Results 1 to 10 of 10
Thread: ECU location
    Oct 2011
    965
    ECU location
    Looking at where to mount the ECU in my car....Mk1 escort with YB.
    Some pics if possible of what you have done, and locations would be helpful.
    many thanks
    Mar 2009
    norfolk
    70
    Re: ECU location
    I fitted a mk2 rs glove box an fitted it on top of that or the n/s kick panel hides it well too
    Sep 2012
    brandon,suffolk
    520
    83
    Re: ECU location
    mines up under the same place.
    Mar 2008
    west bromwich
    1,861
    Re: ECU location
    Mines on the cossy ecu bracket under the glove box on the side , neat and out of the way of wavey feet !
    Oct 2011
    965
    Re: ECU location
    How have you guys mounted them....
    Apr 2005
    worcestershire,uk
    745
    65
    Re: ECU location
    mines in the mk1 escort glove box just screwed to the base
  7. The Following User Says Thank You to rsminter For This Useful Post:
  8. #7
    Jan 2011
    Blairgowrie
    9
    Re: ECU location
    I notice you have Mk1 with YB turbo conversation and was wondering if you could provide some info. I have one as well but I'm struggling with wiring up the Cossie loom IE fuel pump ignition etc etc. Car turns over but no spark.
    Please help.
  9. #8
    Oct 2015
    Essex
    347
    33
    ECU location
    Have u got a 12v feed to the Ecu when cranking
    Green wires to coil n rev counter
  10. #9
    Aug 2016
    Mol, Belgium
    9
    Re: ECU location
    Escort Cosworth : passenger down on feet nearby door
  11. #10
    Australia
    28
    Re: ECU location
    I plan on putting it up behind the glovebox and maybe cutting down the glovebox abit to male a false panel behind it
