My mbe ignition pack has a small lead ending with a d type plug with 9 pins do I need only a lead to connect to lap top or is there any thing else I require will be trying to adjust rev limiter or is it better to leave well alone
you need a proper mbe lead to connect the ecu to a laptop. have a look on the sbd website, it has instructions on how to make one.
http://escort.accelerator.org
as above ^^ this would be the older type 9 pin serial MBE "boingy" lead. iirc has resistors, and is not a "straight" cable. £45 i think?
- colin
