Page 3 of 3 FirstFirst 1 2 3
Results 81 to 101 of 101
Thread: Sunbeam Tarmac Rally Car
  1. #81
    Apr 2008
    Telford
    64
    134
    13
    Re: Sunbeam Tarmac Rally Car
    The Alluminuim box section I ordered arrived the other day and I could not resist having a play with the TIG on AC. I know I should have carried on with the shell but these are all jobs that will need doing. I made up this wheel carrier. The idea of 2 pins as stays is I am still not 100% sure 13" or 15" wheels and this system accomodates them both. Just need to put some anker points in now for the rachet straps..
    Click image for larger version Name:	IMG_1510.JPG Views:	420 Size:	19.4 KB ID:	72567
    Click image for larger version Name:	IMG_1512.JPG Views:	418 Size:	21.2 KB ID:	72568
    Click image for larger version Name:	IMG_1516.JPG Views:	417 Size:	23.7 KB ID:	72569
    The difference between men and boys... is the price of their toys!!!!
  2. #82
    Apr 2008
    Telford
    64
    134
    13
    Click image for larger version Name:	IMG_1517.JPG Views:	417 Size:	27.1 KB ID:	72572
    Sorry, this one's a bit out of focus....... taken with a phone instead of a camera
    Click image for larger version Name:	IMG_1513.JPG Views:	418 Size:	25.2 KB ID:	72570
    Click image for larger version Name:	IMG_1515.JPG Views:	418 Size:	28.0 KB ID:	72571
  3. #83
    Racer Decade Plus User mexicotait's Avatar
    Oct 2008
    whitley bay
    2,436
    89
    Nice idea
    Could you not get it lower though a heavy thing to have so high in the car
    Hexham and District Motorclub
  4. #84
    Apr 2008
    Telford
    64
    134
    13
    I could get it so the it fits flat on the rear dif tunnel but it would only work with 13" wheel and I may still go to 15" The major thing is though, where it is the whole thing comes out through the rear hatch easily. Any other position would place it lower than the rear fire wall and you would need arms like Popeye to stetch in and lift it out.... Nice thought though... Thanks.
  5. #85
    Nov 2005
    15
    Nice build. It takes me back to the days when I rallied a group A 1600 TI, forest rally entry fees were just about affordable and summers were dry and sunny (well, sometimes).
  6. The Following User Says Thank You to retrorally For This Useful Post:
  7. #86
    Apr 2008
    Telford
    64
    134
    13
    The good old days when the grass was greener, the summers were longer...... There's a song in there somewhere!!!! I long for the day I need to worry about entry fees..... Seems to be taking for ever... Life so busy I don't get enough time to really crack on..... Fingers crossed for 2015...
  8. #87
    Mechanic azz259's Avatar
    Aug 2009
    west wales
    487
    10
    just read through your build,looks brilliant and im steeling some ideas for mine if you dont mind! i like the idea of closing in the fuel tank, i need to either do the same or find a way to fit a pump in the original tank to run efi. what tank will you be using and what will seal the lid you will have on top? cheers Arwyn
  9. #88
    Apr 2008
    Telford
    64
    134
    13
    The tank came from Alloy Racing Fabrication, which was one of their standard parts. I just asked them to weld on AN12 fittings.... The top to the enclosure is metal with a hinged lid to fill the tank through. I'll put up some photoes....
    Click image for larger version Name:	Shell 251.jpg Views:	331 Size:	34.1 KB ID:	72711
    Click image for larger version Name:	Shell 253.jpg Views:	329 Size:	26.7 KB ID:	72712
    Click image for larger version Name:	Shell 255a.jpg Views:	328 Size:	23.4 KB ID:	72713
  10. #89
    Apr 2008
    Telford
    64
    134
    13
    Busy day today as I started to make the roll cage and fitted the Navigator front seat rail.
    Click image for larger version Name:	IMG_1585.JPG Views:	323 Size:	25.2 KB ID:	72718
    Making the roll cage was a nervous time. I borrowed a bender and screwed it to the decking in the garden. Started by measuring and remeasuring to draw an accurate outline of the interior of the car.
    Click image for larger version Name:	IMG_1571.JPG Views:	323 Size:	28.5 KB ID:	72716
    Set up for 1st bend... scared.
    Click image for larger version Name:	IMG_1572.JPG Views:	325 Size:	43.8 KB ID:	72717
  11. #90
    Apr 2008
    Telford
    64
    134
    13
    45 minutes later after a bit of fettling I had the mail loop done. I cut it to length and tst fitted it to the car.
    Click image for larger version Name:	IMG_1574.JPG Views:	324 Size:	41.6 KB ID:	72722
    Click image for larger version Name:	IMG_1575.JPG Views:	323 Size:	26.9 KB ID:	72723
    Click image for larger version Name:	IMG_1579.JPG Views:	322 Size:	28.6 KB ID:	72724
  12. #91
    Apr 2008
    Telford
    64
    134
    13
    I wanted to get the cage as snug as possible to the shell and I am quite please with the results. Not bad for a 1st attempt.
    Click image for larger version Name:	IMG_1580.JPG Views:	326 Size:	31.4 KB ID:	72725
    Click image for larger version Name:	IMG_1581.JPG Views:	324 Size:	30.7 KB ID:	72726
    Click image for larger version Name:	IMG_1582.JPG Views:	324 Size:	29.6 KB ID:	72727
  13. #92
    Apr 2008
    Telford
    64
    134
    13
    I made the plates for the bottom of the legs and fitted them to the platforms then tacked the legs to them. I will take the cage out to fully weld them later.
    Click image for larger version Name:	IMG_1583.JPG Views:	323 Size:	26.8 KB ID:	72728
    Click image for larger version Name:	IMG_1584.JPG Views:	320 Size:	26.0 KB ID:	72729
  14. #93
    Apr 2008
    Telford
    64
    134
    13
    Another good day in the garage. The cage is coming together nicely although trying to cut angles on pipes is a challenge. The door bar connectors work well for the cross bar that I tied into the transmission tunnel. Looks like it will be another week before I can do anymore cos work summons....
  15. #94
    Aug 2012
    North east
    14
    Great read, and some great fabrication work.
  16. The Following User Says Thank You to Adam151082 For This Useful Post:
  17. #95
    Apr 2008
    Telford
    64
    134
    13
    some pictures from today..
    Click image for larger version Name:	IMG_1592.JPG Views:	295 Size:	34.6 KB ID:	72747
    Click image for larger version Name:	IMG_1593.JPG Views:	295 Size:	33.0 KB ID:	72748
    Click image for larger version Name:	IMG_1594.JPG Views:	294 Size:	25.1 KB ID:	72749
  18. #96
    Jun 2014
    cavan ireland
    26
    serious work happening here mate.. u must be delighted so far. its very hard to get the time I know.. my project took 8 years. car is one the road but still things to do
  19. #97
    Jan 2009
    Bristol
    187
    Keep it coming buddy !.
  20. #98
    Apr 2008
    Telford
    64
    134
    13
    Thanks guy's. yes pleased with the way it's coming out but time is hard to come by at the moment... I have set myself the target of doing an event at the end of next year. The thing is with this is, it seems to be going on and on and on etc etc...... But the good news is, with all the prep work being at this stage, when its finally in paint the build should be reasonably quick. Just like everything the quality of the end product is all down to the prep. Thanks for the support, it does help....
  21. #99
    Apr 2008
    Telford
    64
    134
    13
  22. #100
    Apr 2014
    cornwall
    11
    Keep it coming mate, I read the whole thing again as its given me some good idea's for my sunbeam. mine is still a long way away and a new garage build is sucking all my money, but the car will be right next to my house then so hopefully some more time will be spent on it.
  23. #101
    Apr 2008
    Telford
    64
    134
    13
    Just found this thread from when I first started my build. Things have moved on a lot but unfortunately I am unable to say it's finnishe. I continued the build on using face book to let people follow the progress.. if you would like to find it just search for "Talbot Sunbeam Rally car" and you'll see a picture of the car as standard.
    Pictures to big to attach
