Map for st170
Has anyone got a map for a st170 with throttle bodies i have mega squirt with no map any help would be appreciated
Re: Map for st170
which mega s. ? edis ? msnse ? more info the better.
Re: Map for st170
All i no is ms1 with a v3 board
Re: Map for st170
ok, you need to know what firmware you have. ie msnse (mega squirt and spark extra) is best, if you dont have it its worth updating.
ms's can be wired in several ways ie with direct coil drivers or using edis, with vr crank sensor or other trigger. you need to know what yours is doing.
can you access it in megatune ? this will show you most settings when you "load config from ecu" or similar .
also worth knowing is most "maps" are config files with all settings. a vex file is just the fuel(ve) or spark advance table
i can give you maps but they may not work...............
Re: Map for st170
Hi, he's got my old megasquirt, its an MS1 with a V3 board, it has MS1 extra 029y4 code loaded, it already has a zetec map on it but he needs it to be able to switch the vvt on.
Re: Map for st170
i have sent him my map but its not ideal.
Re: Map for st170
Hi found your tread And wondered if you could help in a similar situation with a st170 on gsxr throtlebodies bodies and a megasquirt ms2 v3 Wondered if you would be willing to share your ms file just to give me a start.
kind regards
shane
