Results 1 to 8 of 8
Thread: 4AGE backtop info request on fuel tank
    Apr 2013
    Manila, Philippines
    22
    Hi! I'll be fitting in a blacktop into my MK1 and would like to ask if what sort of modification I will need for the fuel lines. Can I use my old fuel tank for this EFI set up and just install an external electric fuel pump next to it and create a return port to the tank? I'm not really sure about the difference of an EFI and carb fuel line. I found some universal fuel tanks in ebay which seem to be priced ok. Thanks in advance.
    Jan 2011
    Sarf Rugeley
    584
    32
    Re: 4AGE backtop info request on fuel tank
    Hi yes you can use your existing fuel tank and and modify the outlet for a bigger opening. Install a external pump and that will be ok. Your lines will need to be upgaded for fuel injection. I used 8mm copper pipe for feed and return. HTH
  3. The Following User Says Thank You to bunta20v For This Useful Post:
    Apr 2013
    Manila, Philippines
    22
    Thank you bunta20v for the info. Looks like I'll be going the way you did yours.
  5. #4
    Apr 2013
    Manila, Philippines
    22
    A bit more questions on converting to EFI.
    Did you install a fuel regulator?
    Do you have to install a surge tank?
    How about the fuel gauge? How will I make this work still?
    Thanks again
  6. #5
    3,237
    Quote Originally Posted by sooper View Post
    Thanks again
    Yes a regulator is required - usually placed after the fuel rail....... unless you use a in-tank pump as these tend to have a built in regulator. If its an Escort, the standard tank is a good shape to prevent / minimise surge unless you like running low fuel level. EFI won't have any effect on the fuel gauge sender - it'll work as standard.
  7. The Following User Says Thank You to katana For This Useful Post:
  8. #6
    Apr 2004
    Bangkok, Thailand, Thailand
    4,346
    479
    A different idea for you to think about...
  9. The Following User Says Thank You to M11rf For This Useful Post:
  10. #7
    Jan 2011
    Sarf Rugeley
    584
    32
    Thanks again
    As mentioned I used the standard 4age one which is located on the 20v fuel rail. Works great. Didn't need a surge tank. It's a simple setup in a escort to get working well. Fuel gauge will work as normal as that's in the tank. Shout up if you need anymore info.
    Dave
  11. The Following User Says Thank You to bunta20v For This Useful Post:
  12. #8
    Apr 2013
    Manila, Philippines
    22
    Thanks guys for the info. It is such a great help. Looking forward to post my finished project. I'll stick to the original tank. M11rf, that's a great and simple setup! Thanks for sharing
