Page 1 of 2 1 2 LastLast
Results 1 to 40 of 45
Thread: DTA S60 ECU any good ?
    Pit Crew Decade Plus User Huxley's Avatar
    Feb 2005
    Thatcham
    987
    79
    Has anyone used one of these, just looking to change the ancient Weber Alpha ECU on my Millington just after some views on the ECU
    Cheers Paul
    Mar 2004
    Barking Essex
    9,033
    262
    Pukka ecu works really well with loads of different options and excellent after sales service.
    Most rolling roads use them.
    Old skool forever
    Just don`t tell the wife
    how much it really costs!
    romford essex
    2,613
    86
    Re: DTA S60 ECU any good ?
    As above good value for money
    Bristol
    175
    17
    Unless you have a turbo'd motor you probably only need the S40. Check the spec's of both ECU's before parting with your cash as the S40 is a very capable ECU and cheaper !!
    Jul 2010
    South Wales
    4,689
    221
    what has the s60 got that the s40 hasn't? your onlu running a 4 pot in n/a form so the s40 should be fine for what you want and cheaper.
    Feb 2005
    Thatcham
    987
    79
    I think the S60 has can interface for the X Dash IIRC as an add on later if required ?
    Just looked and the 40 doesn't have Data Logging and is not water proof if it was in a normal car I wold say that's ok but it's going in my rally car and the can get vey damp from past experience !
    Jul 2010
    South Wales
    4,689
    221
    Quote Originally Posted by Huxley View Post
    If the 40 is missing features you need then got with the s60. Are you buying one new? If so contact MEF Motorports he can get you the ecu ecu plugs and all the plugs for the sensor plugs and raykem wire cheapest about too!
    Dec 2008
    lancashire
    69
    The S40 has the same can interface as all the others in the DTA range so will work perfectly with an X dash. As far as being waterproof, yes you are right, it's not sealed like the S60 but it's considered to be splash proof and certainly is fine in most situations, in fact there's 1000's of them out there in all forms of Motorsport disciplines. The circuit board and components are actually covered in a protective lacquer so if damp does get inside it doesn't cause corrosion or stop it working! The main reason for customers choosing the S60 is usually down to wanting to use individual coils per cylinder or wanting full sequential injection, also the data logging facility. The S60 also has more features and analogue inputs which can be very handy. The S40 on the other hand does most basic functions and is commonly used on big power 4 cylinder engines like XE and Millingtons etc
    Hope this helps, ring me or pm me if you need more info,
    Martin
    I support TS Decade Plus User
    Jan 2007
    Dorset
    1,232
    168
    Yep i've got the S40 Paul, and one day will treat myself to the X-Dash!
    3,236
    Compared to some others at a similar price point the software is a bit clunky to use / change on the fly. Most use a 'dyno box' to interface between the ecu and the PC / lappy as changes added via the usual keyboard keys isn't intuative......apparently! I'll find out later this year hopefully but i've also got the box as well! I got the DTA cos it was cheap otherwise would have prefered the Emerald system!
    Nov 2002
    Grimsby
    112
    I went DTA, all seems good so far. It was the most cost effective solution for me.
    Feb 2005
    Thatcham
    987
    79
    Now have an S60 pro unused and just over a year old checked it with DtA via the serial number all ok so just got to get the X-dash, some plugs but want to modify the USB bit with the buttons so I can have the buttons on the steering wheel to change the display on the fly being a fat git and the dash is a long way away lol
    Can't make my mind up as to have both gear displays as in the Tractive one that changes colour or just have the X-dash one ?
    Jan 2007
    Dorset
    1,232
    168
    I know what you mean, its a tough decision !!
    Feb 2005
    Thatcham
    987
    79
    I have seen a mk 2 with a small display sculpted into the top of the dash and filled then flocked looked quite good but the Tractive one is huge ?
    Jan 2007
    Dorset
    1,232
    168
    The tractive one is a whopper, but thats what makes it cool!
    Well either way i guess if you have the tractive, and will get the x-dash you can have different pages on the dash, one with and one without?
    Feb 2005
    Thatcham
    987
    79
    There is only one fly in the ointment I'll need varifocal glasses to see up the road and the dash at the same time lol
    You in Theale tonight ?
    Spanner Monkey mk2mania's Avatar
    Feb 2010
    lancashire
    352
    got s40 on a xe and thats mint ( got it from MEF spot on ) , ive also got a s60 on an st170 motor which also works mint,, go for the one that suits your build ( good back up if you need from dta )
    Feb 2005
    Thatcham
    987
    79
    Bugger I should have got a DTA S100 it's supposed to have a full gear control unit for paddle shift software/firmware in it now
    Just found out on British Rally Forum there is a thread in there about it.
  19. #19
    Nov 2012
    West berks
    what did the s60 cost you?????
  20. #20
    Feb 2005
    Thatcham
    987
    79
    £150
  21. #21
    Spanner Monkey genRS2000's Avatar
    Jan 2009
    Perth Western Australia
    67
    438
    30
    I have a Geartronics display as well as the X-Dash which was a good decision as the gear position on the X-Dash is playing up so I have the Geartronics display to fall back on.
  22. #22
    Jan 2007
    Dorset
    1,232
    168
    £150
    Paul, PM me with how much you want for it if you do upgrade!
  23. #23
    Nov 2012
    West berks
    £150
    if you want to upgrade i will have that off you at an increased price unless i source one for next toy before that???? let me know
  24. #24
    Feb 2005
    Thatcham
    987
    79
    Oh just checked on Paypal got the price wrong lol was £600
    GenRS200 it might pay to check that some gear display pots won't take two outputs ?
    Have look here http://www.turbosport.co.uk/showthre...96#post2324396
  25. #25
    Nov 2012
    West berks
    could still be tempted
    as fot the barrel sensors the penny-giles ones are amongst the best they go a four wire one (gives 2 outputs 1 for display 1 for engine ecu
  26. #26
    Nov 2012
    West berks
    http://www.pennyandgiles.com/Product...RH280P-DP.aspx
    dual output penny and giles sensor
  27. #27
    Jan 2007
    Dorset
    1,232
    168
    Quote Originally Posted by Geordie View Post
    Even says Geartronics use them in a Motorsport paddle shift !
  28. #28
    Nov 2012
    West berks
    Quote Originally Posted by Paul C View Post
    You can get them from geartronics and I think quaife what box you got save me rereading the thread?
  29. #29
    Jan 2009
    67
    438
    30
    I have fixed the problem now. It was not the pot (I have a dual pot that was supplied with the Geartronics paddle shift kit ). Somehow the voltages for 4th, 5th and 6th gear that I stored in the DTA map had changed so I was getting a neutral reading for these gears on the dash.
  30. #30
    Nov 2012
    West berks
    Quote Originally Posted by genRS2000 View Post
    out of curiosity were the gears wrong on all pages of the x dash?? or does there only have 1 map for gears that goes on all pages of the dash?
  31. #31
    Jan 2009
    67
    438
    30
    Each page gets the same data from the ECU via the CANBUS so the gears were wrong on every page.
  32. #32
    Feb 2005
    Thatcham
    987
    79
    Just about to send my DTA off for a firmware update and a check up
  33. #33
    Nov 2012
    West berks
    can you not do it yourself? are they not online?
    anyway prodrive??? why??
  34. #34
    Feb 2005
    Thatcham
    987
    79
    After what happened to the last ECU I thought I better not leave it a year or so before I do anything with it, a least I know with this one now it's all ok and got the latest firmware in it
  35. #35
    May 2004
    Norn Iron
    1,141
    DTA usually shutdown for a couple of weeks around this time, as Allan is over here at Craigantlet hillclimb
    Bare that in mind if sending the ecu off, check first.
    Firmware upgrade is a fairly easy DIY job if you have a cable with a flash button.
  36. The Following User Says Thank You to stevieturbo For This Useful Post:
  37. #36
    Nov 2012
    West berks
    Good point well presented!!!
  38. #37
    Feb 2005
    Thatcham
    987
    79
    All sorted Steve great service too, I going to be getting X Dash so as I thought that was USB I might be able to do a firmware from that when I get it, if not it has the up to date one on it for now.
    Troy at Northampton Motorsport will be mapping the car for me
  39. #38
    May 2004
    Norn Iron
    1,141
    X-Dash wont help with flashing new firmware to the ecu
    Quickish how to for flashing.
    http://www.dtaforum.com/viewtopic.php?f=8&t=8
  40. #39
    Feb 2005
    Thatcham
    987
    79
    I have decided to have both, I am going to make a additional moulding in a spare dash top we have then get it flocked
  41. #40
    Sep 2015
    Perth, Western Australia
    I live in Perth too and badly need a dyno where the people already know how my S40 DTA works. Travel is not a problem. Know of one?
