As title really, we have had a run of castings made which are basically a direct copy of the original Opel Manta 1800 cast alloy rwd winged sumps, as they were getting hard to get hold of and fetching crazy money in damaged, used condition.
These are brand new castings, and will work in any rwd xe application with the engine at 7 degrees (will work upright but sump is then at an angle)
It fits an escort perfectly as I have used them in this application in our in-house builds.
If you are in Ireland, Group 4 Fabrications are also stocking these. (as are SBD over here too)
They are priced at £175 + vat (so £210) plus carriage, which is normally £10
We also do an exchange pickup pipe mod service to alter the stock 16v pipe to suit this sump, and also stock the gaskets and bolts and sump plugs to fit them
The sump plug threads are helicoiled as standard to avoid stripped threads
