Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 41 to 80 of 170
Thread: Mk2 RS200 Story so far
  1. #41
    Apr 2003
    Liverpool
    468
    9
    Re: Mk2 RS200 Story so far
    stunning.
  2. The Following User Says Thank You to dave_cos4x4 For This Useful Post:
  3. #42
    Jan 2012
    Aberdeenshire
    417
    Didn't get as much done as I wanted so but got the bottle of argon sorted so it was tack the tramp bar brackets to the axle and then remove it again for welding
    Time to refit it for hopefully the last time
    Next are the rear brakes, cosworth calipers being used so dressed and on
    Next was to rebuild the calipers so full strip, blast, paint and Pistons seals all replaced
    On putting the RS alloy back the calipers seemed to foul the inner rim, tried th7" Ronals and no problem so calipers will stay off until the wheels get refurbished
    Next was to get the engine off the stand and onto the cradle so I could fit the flywheel, first job was to fit the sprigot ring
    Next was the lightened flywheel curtesy of retro ford
    Next was the dirt shield
    Next was the clutch, which again curtesy of retro ford
    Looking good
    That's her dressed so happy with the way it turned out. Gearbox got cleaned up but I think she is going to be the weak link as she is just a standard type 9 out of a 2.0 now with the alloy RS bell housing. Will worry about it another day
    Next it's the fuel tank. Nightmare with the thread pattern on the outlet, barious different references on the sites from 3/4 BSP, 3/4 UNF, none fitted so it was modify what I had and come up with something with an AN8 fitting
    So started with this
    Once removed looks like this, after all these years didn't realise they had a filter in the tank
    Next plan was to cut the nut the nut off so the 3/4 tank fitting was flat and then weld on an AN8 fitting
    Once done I cut the small pipe on the inlet side of the tank and drilled and tapped a 12mm hole for an inline filter, which made me smile as it came from a ford tractor. End result looks like this.
    Dowty washer and then fitted and end result, just the dogs
    Next it's clean the tank up ready for paint
    End result
    For the return I just drilled the fuel sender and fitted an AN6 fuel cell fitting
    Well that's it for the next while, next will be fuel lines, brake lines and pedal box so let's see how that goes
  4. #43
    Jan 2012
    Aberdeenshire
    417
    Long time since I updated but for good reason, not a lot done. Keeping the classic look but bit of a hidden modern touch under the carpet in the form of dynamat so after going through all the effort of welding the tunnel in, blending the welds so had the factory look, painting the floor in dove grey to look like primer and the a bit of overspray in yellow I hide it all for a quieter ride
    First a reminder, big tunnel
    Tunnel cut out and bulkhead getting welded back in
    Tunnel welded in and getting dressed
    NOS seat box reinstated
    Gearbox and engine trial fitted and raiser plate fitted
    Now painted and looking much better
    Time to start with the dynamat
    Glad that's done as it's a pain in all the nooks and crannies
    Next was the battery tray in the boot, she was yellow to start with
    Needs to be black as the plan is to blend it in so it doesn't stick out like a sore thumb, black carpet will be in the boot so black tray will look better
    Staying with the black and yellow theme, started to dress the underside of the bonnet
    Wiring next, so will update later
  5. The Following User Says Thank You to donnie For This Useful Post:
  6. #44
    Sep 2014
    middlesbrough
    320
    wow, very nice build, how could i have missed this
  7. #45
    Jan 2012
    Aberdeenshire
    417
    Thanks Andy, easily missed as progress is slow but will get there one year
  8. #46
    Sep 2014
    middlesbrough
    320
    worth it in the end, no matter how long it takes
  9. #47
    May 2009
    north wales
    635
    62
    Very nice indeed what was the cost to get the lights chromed and what bond did you use please
  10. The Following User Says Thank You to dustydog For This Useful Post:
  11. #48
    Jan 2012
    Aberdeenshire
    417
    Ashford Chroming at 220 quid for the pair, sealant was just white fish tank sealant
  12. The Following User Says Thank You to donnie For This Useful Post:
  13. #49
    Oct 2008
    whitley bay
    2,436
    89
    Can I ask where the catch tank is from?
    Hexham and District Motorclub
  14. #50
    Jan 2012
    Aberdeenshire
    417
    Torques, good quality and not a bad price.
  15. #51
    Jan 2012
    Aberdeenshire
    417
    Wiring harness, where to start. Thought about getting a replacement made and a few to choose from, Alan at Premier wiring (gentleman and very helpful every time I spoke to him), rapitfit looms again sounds good but feedback varies so to heck with went with reworking my own loom
    Where to start, original loom
    Then the zetec loom, emerald ECU and focus st engine bay loom
    Needed some help so it was a call to emerald and an engine bay harness provide which is easily married into the the original Mk2 harness
    Trial fit that onto the engine just to make sure it's as easy as says on the tin
    Great, now all the bits together on the floor. Main loom, rear loom, fuel pump wiring loom, replacement engine bay loom & battery cables as she will be in the boot
    Next was the fuse box, plan is to change ceramic original fuse box for a more modern blade fuse box, replacement found and is a direct fit
    Next, clean up all the connectors and marry the lot together
    If anyone knows a way of getting the connectors looking good again, let me know and I will update later in the month
  16. #52
    Oct 2015
    Essex
    347
    33
    Where did u get the fuse box from cheers
  17. #53
    Mechanic beeRS's Avatar
    Apr 2007
    Chelmsford
    773
    114
    Quote Originally Posted by donnie View Post
    I sorted my connectors by unclipping the metal spade connectors within, and then cleaning the white plastic parts by soaking in a de-greaser.
  18. #54
    Jan 2012
    Aberdeenshire
    417
    Got the replacement fuse box from auto electrics, quite a few places do them, you can also try car builder solutions
  19. #55
    Jan 2012
    Aberdeenshire
    417
    Thanks beerRS, stripped the harness of the tape, redid most of the spades and used heat shrink so they look tidy so now it's try the degrease
  20. #56
    Jan 2012
    Aberdeenshire
    417
    So what did I get done in the last few months, well no where near what I wanted due to spending time with the wee fellow over the festivities. Plans were to fit the dynamat to the the roof and fit the headliner once I changed the colour from putty to black, didnt get the dynamat installed but did manage to scrub the headliner and paint it black
    Now with some paint applied. Did try the Dye supplied by AutoGlym but alas not what I expected as 2 cans and I could still see the putty colour so had some Halfords vinyl trim paint and it was great to apply and turned out smart
    As I didn't get the dynamat finished, I could get the headliner installed and then the next job put on hold was installing the glass so hopefully next time
    So what next, brakes. Have the Hydraulic Pedal Box, remote Servo thanks to VWJim and reservoir bottles so bottles fitted first
    Next problem, bottles touch the bonnet when its closed
    So its modify the bracket, lower it 10mm and sent it back of for poweder coating. What next, due to the holidays wont get the bracket back till January
    What next, lets run some brake pipes
    Job now at a stop as the plate that fixes to the bulk head is also still at the powder coaters.
    Only job left to do is get the wheels refurbed and mated up with some tyres, first wheels before the refurb
    Some good old good year eagle NCT 2s, 205s, bit wide but will probably go back to 185
    Back from the the Wheel Specialist in Aberdeen who did a great job so delighted
    Hopefully next time back in the garage the brakes will be done, dynamat finished, glass in and finally wiring harness in place but not going to hold my breath
    Happy New Year to one all all when it comes
  21. #57
    May 2006
    322
    11
    lovely car and lovely build at high quality ! I'm also thinking dynamatting my car. From what i hear it works like it should.
  22. The Following User Says Thank You to filipvdv For This Useful Post:
  23. #58
    Jan 2012
    Aberdeenshire
    417
    Thank you sir, your own build is a stunner and taking shape nicely and again quality built. Dynamat is good stuff and you need patience but worth it I am told
  24. #59
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    502
    Beeeeeautiful. Bet you can't wait to get behind the wheel
  25. #60
    Jan 2012
    Aberdeenshire
    417
    You are right there. Done plenrty looking at at and imagining so looking forward to hearing it fire up in anger again
  26. #61
    Jun 2006
    Durham, UK
    1,494
    That's looking very smart - really clean, neat and tidy. Not sure why, but the mk2 RS2000 in always looks great in yellow!
    Great job with the headliner by the way - I did a similar thing with a pair of putty coloured sunvisors and they turned out fab.
  27. #62
    Jan 2012
    Aberdeenshire
    417
    Thanks big fella, was looking at painting the headliner for a long time and glad I eventually got round it as it turned out spot on. Your own Mk1 must be nearly done as she has come on well since you got her back
  28. #63
    Jan 2005
    up north
    670
    making a cracking job of that donnie,its worth doing the archs and all the holes with the dynamat as a lot of noise is transfered in through them
  29. #64
    Jan 2012
    Aberdeenshire
    417
    Thanks for that and will do as the plan is to keep her as quiet as possible inside and loud as possible outside
  30. #65
    Jan 2012
    Aberdeenshire
    417
    What have I done this the last update, first more soundproofing with the dynamat extreme going on the roof
    Once done it's time to refit the original soundproofing
    Now ready for the headlining and as she was kept with boiler it was so easy to install as I could stretch it and fit a transit
    Only problem was once in and looking at it closely I realised it was a bad by as it was from a left hooker so removed and replacement sourced, so more scrubbing / prepping and painting next time back
    Next it's carry on dressing the engine with the exhaust going on next, retro Ford exhaust manifold now installed
    So sun was out for a wee while so far chucked out for its annual outing, shame it's just not under its own steam
    Still not happy with the rechromed inner headlights so going to remove the lenses again and see if I can polish up the chrome and see if it will make a difference, also got a spare set chrome sprayed so will try that option as well and see which one looks the best
    Next after looking at it for months finally got my finger out so next it's get the engine into the bay
    Up and over time
    Looking good if I must say so myself
    So with the engine in the bay I thought I would try something different and see if I could do something different but alas where do you stop. Next up carbon dipping
    Rocker cover
    Cam belt Cover and windscreen washer bottle as I couldn't get it clean
    Now it's time to stick it back in the corner of the garage and cover her up till the next time
    Next task, engine back out, finish the wiring as I now have trial fitted the loom so all lengths sorted and ready for loom tape, fit pedal box and remote servo so I can refit the bulkhead pad, reservoir bottles, connect brake lines to the bulkhead plate and alas all brake lines done
  31. #66
    Jun 2006
    Durham, UK
    1,494
    That's looking bloody ace. I like the dedication to sticking with the black and yellow theme in the engine bay!
  32. #67
    Feb 2011
    Caernarfon,North Wales
    180
    29
    Fantastic build. Great read/thread. Going to be a stunning RS. Too good to use?? Lets hope not!! Superb👍👍
  33. #68
    Jan 2012
    Aberdeenshire
    417
    Thanks boys and don't worry, built for using and not a trailer queen
  34. The Following User Says Thank You to donnie For This Useful Post:
  35. #69
    3,641
    Stunner, that will be a lovely thing to drive.
  36. #70
    Mechanic DANGERDAVE80's Avatar
    Jul 2008
    Edinburgh, United Kingdom, United Kingdom
    806
    Thats bloody lovely mate, that would be a cracking daily driver!
  37. #71
    Jan 2012
    Aberdeenshire
    417
    Thanks Erik and Dave, she is taking shape slowly but surely, plan is to have her ready for next summer and then give her a good using
  38. #72
    3,641
    How do you find the diff clearance with the Atlas and std diff tunnel?
  39. #73
    Jan 2012
    Aberdeenshire
    417
    Looks as if there is plenty room with no issues but will have to wait till it's on the road before I can answer that one with confidence
  40. #74
    3,641
    Been planning fitting an Atlas in mine but im unsure if i'll need a bigger diff tunnel as its pretty low, let me know how you get on.
  41. #75
    Jun 2006
    Durham, UK
    1,494
    I found there was plenty of space on mine, though I did angle the nose down a couple of degrees. Not masses of space, of course.
  42. The Following User Says Thank You to MegatronUK For This Useful Post:
  43. #76
    9,204
    great read this , well done
  44. #77
    Jun 2006
    Durham, UK
    1,494
    This is under full drop on the wheels-free ramp, so take the amount of space shown with a pinch of salt!:
    Any use?
    I can probably get some better pictures including measuring the top clearance to the diff tunnel this weekend if it would help; the car is pretty low now, so it should give you a good idea.
  45. #78
    Jun 2006
    Durham, UK
    1,494
    Attachment 80918
    Attachment 80919
    Attachment 80920
    Any use?
  46. #79
    Mechanic mk2-mad-ad's Avatar
    Nov 2008
    stoke
    644
    25
    This is comeing along brilliant mate looks fantastic
  47. #80
    Jan 2012
    Aberdeenshire
    417
    Cheers fella, getting there really slowly but no rush
