Roland Rat
40`s inlet manifolds
are the crossflow and pinto manifolds the same, I know the ports are smaller but that will be cured by matching it to the head. I seem to remember that the bolt holes are the same, or am I stoned again?
Re: 40`s inlet manifolds
The are totally different m8 but if you are after one <A target="_blank" HREF=http://www.raldes.co.uk>www.raldes.co.uk</A> do them quite cheaply.
Carl,
Have you got the carbs already?
Roland Rat
I have got a set of dellortos (sidedraft 40`s) without trumpets or manifold, plus i swapped an old gixxer exhaust with a mate for another set on a crossflow (i think) manifold with trumpets! So got two sets now, i know they came off amkII which might have been a 1600 pinto? Oh well if i have to buy a manifold no big deal as I got these for next to nothing anyway!
Roland Rat
Arse just offered em up, yep tis a croosflow manifold! Never mind. Oh well carbs will have to wait till the end of Januray when I get paid again. Unless anyone wants to swap some 600 Bandit bits for a set of 45`s.
Are you after a x flow or pinto (ohc) manifold ?
I have a x-flow manifold - £20.00 its yours
cheeRS
DAVE
Roland Rat
was after a pinto inlet bought a new one from Burtons at the weekend! Just got to lap in the valves give it a good clean and paint then fit in acouple of weeks.
