Results 1 to 15 of 15
Thread: how to smooth seam-sealer?
    Mechanic dollie007's Avatar
    Aug 2007
    Lincoln
    511
    25
    As title, how do I smooth seam sealer off while it is wet? I was going to brush it but I've seen that thinners reacts when used, and I don't want to use anything that will react with the paint afterwards.
    thanks,
    Oliver
    3,641
    Re: how to smooth seam-sealer?
    You get seam sealer brushes, they are quite coarse.....work reasonably well although I end up using my finger most of the time. I've used Sikaflex on a few occasions too.
    immediately its been applied using your finger in a laytex glove, it goes off quite quick so only apply small amounts at a time
    Remember the camper......? Decade Plus User
    mk1matt's Avatar
    essex
    7,616
    70
    I much prefere sikaflex or tiger seal to any brush on seam sealer. Don't use anything else anymore.
    Mechanic runoutofrigos's Avatar
    Aug 2006
    North London
    651
    You can also use a palette knife/spatula dipped in methylated spirit to smooth any sort of sealant. Just make sure to keep the tools "wet".
    Simon
    Dec 2011
    Northamptonshire
    731
    Buy one of these and get the factory finish. Ive just bought one there awesome.
    http://www.ebay.co.uk/itm/Sprayable-...item20db1fa74a
    Jun 2006
    kilkenny, ireland
    519
    Quote Originally Posted by mk1matt View Post
    Me too, there is no comparison between brush seam sealer and tigerseal. Trying to remove a wing that has been stuck with tigerseal is no easy task!
    Oct 2004
    Orrstralia
    Put some turps on your finger and use it to smooth. Works well for sikaflex/urethane.
    Mechanic beeRS's Avatar
    Apr 2007
    Chelmsford
    773
    114
    I do almost exactly what bowlsclubboy says. I use Sikaflex, then with a cotton rag wrapped right to the end of a finger and dipped in white spirit wipe the surface smooth. The shape of the finish takes on the radius of the end of your finger. I've also used plastic spreaders (body filler spreaders) cut to different shapes to change the profile of the sikaflex bead.
    3,641
    And mask either side of the seam for a straight factory look line
    May 2014
    midlands
    Use fast panel wipe in a brake cleaner spray dispencer n a rag wet with panel wipe will give smooth finish
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    502
    I done my whole car with tigerseal and smoothed it using nitrile gloves dipped in petrol. You can really work it into the seams without it acting like chewing gum any excess cleans off with a rag also in petrol.
    Jul 2011
    herts
    502
    http://www.turbosport.co.uk/showthre...=169899&page=3
    Here you go. Have a look at post no 158. I used 7 cartridges to do every seam on the whole shell
    Jul 2011
    herts
    502
    That was the wrong page. Try this one
    http://www.turbosport.co.uk/showthre...=169899&page=4
    Jul 2010
    South Wales
    4,689
    221
    I brush it on and as soon as possible use a brush dipped in thinners and keep brishing it untill it is smooth.
