Thanks mate I am after an in boot tank filler and splash bowl thanks tho
Don't have one off those listed but thanks anyway
Bump
best price on turrted rear dampers and wiper motor and linkage (if its good)?
Dampers sold, wiper motor linkage + fitting kit £45 + post
Did you get my payment for the steering knuckle, £23 inc postage ?, no mad panic but any news on arrival times ?. I have a works ha axle in my sunbeam, any idea if your flange is the same ?. Could be interested.
Hi posted the knuckle Monday, should arrive wed or thur
Not sure if flange is the same, cam take some measurements if you like
Pedal box still available
Got the steering knuckle, thanks. Actually doesnt fit as mine appears to have been modified but no probs, be good to chop up for something else. Are the twin cables still available ?.
Yes still have cables, have another knuckle but think its the same size
Payment sent for the cables. Don't worry bout the knuckle, its not your fault, Im not too familiar with sunbeams and didn't realise it had been modified. Sorted it now.
Spot on chris will post first thing Monday
Nice one buddy.
Cables posted today
Prop shaft has received.
That's good thank you
Some parts still available also gp4 rolling/steering mk2 motorsport shell, photos to follow
If you can do the cwp for £130 posted I will take it
Ford Escort RS MK2 Motorsport rolling shell
Excellent stright soild shell, suit historic or group 4 build
Spec:
Big diff and gearbox tunnel
Link boxes
R/h exhaust tunnel
Fully Seam welded & strengthened
Large Radiator Cut out
Weld on Strut Brace
Double skinned bulkhead
Firewall
Fuel tank, battery stand
Round Rear turrets
Aluminium arches & front spoiler
Included with the shell:
Springalex steering wheel
Long group 4 steering knuckle
Centre counsel
Instrument Binnacle
Dash top
Handles/Door latches
Rear lamps
Headlamps/Bowles
Front windscreen
Screen rubbers
Front grill
Doors,bonnet, boot
Atlas 52" axle casting
Steel wheels
Shell is rolling and steering on standard mk2 axle, struts, & rack,
Original rs chassis number
& registration supplied ( log book needs applied for)
Car is located 20 minutes from ferry ports off belfast Northern Ireland
Priced to sell
£4.250
Atlas 52 axle casting dimond brackets shafts std diff
Pedal box
Wiper linkage & motor
Plus more
Hi there, CWP arrived today and looks better than I expected, TOP MAN!
Thanks again
Bump
Atlas axle pedal box and some other parts still a available
Forgot to add, cables arrived safely, spot on !. Cheap shell, hope it sells.
Hello
Parts still available??
hi could i have pick of ti rocker shaft and postage cost and is flywheel listed as crossflow/sunbeam does that mean they are same or your not sure which it is sorry for prob daft question just new to this cheers
Still have rocker shaft £25 + £12 p&p
Flywheel is ford crossflow I used on my sunbeam, £20 postage
Ford crossflow or pinto flywheel fits a sunbeam ti
any chance of pic of rocker shaft showing any wear
thanks
