Front cross member
How difficult is it to change the front cross member on a S1 ?
How much is it likely to cost me to get it done ??
Re: Front cross member
Slim do you mean the box section under the radiator?
If so it is a bit of a pain as you need to remove the front panel as well, which will need a replacement.
How bad is it? is it rotten or damaged? and are you just trying to keep it solid or do you want everything original?
It may be possible to cut any rot back and weld in some patches.
dunno if you can see from this pic or not.
It may be able to be patched up, what do you think?
Need to see with the radiator out really, I can see the crack in the corner, should be able to make a plate to go over that OK, but depends how far in the rust goes.
Shouldn't be terrible
It is actually a hole just below the jubilee clip in the pic about the size of an egg.
Oh yeah I see now, the edge of the hole is what I thought was cracked.
orrible, but still fixable depending on depth of rot.
I`ll think i will have to get it done soon b 4 it gets too bad.
The rad has to come out anyway as it is falling apart
Where are you Slim?, could come and take a look when the rad is out, see what it needs.
Im in Sawston, it is about 3 miles from the Duxford junction of the M11
eeek!
miles away. Nah it's not that bad.
Can always pop up for a look, but will be away for a couple of weeks.
cool thx,
Clint knows where i am, I need to get a rad first anyway.
We'll sort something out when I get back from hols.
Sorry to hear that you need some welding doing :o. I got my radiater from Anglia Radiaters in cambridge, will look up there number if you want. Cost me £70/80 I think. As for ease of doing it. It all depends on how bad it is. I can get hold of a Ford front panel if you need one. ( I have one in the shed but thats for my car lol)
Scott
Ill get you a price today on the rad recore.
Im also going to pick up my panels at lunch time so I will get you a price on the crossmember.
Are they by the Bridge Scott Nr Cambridge Utd ?
Thx Clint, Hopefully it wont need it and can be patched up.
if you havn't got your cross member yet A.R DAVIES in baldock have them for £33.95 they also do the front panel with crossmember for £51.45 there is a sale on at the moment! you can call them on 01462 892304
Cheers Neil,
Baldock aint that far from me either.
Hopefully it can be patched up though.
Will need to get a look at it and see what it's like.
Mark i just looked, the MOT runs out on March 18th so would be good to get it done by then if poss.
HI MARK M8 WELL I FOPUND THIS SITE THANX 2 A M8 . IM NOT FAR FROM SAWSTON , WE THRASH EM AT RUGBY TWICE A YEAR LOL SO I COULD HELP IF IT IS NEEDED I GOT A WELDER ETC .WHERE R U FROM MARK AS I HAVE ME MK1 PROJECT ON YA SITE.
ANDY
Hi Andy,
Welcome to Turbosport, how's the Escort coming on, have you done any more?
Slim,
Any chance you can bring it down this way for a look at the rot? maybe sort something for a weekend?, I will be away again in March so need to look soon, if it is patchable then I could do it same day.
Not at the minute its running like a pig at the moment, when/if its sorted then yeah probably. Will let you know.
What happened to yer post????????????
ohhh more work for me to do. Still i prefer doing bodywork. Clint did u get any prices on the cross member?
£25 for the xmember and you dont have to remove the ft panel but the guy at the mot station said that it is still quite solid at the mo so was just going to do it when I got around tuit
Have you soirted that 5 th gear prob yet ?
no worries m8, Ill sort a set out for you and put them by.
