Page 6 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 201 to 240 of 374
Thread: 5tox mk1 escort restoration project
  1. #201
    Is that part not notched out when 6 linking ? For greater travel.
  2. #202
    2,656
    267
    Re: 5tox mk1 escort restoration project
    It can but you dont have to.
  3. #203
    Pit Crew 5tox's Avatar
    Jul 2012
    cambridgeshire
    1,054
    dont people notch that part out to get the car lower / wheel right up in the tubs?
    I wont be too low as the roads round here are really bumpy
  4. #204
    Jul 2012
    cambridgeshire
    1,054
    i finished work early so spent hours measuring up before cutting out the rear quarter for the bubble arch, i'm actually no further forward though and more confsed now than i was before i started.
    With the car on the spit it i fitted the axle on leaf springs and found that it didnt help much because as the wheel goes up into the arch it also moves further toward the rear of the car, is there a decent guide anywhere with measurements?
  5. #205
    Jul 2012
    cambridgeshire
    1,054
    After 'daveMK1' kindly spent some time expaining how he did his bubbles on the phone i took the plunge and got stuck in, to be honest i feel a bit daft now as it took me about 15 minutes to get to this stage.
    i barely had to linish it back at all and i'm very pleased with the fit, the wing presses right up into the curve of the bubble so very little filler will be required.
  6. #206
    Nov 2011
    ochiltree
    134
    Looks great man, keep it going��
  7. #207
    May 2016
    Germany
    288
    63
  8. #208
    May 2016
    Germany
    288
    63
    Great work! Very nice craftmenship
  9. #209
    Mar 2014
    London
    110
    Looking good m8 - if your going down the turret route then do them first as it gives you more room to work in .. the tub infills are a pain in the backside
  10. #210
    Jul 2012
    cambridgeshire
    1,054
    rear firewall is now out so i can access everything
  11. #211
    25,110
    love the way you are working through the car
  12. #212
    Jul 2012
    cambridgeshire
    1,054
    Took a closer look at the chassis rail behind the tub and it was in bad condition, as was the floor section underneath.
    Fortunately i had some spare bits that come with the car and these sections were included so i set about chopping out the old crap and tidying up the replacement bits.
    They sit in quite nicely but there's a 10mm gap between the two chassis rail sections so ill weld a little plate over the top connecting the two.
    hopefully i'll get this lot welded in tomorrow
  13. #213
    Jul 2012
    cambridgeshire
    1,054
    Took a long time to get it back in today but i was taking my time and paying attention to detail, another hour or so and it'll be done ready for my turret to go in
  14. #214
    May 2010
    london
    1,139
    coming on nicely..take your time and do it once...the right way..(as you are doing)...its going to be a nice strong motor when finished...cheers mark
  15. #215
    Jul 2012
    cambridgeshire
    1,054
    I spent a long time looking up turret fitting guides and found lots of measurements etc. which just didn't seem to work, so finally decided to just get the car square on the jig and use the laser level drawing a vertical line up from the centre of the bump stop.
    Laid the parcel shelf on top to see how it sits against the turret, not sure if i need to take the turret higher or lower yet.
    It seems to fit quite nicely, i'm hoping to have it welded in tomorrow so i can look at permanently attaching my bubble arch.
  16. #216
    May 2010
    london
    1,139
    looks spot on...id take it a bit higher..to meet the fire wall/parcell shelf..would make the welding/ blending a lot neater...and of course higher equals mor movement to make the car lower with shock heights..if you need to...good job...cheers mark
  17. #217
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    502
    That's about where mine are. My cup washer is about level with the bottom of the folded over piece that the quarter panel trim tucks into. That's the only reference point I can give you as mines an earlier shell!
    If I remember rightly the turrets are angled in 3 each degrees which should give you as near as damn it 1000mm between the hole centres
  18. #218
    Jul 2011
    herts
    502
  19. #219
    Jul 2012
    cambridgeshire
    1,054
    Ta mate, i did find a drawing with some measurements online (Gartrac comes to mind)
    and it said 14" from the top (inside) of the turret to the bottom of the chassis rail which brings it to where you said.
    I perhaps could have gone a little higher but i haven't notched out the chassis rail and don't plan on taking the car too low as the roads round here are terrible
    The turret is welded in and i'm hoping to get a little more done today, should have a few more pics up later
    Thanks for all of the comments and interest
  20. #220
    Tyre Kicker Dacarpking's Avatar
    May 2017
    Suffolk
    19
    10
    Coming along really well mate.. I’ve had very similar issues with mine ended up replacing all of the chassis rails front to back and the metalwork underneath. Also had anxiety about turret fitment, but to be honest as long as they are somewhere near and look right I wouldn’t worry to much about measurements. Top job 👍🏻
  21. #221
    Jul 2012
    cambridgeshire
    1,054
    Got a couple of hours on the old girl this afternoon, one of my welds is pretty shocking so i'll go back and tidy up with the dremel, the rest seem ok.
    cut a circle out of the parcel shelf which just needs taking back with the flap disc then this side is pretty much done.
    I can then get back on with all the little jobs i never finished like welding up the holes in the parcel shelf.
  22. #222
    Jul 2012
    cambridgeshire
    1,054
  23. #223
    Jul 2012
    cambridgeshire
    1,054
    Now i pretty much have to copy exactly what i did on the N/S/R arch to the O/S/R
  24. #224
    25,110
    its coming along nicely
  25. #225
    Jul 2012
    cambridgeshire
    1,054
    Today i set about fitting my other rear turret, i first found a nasty rotten piece which had to be cut out and replaced.
    I then cut out a hole and fit my turret, its welded in place but still needs the lip folding over and seam welding all the way round the tub.
    The parcel shelf has been laid on top and just needs the turret holes grinding back until they fit, there is another small piece i need to make and weld in then im ready to weld the parcel shelf back in.
  26. #226
    25,110
    you certainly couldnt be accused of cutting any corners, cutting them out maybe
    excellent work keep it up
  27. #227
    Jul 2012
    cambridgeshire
    1,054
    Cheers Graham, hoping to see some major progress this summer.
    Hopefully all the major structural stuff will be completed, i started from the front and worked back so not too much left to do,
    I know the rear chassis rails under the boot floor are pretty bad
  28. #228
    Jul 2012
    cambridgeshire
    1,054
    I chopped the firewall down today so it fits between the turrets, im going to have it set back approximately an inch from its original position so it sits snuggly between the turrets.
    Haven't welded it in yet though.
  29. #229
    Jul 2012
    cambridgeshire
    1,054
    Offside rear turret is now fully welded in, link boxes are tacked into position.
    I then did a few repairs to the offside rear tub which i was very pleased with, should have my last bubble welded on pretty soon
  30. #230
    May 2010
    london
    1,139
    coming on great ...the more you do the better it gets...and the everything moves up a level...i look back at my first welds when i started my project..and consider doing them again lol...(they looked good then..but now they dont look as good as my latest welds...lol)...keep up the work will be a stunner when finidhed...cheers mark
  31. #231
    Jul 2012
    cambridgeshire
    1,054
    Chopped out some old crap and welded in some fresh steel, was going to buy a replacement panel but there almost £50!!
    I dont intend on using the original fuel tank anyway x
    Sent from my SM-A520F using Tapatalk
  32. The Following User Says Thank You to 5tox For This Useful Post:
  33. #232
    Mechanic mk2-mad-ad's Avatar
    Nov 2008
    stoke
    644
    25
    brilliant work mate really starting to come together now looks really smart bud
  34. The Following User Says Thank You to mk2-mad-ad For This Useful Post:
  35. #233
    3,641
    Tidy work
  36. The Following User Says Thank You to Erikmex For This Useful Post:
  37. #234
    Jul 2012
    cambridgeshire
    1,054
    Got a little further with it today, took hours to carfully chop the rot out of the opposite side, i had to remove the chassis rail and will probably have to make a replacement as it was completely rotten
  38. #235
    Jul 2012
    cambridgeshire
    1,054
    A little further with it
  39. #236
    Jul 2012
    cambridgeshire
    1,054
    Made a new chassis rail which im extremely pleased with
  40. #237
    Jul 2012
    cambridgeshire
    1,054
    New chassis rail is in, half the rear panel has been cut out and ive removed a badly repaired section where the boot floor meets the rear panel
  41. #238
    Apr 2013
    S Wales
    230
    431
    Good work. It amazes me the patience involved with fab work that some people can do.
    How long since you started this project at day zero?
  42. #239
    Jul 2012
    cambridgeshire
    1,054
    Quote Originally Posted by dt36 View Post
    Blimey its been years on and off, probably around 6-7, cant wait to finish it.
    Its very rewarding fabricating bits from scratch
  43. The Following User Says Thank You to 5tox For This Useful Post:
  44. #240
    Jul 2012
    cambridgeshire
    1,054
    A few more bits done ready for my new chasdis rail and rear panel to be fitted
