Results 41 to 80 of 101
Thread: Sunbeam Tarmac Rally Car
  1. #41
    Apr 2008
    Telford
    64
    134
    Re: Sunbeam Tarmac Rally Car
    Quote Originally Posted by patby View Post
    5 years since my last post but I am looking at your thread with interest . Have my own Sunbeam in the garage needing lots of work and you are giving me an idea of what needs to be done to it.
    Please keep reporting your progress as even if I dont comment I enjoy watching your progress.
    When you do work on it, Definatly get a spit, All this would be a nightmare without it.
  2. #42
    Apr 2008
    Telford
    64
    134
    As I am working stupid hours this week and cannot get in the garage I thought I would post some back pictures of the rear end developement.
    I knew from the start I wanted to run a better axle than the std Lotus item and the Atlas from a Cortina with the lugs on the top gave the idea replacement. All the options of CWP and Fully Floating made it the natural choice. I have already posted pictures of that but how to mount it was going to be a challenge.
    Where to place the Turrets (having never done it before was an interesting challenge). I asked about but no-one could tell me how to determin where to mount them. In the end I made it up at what I thought was logical (Looks right now so, fingeres crossed when I drive it first time). Basically I put the axle on stands, took out the rear window and drew a virtical line, up both sides with a spirit level, from the center of the drive shaft. Then placed a piece of wood across the whole width of the car and dropped a plumb line down to the inner arch to find the middle of the turret. I used modified Escort turrets.
    Click image for larger version Name:	Shell 18.jpg Views:	964 Size:	32.3 KB ID:	65828 Click image for larger version Name:	Shell 15.jpg Views:	965 Size:	36.0 KB ID:	65827
    Click image for larger version Name:	Shell 16.jpg Views:	968 Size:	37.3 KB ID:	65830 Click image for larger version Name:	Shell 21.jpg Views:	969 Size:	24.7 KB ID:	65829
    I had aleady cut most of the boot away which made it easier to see. (the old axle looks a bit tired).
    I then bought the plasma cutter and what a difference. This shows the axle in place with all the new linkages.
    Click image for larger version Name:	Shell 24.JPG Views:	968 Size:	41.5 KB ID:	65831 Click image for larger version Name:	Shell 25.JPG Views:	967 Size:	39.5 KB ID:	65832
    Click image for larger version Name:	Shell 26.JPG Views:	964 Size:	39.7 KB ID:	65833
    Obviously the big whole where the boot was would be an issue, a bit noisey and cold to drive. I wanted to mount an internal tank and stiffen up the back end, so built the frame to weld in. Few things to notice, The down legs are extended an extra 15mm to mount a tank guard, I fitted a threaded bar to add a tow hook and manufactured weld in spacers to fill the box section for mounting a redesigned bumper hanger.
    Click image for larger version Name:	Shell 33.JPG Views:	963 Size:	34.8 KB ID:	65834 Click image for larger version Name:	Shell 34.JPG Views:	962 Size:	33.1 KB ID:	65835
    Click image for larger version Name:	Shell 37.JPG Views:	958 Size:	33.3 KB ID:	65836 Click image for larger version Name:	Shell 38.JPG Views:	956 Size:	33.7 KB ID:	65837
    Click image for larger version Name:	Shell 43.JPG Views:	955 Size:	33.0 KB ID:	65838
    Looks good with the Guard on and nice and strong.
    As with all development there is the odd issue... The back of the axle was way to close to the front of the tank guard and the diff cover wasnt on yet. I had to take it out and modify the tank enclosure by moving the centre guard stay internal of the tank frame. It gives me an extra 25mm of clearance.
    Click image for larger version Name:	Shell 45.JPG Views:	955 Size:	26.0 KB ID:	65839 Click image for larger version Name:	Shell 46.JPG Views:	955 Size:	36.9 KB ID:	65840
    Click image for larger version Name:	Shell 159.JPG Views:	954 Size:	24.8 KB ID:	65841
  3. #43
    Apr 2008
    Telford
    64
    134
    You will notice a safety devices Roll cage in one of the pictures above. I have used the removable diagonal cross section for make the brace between the turrets but have decided to build my own cage. Therefore I am gonna sell on the cage. I can easilly manufacture a new diagonal for it. If anyone is interested or knows anyone who is PM me please. Guess in the end when the time comes if I have not sold it then it will go on E-Bay..
  4. #44
    Jul 2012
    Ireland
    Keep up the good work... I'm reading away at your posts.... My own sunbeam build feels like its in high reverse... Good to see somebody getting somewhere!!!
  5. #45
    Apr 2008
    Telford
    64
    134
    Hi, Been a week or two of work and no chance to get in the garage, and therefore no progress.
    Had plans of a full day on the car today but things seem to have been stacked against me. Got all prepped up to carry of with the wheel arch and found I had run out of Gas....... So plan 2 make a part I have been planning for a while, (not needed yet but I have the bits in so......), meant using my mini lathe, buy I had to fix it first. Almost said sod it and worked on the house, but I dont get enough time in the garage and I was not gonna waste the day. Took a couple of hours to manufacture the parts to fix the lathe. Its only a model lathe but suprisingly useful.
    I contacted Cossymax from on here a while ago. He recently built a Sunbeam with an S2000 engine in it (interesting thread on here). I saw a part on his radiator that I needed and was interested where I could get one. Unfortunatly it was a one off part he had made and was not a stock item anywhere. I need to connect the inlet manifold coolant breather to something or blank it off.
    I have had the radiator a couple of years. I think it was a return (I assume because they put the lower hose connection in the wrong place) cos I got it for a song and is ideal for me.
    Click image for larger version Name:	IMG_7725.JPG Views:	871 Size:	32.4 KB ID:	65972 Click image for larger version Name:	IMG_7727.JPG Views:	871 Size:	32.1 KB ID:	65973
    The Fan switch is a standard part with a 22mm x 1.5mm pitch. It's this area I needed to make a part for. I bought a lump of alloy hex bar from E-Bay and a couple of taps and made this:
    Click image for larger version Name:	IMG_7728.JPG Views:	868 Size:	29.3 KB ID:	65974 Click image for larger version Name:	IMG_7729.JPG Views:	866 Size:	33.2 KB ID:	65975
    Click image for larger version Name:	IMG_7731.JPG Views:	865 Size:	33.6 KB ID:	65976 Click image for larger version Name:	IMG_7732.JPG Views:	868 Size:	30.6 KB ID:	65977
    Click image for larger version Name:	IMG_7737.JPG Views:	866 Size:	26.5 KB ID:	65978 Click image for larger version Name:	IMG_7738.JPG Views:	867 Size:	27.5 KB ID:	65979
    Click image for larger version Name:	IMG_7739.JPG Views:	865 Size:	27.8 KB ID:	65980 Click image for larger version Name:	IMG_7740.JPG Views:	865 Size:	40.0 KB ID:	65981
    The 2 brass fittings are for this unit and the inlet manifold, Unfortunatly the 1/8th NPT tap has not arrived yet. But here is is fitted.
    Click image for larger version Name:	IMG_7741.JPG Views:	863 Size:	29.2 KB ID:	65982
  6. #46
    Jun 2009
    ireland
    36
    cousin rallys a sunbeam in ireland
  7. #47
    Spanner Monkey escortmad1's Avatar
    Oct 2011
    North Ireland
    366
    Who's that?
  8. #48
    Apr 2008
    Telford
    64
    134
    I did my BARs test in an escort but have only ever rallied a Sunbeam. Understand why the escort is loved so much but Sunbeams are just a little bit different. Just as much fun though. Just a shame the spares are not as easy to get.
  9. #49
    Apr 2008
    Telford
    64
    134
    Hmmmm...... Day in the garage working on the car or big coat and off to Wales for WalesrallyGB .......??????
  10. #50
    Oct 2011
    North Ireland
    366
    WalesGB sounds there's a real buzz at it on wrc.live.com
  11. #51
    Apr 2008
    Telford
    64
    134
    Well......, I decided, the lady of the house drags me Xmas shopping and makes me suffer soaps on the TV, so I feel its payback time. The upshot is I had a couple of hours in the garage today and tomorrow morning I will drag her kicking and screaming into a welsh forrest for the WalesRallyGB.
    Anyway I wanted to crack on with the O/S/Rear wheel arch but it was not as easy as I thought it would be. Ended making strips to weld in so I could get the shape right. Then made a cardboard former for the new inner arch. I ran out of time to be able to weld it in but at its all prepped now,
    Click image for larger version Name:	Shell 211.jpg Views:	757 Size:	25.0 KB ID:	66214 Click image for larger version Name:	Shell 212.jpg Views:	756 Size:	22.9 KB ID:	66215
    Click image for larger version Name:	Shell 213.jpg Views:	760 Size:	28.1 KB ID:	66216 Click image for larger version Name:	Shell 214.jpg Views:	758 Size:	26.4 KB ID:	66217
    Click image for larger version Name:	Shell 215.jpg Views:	757 Size:	26.4 KB ID:	66218
  12. #52
    Mar 2006
    In the garage getting cold
    1,448
    31
    Great project you got yourself and makes a very interesting read , well done on all your work so far and look forward to more updates
  13. The Following User Says Thank You to 105Ian For This Useful Post:
  14. #53
    Apr 2008
    Telford
    64
    134
    What a cracking day and hat's off to my lovely lady who got wet, cold and hungry and didn't whine once, even when her boots fell apart and her feet got soaked.
    Thats why I love that lady.. She enjoyed the day but OMG.... WRC cars are so fast but what a mess they make of the stages. Here's a few pictures from the day..
    Click image for larger version Name:	IMG_7744.JPG Views:	733 Size:	38.1 KB ID:	66266 Click image for larger version Name:	IMG_7748.JPG Views:	732 Size:	39.6 KB ID:	66267
    Click image for larger version Name:	IMG_7756.JPG Views:	733 Size:	39.5 KB ID:	66268
    Excellent day. Not that I needed motivation to get the Sunbeam done. Just wish I had a kind benefactor to help with the finances.
  15. #54
    Apr 2008
    Telford
    64
    134
    During the week the 1/8th NPT tap arrived so I finnished off the Radiator mod and took the inlet manifold off to tap that. No picture I'm afraid of that. Cracked on with the rear though, cutting a hole in the new rear panel then using a joggling tool to recess a plate. Drilled a few holes and bolted them back together before welding the nuts to the back.
    Click image for larger version Name:	Shell 217.jpg Views:	702 Size:	10.8 KB ID:	66345 Click image for larger version Name:	Shell 218.jpg Views:	702 Size:	8.5 KB ID:	66346
    Click image for larger version Name:	Shell 219.jpg Views:	700 Size:	10.7 KB ID:	66347 Click image for larger version Name:	Shell 220.jpg Views:	701 Size:	9.2 KB ID:	66348
    Got carried away then and started framing up the rear tank enclosure..
    Click image for larger version Name:	Shell 222.jpg Views:	703 Size:	26.1 KB ID:	66349 Click image for larger version Name:	Shell 223.jpg Views:	701 Size:	27.9 KB ID:	66350
    Click image for larger version Name:	Shell 224.jpg Views:	700 Size:	22.8 KB ID:	66351 Click image for larger version Name:	Shell 225.jpg Views:	698 Size:	24.2 KB ID:	66352
  16. #55
    Nov 2013
    Tubbercurry , Sligo
    very interesting and good work being done .your giving me a lot of ideas to do to my sunbeam. keep the pic and info coming
  17. #56
    Apr 2008
    Telford
    64
    134
    Glad your enjoying it. The only frustrating thing is the slow pace, but I guess that's the price of doing it alone. I am learning loads as I go but really look forward to when all the mods and fabrication are complete and I paint it. Then I can start putting all the shiny bits I have been collecting for years on. I do very much appreciate the comments though. Thank you
  18. #57
    Nov 2008
    Adelaide, Australia
    1,331
    96
    I love the old sunbeam. Last one I saw was shortly before leaving the mother country for Australia. They are totally unheard of over here loving the build. I'm not posting much but Def looking at every post!
  19. The Following User Says Thank You to MK1_Oz For This Useful Post:
  20. #58
    Apr 2008
    Telford
    64
    134
    The advantages of having 2 sons and 2 daughters is the girls think about clothes and shoes for me for xmas and the boys just say "what do you want dad". Well today I picked up the pressies from my boys and before they take them away to be wrapped I just had to pre fit one of them...
    Click image for larger version Name:	Shell 230.jpg Views:	641 Size:	28.2 KB ID:	66641 Click image for larger version Name:	Shell 228.jpg Views:	640 Size:	23.0 KB ID:	66640
    Click image for larger version Name:	Shell 231.jpg Views:	640 Size:	27.8 KB ID:	66642 Click image for larger version Name:	Shell 232.jpg Views:	639 Size:	24.8 KB ID:	66643
    There will be two of these hanging out the back. One either side of the tank. Just looking at the one I can tell its gonna look really nice and shoud sound sweet.
  21. #59
    Apr 2008
    Telford
    64
    134
    As it turns out Cobra Seats happens to be based 6 miles from my house. Every year they have a factory sale. I told the wife-to-be that I would just pop down and see what they have and what kind of saving there is...... Well
    Click image for larger version Name:	Seat01.jpg Views:	625 Size:	28.2 KB ID:	66683 Click image for larger version Name:	Seat02.jpg Views:	624 Size:	26.5 KB ID:	66684
    As this is my kitchen and not the factory......... they sorta fell into my car dear.
    Thankfully she's very understanding and offered to give me some pennies towards them and they can be my Xmas pressie. WHAT A DARLING
  22. #60
    Nov 2008
    Adelaide, Australia
    1,331
    96
    wow a real keeper!!!!
  23. #61
    Apr 2008
    Telford
    64
    134
    As I said two back boxes so here's the view. Looks the Bollocks....
    Click image for larger version Name:	Shell 234.jpg Views:	604 Size:	26.6 KB ID:	66723 Click image for larger version Name:	Shell 233.jpg Views:	604 Size:	28.7 KB ID:	66722
    Can't wait to hear them......
  24. #62
    Apr 2008
    Telford
    64
    134
    Managed a couple of hours today but unlikely to get many more for a week or two. Took the silencers off to give to my boys to wrap up and find under the tree on the 25th. Drilled a few holes, for the power cable and tank breather and finished of the right shelf welding. Then made a battery brace:
    Click image for larger version Name:	Shell 235.jpg Views:	567 Size:	24.1 KB ID:	66822 Click image for larger version Name:	Shell 236.jpg Views:	565 Size:	25.1 KB ID:	66823
    Click image for larger version Name:	Shell 237.jpg Views:	566 Size:	23.2 KB ID:	66824 Click image for larger version Name:	Shell 238.jpg Views:	565 Size:	23.9 KB ID:	66825
    Click image for larger version Name:	Shell 239.jpg Views:	563 Size:	26.3 KB ID:	66826
    The back of the car is coming together nicely now. Few more jobs and I can start working forward.
  25. #63
    Apr 2008
    Telford
    64
    134
    Managed another few hours today and cracked on with the back. Somehow my welding seems to have gone to shit. Had to walk away in the end, thank god for the grinder and joint sealer.
    Geeting there though:
    Click image for larger version Name:	Shell 240.jpg Views:	516 Size:	22.8 KB ID:	66995 Click image for larger version Name:	Shell 241.jpg Views:	514 Size:	21.6 KB ID:	66996
    Click image for larger version Name:	Shell 242.jpg Views:	515 Size:	28.1 KB ID:	66997 Click image for larger version Name:	Shell 243.jpg Views:	514 Size:	26.0 KB ID:	66998
    Click image for larger version Name:	Shell 244.jpg Views:	514 Size:	26.1 KB ID:	66999 Click image for larger version Name:	Shell 245.jpg Views:	515 Size:	29.6 KB ID:	67000
  26. #64
    Jan 2009
    Bristol
    187
    Loving the thread, keep plodding on.
  27. The Following User Says Thank You to Dr Dub For This Useful Post:
  28. #65
    Apr 2008
    Telford
    64
    134
    Just been reading through some threads on here and looking with envious eye's on the amount of new perfect panel's available for escorts. Basically everything available to make a completely new shell. I wish there was as many parts available for Sunbeam's that didn't involve me having to remortgage the house to get them. The upside I guess is oh yeh.... My fabrication skills are improving.
    Seasons greetings all and looking forward to more fun in 2014. Hope you all have a good one.
  29. #66
    You are doing a marvelous Job of the Sunbeam, its far more rewarding seeing your own fabrication work than just going out and buying everything.
    Was that your Sunbeam that Rolled on a 90 left in Clipstone on the 2012 Premier Rally?
  30. #67
    Apr 2008
    Telford
    64
    134
    Hi. No not me.... Unfortunately I haven't been behind the wheel of a rally car for 7 years. It's been a long recovery from my divorce. Hoping 2014 see's DAC19Y being MOT'd and testing to do some events in 2015. Just at the moment seem to spend my life fabricating and welding.
  31. #68
    Apr 2008
    Telford
    64
    134
    I was planning on spending a lot of time over the Christmas period in the garage but unfortunately my lovely ladies father is seriously ill. Family has to (and will always) be priority. Soon as I can I will crack on and continue to post my progress.
  32. #69
    Feb 2009
    Yorkshire
    286
    10
    Kevin have a look at my old beam consul think it cost about 20 to make I mite still even have the templates
  33. #70
    Apr 2008
    Telford
    64
    134
    Looks interesting. I am really looking for a carbon fibre one that fits a bit more of an angle though. However appreciate the idea.
  34. #71
    Apr 2014
    cornwall
    11
    Hi mate, making a great read. Found some of the info here really helpful. Can i ask where you got your engine mounts for the c20xe from? also i see you used envirostrip, would you recommend these? thanks
    adam
  35. #72
    Jun 2013
    Nottingham
    222
    11
    Loving the car mate, bringing back some memory's from the 80's for me
  36. #73
    Apr 2008
    Telford
    64
    134
    Quote Originally Posted by adamh6599 View Post
    adam
    Hi. Sorry been a while since any updates. My personal life has taken all my time since before Christmas with the loss of my farther in law (a great man I miss dearly) and my own wedding and honeymoon. Life only started to return to normal when I went back to work Monday.
    So to answer your questions. Yes I fabricated my own engine mounts on the first car but have bought chassis mounting kit for this car. They are readily available from most suppliers just do a net search for c20xe rwd engine mounts.
    As for enviro-strip. They are in my top 5 of companies I will go out of my way to promote. I cannot speak highly enough of them and will recommend them to anyone looking for this service. Cannot remember he guy's name but I have it written somewhere in the car records if needed.
    Hope you get on well with your car. Always interested if you start a post on it. Nice to see others endeavors.
    Kev
    The difference between men and boys... is the price of their toys!!!!
  37. The Following User Says Thank You to rallysunbeam For This Useful Post:
  38. #74
    Oct 2010
    south wales
    12
    Stunning work.
  39. The Following User Says Thank You to gurnsimps For This Useful Post:
  40. #75
    Apr 2008
    Telford
    64
    134
    Been a while since I have shared any pictures of the build so thought I would add these. My design & build yourself Stainless exhaust system... Hope you like??
    Click image for larger version Name:	IMG_1413.JPG Views:	212 Size:	27.4 KB ID:	72416
    Click image for larger version Name:	IMG_1414.JPG Views:	212 Size:	31.0 KB ID:	72417
  41. #76
    Apr 2008
    Telford
    64
    134
    this is the front section. I am looking forward the mocking up and building the manifold. Hopefully it will be under the noise limit in the regs!!!!!
    Click image for larger version Name:	IMG_1372.JPG Views:	212 Size:	24.9 KB ID:	72418
    Click image for larger version Name:	IMG_1407.JPG Views:	212 Size:	28.4 KB ID:	72419
  42. #77
    May 2013
    Dublin
    Hello great build keep at it it will be worth it, why are you using 2 back boxes, just wondering.
  43. #78
    Apr 2008
    Telford
    64
    134
    The early works cars had 2 rear boxes. I wanted to run a large bore exhaust for future power increases ( possibly even turbo) plus I know it's a little heavier but it does look pretty swish.
  44. #79
    Apr 2008
    Telford
    64
    134
    Exhaust is finished now and has been removed and stored ready for final build. I will put the front section back on again to build the manifold when I pre-fit the engine. But for now I have moved onto something else...
  45. #80
    Apr 2008
    Telford
    64
    134
    Few pictures of the exhaust.
    Click image for larger version Name:	IMG_1453 - Web.JPG Views:	119 Size:	31.4 KB ID:	72564
    Click image for larger version Name:	IMG_1455.JPG Views:	119 Size:	32.5 KB ID:	72565
    Click image for larger version Name:	IMG_1456.JPG Views:	119 Size:	29.3 KB ID:	72566
