Results 1 to 6 of 6
Thread: Regulator Wiring
    Bodger Turbosport Subscriber neb105's Avatar
    Sep 2012
    Surrey
    32
    61
    Regulator Wiring
    Hi, in need of some advice about a Jeep that's being converted to 12v from 6v with negative earth. Somebody's done the majority of the conversion, I'm just attempting to install the 12v generator and regulator. The problem is I'm electrically incompetent/retarded. The generator has Field, Ground and Armature terminals, the regulator E D WF F B, which one goes to which? I assume the generator 'Field' terminal connects to the 'F' on the regulator, and the 'Ground' of the generator wired to an earth?
    Any help much appreciated, thanks.
    Feb 2009
    essex
    2,043
    Re: Regulator Wiring
    Quote Originally Posted by neb105 View Post
    what is the make of the regulator ?
    Sep 2012
    Surrey
    32
    61
    This is it
    I support TS Decade Plus User
    4,733
    27
    Google is your friend!
    (google a bit more and you probably will find a pic with exactly your markings)
    Sep 2012
    Surrey
    32
    61
    After abit of google image research its the same as this one http://www.autoelectricalspares.co.u...-22a-261-p.asp
    'control box RB340 replacing Lucas NCB132 12v 22A'
    Sep 2012
    Surrey
    32
    61
    Thanks! I'd been looking at other diagrams with different symbols but that is the one
