Results 1 to 7 of 7
Thread: Help with type 9 please
    essex
    35
    178
    Hi all hope someone on here can help I've got a 2 litre type 9 but have noticed it's got a crack in the tail housing. I've got a spare v6 type 9 just want to know would I be able to use the tail housing from the v6 and fit it to the 2 litre? Any help would be great
    Pit Crew Decade Plus User jimmy2006's Avatar
    Feb 2009
    essex
    1,973
    Re: Help with type 9 please
    yes in sure they are all the same
    Mar 2013
    West Midlands
    225
    I think ones 15mm longer ?????!
    Feb 2009
    essex
    1,973
    I no the input shaft is longer on the 2.8 but that is the wrong end
    Feb 2009
    essex
    1,973
    all I would say is make sure the two gearbox you are using are the same age what mean by that is they a both early boxes or are both late because the selector will not fit what I mean is you will not get a late tail fit a early gearbox because of the selector
    essex
    35
    178
    So in theory as long as they both look the same? I.e both have bolt on gear lever? Or did they do early and late types of those?
    Feb 2009
    essex
    1,973
    Quote Originally Posted by firthy View Post
    no the early gearbox tail housing has a single rib running lengthways along the tail and the earlier selector shaft is shorter
