblance to the original balanced article, could i tell the difference? no, infact one well known rr operator commented how smooth the engine was!
    i did recently have a vw 92.7mm stroke crank and flywheel balenced, mainly because it had a cast flywheel from which a machined 3kgs of material off and i figured the long stroke will show up any imbalance worse and that cast flywheels don't have the same consistency of material in terms of density as a billet steel one, and its going in a rally car which will see 8K
    when they came back the crank was practically untouched, and although the flywheel did have more balancing drillings in it, it had far few drillings than it came from the factory with, i had actually machined away a fair bit of the imbalance!
    for fast road/mild competition engines which are only revving to 7-7.5k i dont bother. neither do i when using billet steel cranks and flywheels
  30. The Following User Says Thank You to Graham For This Useful Post:
  31. #308
    Jul 2010
    South Wales
    4,689
    221
    im with jason.
    Thanks for the input guys. I don't think i will balance it now as it sounds like a waste of £160 as i am only runnig a 91mm stroke and if it revs and makes power to 7.5k i will be surprised. Well thats a timing chan kit and a head gasket kit instead of the balancing. Just in time too as i'm dropping the engine off tomorrow for boring and honing.
  32. #309
    Jan 2011
    clacton essex
    1,731
    70
    Not checked in ere for a while, can't wait to see what you get out of the engine, or how long it'll last, these engines are started to get noticed abit round my end, I have 1 to put in a mk5 fiesta and I trying to speak a customer into having 1 in a trike instead of a pinto, and possible get mine done,,
    Any way top thread,,,
  33. #310
    Jul 2010
    South Wales
    4,689
    221
    Quote Originally Posted by rwd2ltrfiesta View Post
    They are a great engine and the guy in the machine shop said he hasn't seen one of these engines in a while. I was saying you should be seing a few more of these. I am expecting about 250bhp but people are quoting more out of thiers but unproven.
  34. #311
    Jul 2010
    South Wales
    4,689
    221
    All painted up! Looking mint too.
    I also flushed my radiator with jizer, 2lrs of the stuff! It is now oil free now.
  35. #312
    Mar 2014
    Leeds
    185
    You should of sent me your crank to be lightened and balanced, I've done loads of them with good results..
  36. #313
    Jul 2010
    South Wales
    4,689
    221
    I was going to but I didn't get it done yet again for what I am doing I don't think it is needed.
  37. #314
    Jul 2010
    South Wales
    4,689
    221
    well I got the block back from the machine shop and fair play I paid from a rebore and rehone and that is what I got! The block was stinking, how they made such a mess just taking 40 thou out of the bores I will never know.
    Any way I measured the bores and they were cock on so that's the main thing
    gapping the rings
    pistons out to play
    head out to play
    crank going in
    pistons on the rods
    rings on the pistons
    full gasket set
    new timing chains
    piston number 1 in
  38. #315
    Jul 2010
    South Wales
    4,689
    221
    all the pistons in
    head gasket is plenty big enough for the new pistons
    sump 'modded' to clear the new rods and arp bolts I'm glad I turned the engine over at every stage to check the rotation of the bottom end now otherwise it could have been messy
    oil pump chain fitted
    head fitted and timed up
    bottom end timing mark
  39. #316
    Jul 2010
    South Wales
    4,689
    221
    all done ready to go in tomorrow!
    I can just hear these making a brapppp brraaappp in the near future. You will also notice I used the under throttle body linkage bracket as I don't want everyone seeing that piece of rubbish in the engine bay.
  40. #317
    Pit Crew 5tox's Avatar
    Jul 2012
    cambridgeshire
    1,054
    Great work as always mate
  41. #318
    Jul 2010
    South Wales
    4,689
    221
    thanks. I left out the part where an old helicoil stripped out the head on cylinder number 1 spark plug when it was fully built up!
    It resorted in me stuffing a load of rags in the inlet ports covered in wd40, leaning the engine over, greasing up the tap to catch the swarf and cleaning out the threads and inserting a new helicoil, a bit annoying when you have to do things like this on a 3k build!
  42. #319
    Jul 2010
    South Wales
    4,689
    221
    well I have cracked on with this over the last two days and this is as far as I have gotten.
    all thrown in the back of my brothers new truck
    engine went in about half an hour after I unloaded it with the help of my mate Lloyd and the good old mini digger it was in with in 10 mins
    there isn't a great deal of photos over the next steps but the box and prop are back on and all oiled up gearstick on and the injector loom has been added and tested which I'm glad to say works fine
    I moved on to cutting a hole in the tank platform for the new and improved injection tank and working out where to place the fuel pump and filter and I have found the place. Purely based on what rubber fuel pipe I had hanging around
    exhaust and alternator set up back on
    bodies fitted hehe
    and finally the injector loom fitted
  43. #320
    May 2009
    Maesteg South Wales
    2,041
    142
    Christ that was quick lol
    Bet that engine was a walk In the park after the bag of cogs and a gearbox casing great work...
