Page 9 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 321 to 360 of 374
Thread: 5tox mk1 escort restoration project
  1. #321
    Pit Crew 5tox's Avatar
    Jul 2012
    cambridgeshire
    1,054
    Lots of odd little bits of welding done today such as the middle exhaust bracket.
    Finished welding up my gearbox tunnel to the bulkhead, she now looks like a basking shark with a huge open mouth, great for the big old gearbox but not so good for my left foot when its not on the clutch pedal.
    Hopefully soon she will be seam sealed underneath and off the jig.
    I really need a few hours just going round making a list before i do that.
    Sent from my SM-A520F using Tapatalk
  2. The Following User Says Thank You to 5tox For This Useful Post:
  3. #322
    3,242
    Re: 5tox mk1 escort restoration project
    Could always put an Auto box in there ! LOL!
  4. #323
    Jul 2012
    cambridgeshire
    1,054
    Not in a million years
    I reckon there will be just enough room for my to weld a little foot rest to the side of the G/box tunnel
  5. #324
    Jul 2012
    cambridgeshire
    1,054
    Cut and welded my nearside front wing so its gapped correctly with the fitted door (i may still adjust it ever so slightly)
    Need to re-skin both of my doors, so keeping an eye out for something reasonably priced
    I also welded on studs for my handbrake 'p' clips, now do i:
    1. Clip them to the body where left and right cross over
    2. Clip them yo the axle
    3. It doesnt matter which and im worrying over nothing
  6. #325
    Jul 2012
    cambridgeshire
    1,054
    This weekend my drivers door has been on and off at least a dozen times while i cut and re welded the lower bracket to get the door in the right position, i also cut and welded along the back of the frong wing where it meets the door to get a consistent gap.
    The door itself wasnt too bad but sections of the skin had rotted through so has to be replaced.
    Cut the skin off, did a few small repairs along the bottom and am now looking for reasonably priced door skins.
  7. #326
    Spanner Monkey HOSSMAN's Avatar
    solihull west midlands
    359
    21
    watched you do this from the start always look forward to posts fair play mate will be a very nice car when done
  8. The Following User Says Thank You to HOSSMAN For This Useful Post:
  9. #327
    Jul 2012
    cambridgeshire
    1,054
    A few little bits tidied up, i added a strengthening bracket from the middle of the rear panel to the boot floor to stiffen this section up (copied it from one of my favorite resto threads)
    Done a few repairs to the inner door frame and fitted the skin, still a bit of work to do around the front where the wing mirror sits, better get the hammers and dollies out
  10. The Following User Says Thank You to 5tox For This Useful Post:
  11. #328
    Jul 2012
    cambridgeshire
    1,054
    Drivers door is pretty much there now, done lots of odd little bits of fillering and sanding.
    Made a cool little bracket for my megasquirt, ecu tucks away neatly beside the glovebox.
    Sent from my SM-A705FN using Tapatalk
  12. #329
    Jul 2012
    cambridgeshire
    1,054
    Very pleased with this little ebay bargain!!
  13. #330
    Well done mate nice project
  14. #331
    Jul 2012
    cambridgeshire
    1,054
    My brother kindly brought over his retro ford bits and jenveys today so we could see if the engine was in the correct position, the idea being that retro ford stuff should fit.
    What we discovered is that although it was close, the engine had to drop a touch lower, go forward a touch and angle backwards.
    Its in a very nice position now with all the bits fitting correctly, i have to say the retro ford parts are fantastic quality, having seen them up close im very tempted to buy a retro manifold and water rail.
    My gear stick is now far lower and in a much better position
    I did have to heavily modify my x-member, with hindsight im not sure the ranger sump was worth the effort, but if your after a cheap solution for the sump and dont mind putting in the hours it does work
  15. #332
    Attachment 84535
    Whose maker of exhaust manifold is that Stox?
  16. #333
    Jul 2012
    cambridgeshire
    1,054
    Its alunox, im actually selling this on as i just cant get it to fit.
    With my ranger sump and the taller 2.3 it just wont go
  17. #334
    Is it the height of the engine that's the problem or is it the shape of the sump? Can't it be modified in some way or not?
    I will be looking for an Ex manifold for a 2.5 Duratec once the build eventually gets started. The engine will be dry sumped.
  18. #335
    Jul 2012
    cambridgeshire
    1,054
    I think its a combination of both, im pretty sure it can be modified to fit but im not set up to weld stainless.
    Id say it needs to sit about 2" lower as its trying to come through the bulkhead, bearing in mind that my engine should really be a little further forward, lower and tilted back a bit.
    It owes me 325 plus the long journey to collect, so ill be looking to recover £300
  19. #336
    Jul 2012
    cambridgeshire
    1,054
    I was going to try using the standard 2.0 pistons as a cheap otion for higher cr but in the end just bit the bullet buying these omega pistons from SBD, they are lovely items and only 550 delivered to my door the next working day.
    I decided to take a punt on a set of maxispeeding rods and i have to say the quality is outstanding, i even compared them to a set of molnars and theres no difference in quality and they are half the cost.
    Weighed them all and are exactly the same to 1 gram, id honestly recommend them to anybody.
  20. #337
    May 2016
    Germany
    288
    63
    I bought the speeding rods too. Just waste. The edges were to sharp which can cause damages. Also the Rod eye were drilled too small. Never get this refunded. Worst customer Service ever! At the end I bought a set of K1 rods.
  21. #338
    Jul 2012
    cambridgeshire
    1,054
    Thats really interesting, mine are spot on.
    I had read a few bad reviews including their customer service but gave it a shot and it paid off i guess
    Im quite interested in how the sharp edges cause damage, Do you mean like rough casting marks?
  22. #339
    3,641
    Sharp edges cause stress concentration points, smoothing reduces the point load path which will reduce fatigue. same as you would drill a round hole at the end of a crack to stop propagation
  23. #340
    Jul 2012
    cambridgeshire
    1,054
    Ahh i see
  24. #341
    For most peoples application the chinese Rods will posibly do the job, but so will std production ones unless your engine's going to be used for constant high revs for prolonged lenghts of time.
    Like alot of things the quality of the rod material can't be spotted by the naked eye. One of my main concerns would be, are they going to be turned into jelly through fatigue due to high power and revs. A broken con rod is never a pretty sight.
  25. #342
    Jul 2012
    cambridgeshire
    1,054
    Yeah mine is only a weekend road car, wont be used competitively.
    Wont be revved hard often but just wanted a bottom end that could safely take 250ish bhp
    The standard 2.3 mazda rods were shocking, rough raised casting marks and sharp edges everywhere, strangely the 2.0 ford rods were much better.
  26. #343
    You should be okay then.
    If your 2.5 engine's built for torque then there's no reason why you could n't use a 3.0-1 diff. You should be able to drive it more in the torque band much like you would with a Diesel engine.
  27. #344
    I bought a wrecked duratec for fitting up (head was great). It broke rod 1 through i assume oil starvation (locked up maybe). It wrecked everything crank, rod, holes in the block. They seem to suffer from bottom end knock and rods are known to be weak. Anything must be better than standard.
    Check your rods have the right bolts there was a big thing about imitation AP rod bolts.
  28. #345
    Jul 2012
    cambridgeshire
    1,054
    The bolts look very good quality, almost identical to the molnar ones but a shallower head.
    Molnar are 'approved' on ARP's website, but didnt see maxpeeding on there 🤣
    I very much doubt there genuine but not sure how i'd check for sure
  29. #346
    3,641
    They were being supplied with fake ARP's a while back, they look indentical, for 250Hp you should fit good known quality rods.....could be an expensive mistake for the sake of saving a few £100. Only way you could check would be through destructive testing to determine their tensile strength
  30. #347
    Spanner Monkey SimonD's Avatar
    South East Kent
    230
    22
    Great thread so far mate, you have come along way with the car.
    My two pennies worth regarding the conrods, I would look at using something better tested (like Manley or even Arrow if the budget will allows) especially considering the higher stress on the conrods due to the longer stroke of the 2.3. It's also well worth fitting an cylinder head oil restrictor to stop the cylinder head filling with oil and losing oil pressure to the mains and big ends.
  31. #348
    South East Kent
    230
    22
  32. #349
    South East Kent
    230
    22
    Morning,
    Not sure if you have seen this document but its well worth following the relevant parts when it comes to building your engine up 5tox, especially the pages on de-burring journal edges and opening up the oil return drains in the cylinder block.
    Cosworth / Caterham CSR260 Engine Build Manual.pdf
  33. The Following User Says Thank You to SimonD For This Useful Post:
  34. #350
    3,242
    Nice - attention to detail bible. General build Info can no doubt be carried across to many engine builds.
  35. #351
    3,242
  36. #352
    2,659
    268
    I thought much the same tbh
  37. #353
    Jul 2012
    cambridgeshire
    1,054
    Quote Originally Posted by SimonD View Post
    Morning,
    That manual is fantastic!!
  38. #354
    I've used that manual for more than one Duratec engine build lots of useful info
  39. #355
    Jul 2012
    cambridgeshire
    1,054
    Bought some nice powder coated after market bumper brackets and a new stainless bolt set off ebay, problem is that the nylon spacers are too short, do the bolts need doing up tighter to pull both sides in or do i need to buy or make longer spacers?
    My boot lid also sits on the piss one side, the tension bars are on the same adjustment catch both sides so can't work it out.
    Chopped out a section for my lower rad panel, just needs welding in, will hopefully source my rad soon from ralloy, not a bad looking thing for £300
  40. #356
    Jul 2012
    cambridgeshire
    1,054
    Best xmas present ever, my girlfriend did me an oil painting of my car finished, even got my number plate
  41. #357
    Jul 2012
    cambridgeshire
    1,054
    Made up a number plate bracket, still not sure if i like it but theres just nowhere to stick the number plate without ruining the look
  42. #358
    This is my rear bumper spacer
  43. The Following User Says Thank You to wildo105e For This Useful Post:
  44. #359
    South East Kent
    230
    22
    Hi 5tox,
    Any update on your car mate?
  45. #360
    Feb 2020
    Leicestershire
    30
    9
    Wow, proper project!
