Aldon "Amethyst" Mappable Ignition System.
Has anyone tried one of these?
http://www.aldonamethyst.co.uk/
Re: Aldon "Amethyst" Mappable Ignition System.
yes we did it worked right out of the box.... if you read the instructions carefully
(Light has to turn on not off for initial setting...)
Make yourself a spark map with 10° advance everywhere time it to that; tighten distributor and rev engine it will stay at 10° if done right and no slack in the distributor advance mechanism...
Put the right advance curve and away you go!
It's money well spend
CheeRS
Jens
r these 4 engines with out dizzys???
just red it, guess not
