Page 7 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 241 to 280 of 367
Thread: Pipes pinto :)
  1. #241
    Re: Pipes pinto :)
    Maybe we need to start talking if you fancy it??...........
    why not?
    are you still running the emerald or have you gone onto something new?
  2. #242
    Re: Pipes pinto :)
    after matching the inlet manifold to the head i got a bit of a surprise
    the jenvey manifold is really nice and seals with o rings, BUT doesnt suit a head with big ports, opening the manifold up to match the head has broken into the o ring grooves.
    fortunatly theres just enough thickness to the mounting flange to machine the grove out.
    at this point i am undecided which way to go, i could machine up a plate like a sidedraft carb has with a o ring groove in each side to carry new o rings, or simply open a gasket out a bit and use a gasket and sealant. theres not a lot of material left to seal with, but there shoudl be enough, at least on injection if it develops an air leak the worst that will happen is a bad idle, no danger of a lean mixture like it woudl get on carbs
  3. #243
    Re: Pipes pinto :)
    you might of noticed my milling machine has got much much bigger, my sealey mill has been replaced with a lovely Bridgeport. many thanks to Andy pipe and crew for dealing with the scarey 3 phase electrics for me
  4. #244
    Re: Pipes pinto :)
    at the moment im defiantly errring on the side of using a gasket rather than faffing around making misabs.
    with that in mind i ran a fly cutter across the manifold face of the head to give a better surface to seal against, just for good measure i did the exhaust face too. nothing earth shattering, but a nice touch. its not something i usually have done, but thats simply a case of economics, when i had to subcontact it out it was hard to justify the cost
  5. #245
    2,659
    268
    Re: Pipes pinto :)
    Shame about the manifold breaking out like that.
    I like the Milling machine, it certainly looks good.
    Those inlet ports look Huuuuge !!!!
  6. #246
    Re: Pipes pinto :)
    they are, but thats mainly down to me lifting the ports up, i refuse to use port filler, because sooner or later it does come out
  7. #247
    2,659
    268
    Re: Pipes pinto :)
    Did that start off as an injection head then, or a carbed head?
    Dont suppose it makes any difference if you're going to do that to it does it...
  8. #248
    Re: Pipes pinto :)
    carb, because its a 1600 head
  9. #249
    2,659
    268
    Re: Pipes pinto :)
    Oh ok... Have they got a smaller combustion chamber than a 2.0ltr?
  10. #250
    Re: Pipes pinto :)
    yes iirc 1600 is 38cc 2.0 being 49/50cc
  11. #251
    Jun 2015
    Australia
    295
    Re: Pipes pinto :)
    Hi graham whats the size of the port entry it looks huge cheerd mario.
  12. #252
    Re: Pipes pinto :)
    Quote Originally Posted by mariors2000 View Post
    too big! they are only that size because i have lifted them up and the original inlet manifold had big ports!
    in all honesty i dont know ive never measured them as such, and right now the head is 100miles away
  13. #253
    2,659
    268
    Re: Pipes pinto :)
    What's the basic advantage of using the 1600 head then Graham, is it the smaller combustion chamber?
    Does a it give a more concentrated burn or something, I don't know I'm just guessing
    Can you still get the same large size valves in it then? I know you you're going offsetting for larger than normal big valves.
  14. #254
    Re: Pipes pinto :)
    means you dont have to skim the head to death to get compression, but also theres more material in the short turn. before the injection head came along all the really quick pintos had 1600 heads
  15. #255
    2,659
    268
    Re: Pipes pinto :)
    Oh ok. I did wonder if it was also something to do with not having to skim it as much for compression...
  16. #256
    Mar 2003
    Now over the pond North side
    3,540
    Re: Pipes pinto :)
    why not?
    If that's the case, maybe you need to start spending my pension for me
    I'm trying to run a new Emerald K6. I did have some problems with it at the end of last year and so far I haven't had the time (more like I haven't got off my fat backside) to look at it!
    How do you go about matching the inlet manifold to the head Graham? I don't know if you remember but I got one of the HT straight inlet manifolds for mine.
    Dazzle
  17. #257
    Re: Pipes pinto :)
    spending money is no problem
    if you order the K6 through me at work, i will give you more discount than emerald will im pretty sure you wont pay vat.
    matching manifolds is done a couple of ways on Andys new one i literally bolted the manifold and head together and because the manifold was smaller and soft alloy my die grinder opened it up to match the head without making the head port bigger. normally you just match them to the gasket, so thats what i would probably do open teh head up to match an inlet gasket, you didnt have the HT manifold when yours was built so its not matched to that anyway
  18. #258
    Re: Pipes pinto :)
    had a bit of a play today, trial assembly of the head shows ive gained some more inlet lift, not a lot, but an extra 10 thou is worth having, especially remembering there will be slightly more lift right through the range.
    i was a bit concerned that moving the valve over may give issues with the follower wiping off teh edge of teh valve stem/ follower, but thats clearly not the case, well at least not with the newman followers im using. if i were starting agin with a fresh head i would defiantly move the valve over a bit further
  19. The Following User Says Thank You to Graham For This Useful Post:
  20. #259
    Bodger Duffer's Avatar
    Jan 2014
    West Sussex
    198
    27
    Re: Pipes pinto :)
    What about machining the o-ring groves into the head instead of the manifold, looks like you have more room to play with there?
  21. #260
    Re: Pipes pinto :)
    Quote Originally Posted by Duffer View Post
    yes i have thought about doing that. a rienze inlet gasket will just about seal also, another possibility is just to use sealant. as its injected if it did develop an air leak it wont overly effect it unlike carbs
  22. The Following User Says Thank You to Graham For This Useful Post:
  23. #261
    Racer Decade Plus User andypipe's Avatar
    Jan 2003
    Harlow/Walthamstow
    3,104
    Re: Pipes pinto :)
    just caught up with all this as i have been busy building a business.
    Great job you are doing graham
    www.snaglets.com
  24. #262
    Mar 2003
    3,540
    Re: Pipes pinto :)
    Quaife QBE89G In-Line 7-Speed Sequential Gearbox
    Andy, really considering getting one of these, what are your thoughts on it or anyone else running one??
    Dazzle
  25. #263
    Jan 2003
    Harlow/Walthamstow
    3,104
    Re: Pipes pinto :)
    Best thing i ever did. wouldnt have one in a road car though
    www.snaglets.com
  26. #264
    Mar 2003
    3,540
    Re: Pipes pinto :)
    Quote Originally Posted by andypipe View Post
    Could you expand on the reason for not wanting one in a road car please?
    For me it would predominantly be a track car.
    Dazzle
  27. #265
    3,641
    Re: Pipes pinto :)
    Straight cut dog box, clunky and noisy. Semi helical BGH type box best for a road car
  28. #266
    Mar 2003
    3,540
    Re: Pipes pinto :)
    Thanks for your reply, appreciate that but I was already running a 26z sequential straight cut so well aware of what it's like.
    I was asking Andy why he said what he said
    Dazzle
  29. #267
    Jan 2003
    Harlow/Walthamstow
    3,104
    Re: Pipes pinto :)
    As above, it is a straight cut dog box and you have to be brutal with it. also a pain in the arse having to go all the way down to get neutral. thats why i wouldn't have one in a road car.
    for a track car you cant beat it and its a joy to use especially when linked up to a closed loop flat shift system
    www.snaglets.com
  30. #268
    3,641
    Re: Pipes pinto :)
    You’ve answered your own question then
  31. #269
    Mar 2003
    3,540
    Re: Pipes pinto :)
    I thought that would be the reason and as explained above, I was already running an older version which I believe to be even worse than the newer versions
    And funny enough, I have a closed loop flat shift system all ready for it
    Thanks Andy
    Dazzle
  32. #270
    Mar 2003
    3,540
    Re: Pipes pinto :)
    Sorry, do you mean me? As I'm not quite understanding you??
    Dazzle
  33. #271
    Jan 2003
    Harlow/Walthamstow
    3,104
    Re: Pipes pinto :)
    And here it is back in its hole
    www.snaglets.com
  34. #272
    Aug 2014
    South Africa
    47
    16
    Re: Pipes pinto :)
    Looks Awesome, what kind of HP is expected ?
  35. #273
    Mar 2003
    3,540
    Re: Pipes pinto :)
    Looking good guys
    I'm really interested to see how you get on with the manifold
    Dazzle
  36. #274
    Re: Pipes pinto :)
    that manifold is known to add a bunch of midrange torque so we could be looking at 190+ lbft, as for power well i dont like guessing games. I have a figure in my head of whats possible given what it used to make and what improvements its had, but thats where its staying in my head, but its safe to say should go north of 220bhp. but already encouraged by flowbench results id like to start on a new head for it, just got no time, i started work 8 am yesterday and didnt leave until 10.30 pm
  37. #275
    9,204
    Re: Pipes pinto :)
    was the long upsweep intake manifold on dave whites engine not a success ?
  38. #276
    3,641
    Re: Pipes pinto :)
    Is that an SRD manifold? made a big difference on my engine.
    yes
  39. #277
    Re: Pipes pinto :)
    yes, pintos like long inlets, but theres not room to get that manifold in an escort, so ive gone a different way, as straight as possible on the flow bench its worth a few cfm so SHOULD add a few BHP
  40. #278
    3,641
    Re: Pipes pinto :)
    SRD's latest 92mm Pinto made 227hp on TB's with this manifold.
  41. #279
    Dec 2014
    Mk
    Re: Pipes pinto :)
    So you said Pinto like long inlets as in straight inlets straight to the back of the valve .... so you would not gain anything by running the up swept
    long trumpets Jenvey do ...
  42. #280
    Re: Pipes pinto :)
    i wouldnt of thought so two reasons, your introducing a bend into the intake and secondly the shape of the jenvey trumpets is wrong! that might sound like a bold claim but back to back testing has shown the big wide radiused trumpets make less power than straight tubes with a simple 45 degree flare, which is probably why weber has been making them that shape for a gazillion years
