im kinda stuck on a few bits so started plumbing the engine bay and getting the holes drilled for the cooler header tank that kinda stuff
and man unless you have all the bits its a long job.
Any pics on Turbosport??
im on facebook with images ,as I use photobucket on here to upload and it has viruses all over it at the mo.
will start my build thread soon as im well over mid point.
More holes to patch up, There cant be many more Tin worm holes... Chassis seam welded, Skid plates getting attached... come on!!!!!
IMG_1925.jpgOld [ATTACH=CONFIG]67028[/ATTACH
Hydraulic clutch recess has been removed and tidied up before / After pic... Cheers Paul it was an eyesore!!
IMG_1965.jpgIMG_1966.jpgIMG_1967.jpgIMG_1968.jpgIMG_1969.jpgIMG_1970.jpgIMG_1971.jpgIMG_1972.jpgIMG_1973.jpgIMG_1974.jpg
Skid plates are all finished... & more corrosion damage to fix... HAPPY NEW YEAR SWAN AVO..!!
Im thinking of going standard blue for the cosworth cam cover can anyone reccommend where to buy a quality refurbished one from?
or where I can get mine refurbished at?
my yb cam cover is a mauve blue?
I might have one of those knocking around somewhere
starting to dry fit parts making sure theres no issues before It gets painted
thats the same colour as my cam cover, my turbo is bigger though
IMG_2002.jpgIMG_2003.jpgIMG_2004.jpgIMG_2005.jpgGearlever in the right position beading will look the part when its painted and add the extra strength into the panel..
the cam cover ? mines is same co lour, does the colours mean owt? yer car looks gud BTW
the colour means I made an error in powder coating it in the only blue the powder coaters had... I want it original blue..
Looking good
9.7 @ 143 mph http://www.youtube.com/watch?v=kF1Ep...feature=relmfu
IMG_2031.jpgIMG_2032.jpgIMG_2033.jpgIMG_2034.jpgIMG_2035.jpgIMG_2036.jpgIMG_2037.jpgIMG_2038.jpgIMG_2039.jpgIMG_2040.jpgIMG_2041.jpgIMG_2042.jpgIMG_2043.jpg Rix sump guard need some modifications because of the big winged sump... Why isn't anything easy with these?
IMG_2046.jpgIMG_2047.jpgIMG_2048.jpgIMG_2049.jpgexhaust tunnel marked out, let the cutting begin
Exhaust tunnel is coming along nicely...
HELP!!!!!!!!!!!
Just bought what was supposed to be a "Billet" plenum turns out to be a welded aluminium one? are these safe does the plenum hold much pressure?
Looking good there fella credit to you well done!
Coming along nicely
IMG_2073.jpgIMG_2074.jpgIMG_2076.jpgIMG_2077.jpgIMG_2078.jpgIMG_2079.jpgIMG_2084.jpgIMG_2085.jpgIMG_2086.jpgIMG_2087.jpg
Exhaust tunnel finished to accommodate a stainless 2 1/2" system might have to buy some heat reflective material to go on the tunnel.
can anyone recommend any???? PLEASE....
I'm not hating here mate ... BUT if the cars YB powered it isn't going to be getting used for rallying so why the need for a maaaaasive sump guard :/ just masses of extra weight isnt it??
John, I get your point but its only going to be used for the odd track day/ fair weather road use however where I live theres hundreds of speed bumps in every other street so I'd rather cope with the extra aluminium weight to protect my investment in the engine..
stone guard arrived today, what a great quality product im well impressed with it ...
more holes to be filled in
arches marked up to be re profiled, to take away the blind woodcutter look lol I want this car done right..!!
IMG_2117.jpg boxing in the tops of the rear turrets
Mocking up the exhaust system going with one oval back box side entry so its easier to angle towards the tunnel
It will be a full stainless system though..
Wouldn't trust that plenum, anembo make billet ones , car looks ace coming on well
BOB'S almost finished with the fabrication side of things Hillman IMP sidelights fitted...hopefully the Stainless exhaust will arrive Friday to dry fit, Car needs a torch test to check for unwanted holes.. but could be ready for paint in a week I hope
Don't know how much , give Greg a call at anembo engineering , he will sort ya, he's sold a fair few
Here another pic
