I feel a right idiot asking this, but I've never had nice toys like this to play with! I've got one of those manometers that you can connect all 4 venturis to and set the carbs up properly. So yesterday I got everything out, warmed up the Jensen and looked for somewhere to connect the beasty to. I've circled the bit I expected to work, the blanking screw 'progression drillings cover' with the air balance to the right and idle mixture as you look at the engine ( maybe I should have used the other venturi! ) however, I got no reading at all. Obviously I'm doing it wrong. Can someone point out what I'm doing wrong??
Also, found why the handbrake failed the MOT... the tester's emergency stop blew the seals on the one wheel cyl I hadn't replaced. There is a wavy crack in the lining - hope you can see it. Is it ok to use, or will I need the linings replaced? Car's an old racer, I'm slowly getting it onto the road.
Cheers,
Steve
