I've been back in the UK for a while so not really much to report.
We've had another fuel pump go down on us on the motorway, but i managed to get get it into the services (just) and bodge it up to get to the garage. So i need another fuel pump.
I've raised the rear 3" so it's level(ish) with the front.
I can't get enough caster at the moment, so the front tie rod arm mounting points need moving forward, also the front of the arch needs modifying or the wheel is going to hit when turning.
We have too much camber, even with the strut slid to the outside as much as possible we still have 5 degrees so something will need to be modified to get less camber.
