FULL Janspeed Turbo Kent Crossflow kit
From my mk1 XR2
Janspeed turbo conversion, running 6.5 PSi boost. Includes manifold, turbo, wastgage, inlet manifold correct positive pressure carb jetted etc for 1600cc engine, janspeed plenium, all oil lines, all fuel lines, facet fuel pump, all literature, unused janspeed serial plate.
dizzy coil and microdynamics turbo ignition control, although if I were to fir this kit again I would go for trigger wheels megajolt kit for hassle free set up
increases power at the wheels from 55bhp to 85bhp on an other wise standard XR2 (rolling road from 1982) on standard compression
Was used by a college for development work on a testbed engine (literature confirms) Fitted to my xr2 at around 2001 by previous owner (still have his contact details) and done about 2-3k.
oil lines plug straight into a front wheel drive cross flow, cant imagine it will be much different for a rwd set up
this is an older photo, its all currently off the car I will get a current photo as soon as possible
£750 Posted, or pick up from Ayrshire
Re: FULL Janspeed Turbo Kent Crossflow kit
Originally Posted by
the real boris Has this item long gone?
Was just about to ask the same thing!
