T9 electric speedo sensor wiring
Hi everyone,
my T9 gearbox died under loud noises and rumble yesterday. It had only a cable drive speedo.
I got another new rebuild T9 box witch has a cable speedo and a electric ford sensor for a electric speedo as well.
I would like to use the electric sensor together with my vapor digi dash that normally uses a hall effect sensor mounted on a wheel.
On the sensor from the T9 box are 3 cables comming out. How do i have to wire them?
Is it possible to use the original Ford sensor with my digi dash?
My new box is probably one of the last produced ones from a 4-cyl engine. I think it will fit, but the input shaft is about 3mm longer than the one on my old box and the leght of the 23 theet is also a little bit longer. Am i right, that it will still fit?
Best regards
Chris
