Hello new member
Followed the link off duncans site and found this nice little board. I own a mk2 escort, which is currently undoing rebuild, and i need a little help with a few little things.
I am hoping to drop the engine and box in this weekend
Does anyone know how to wire MK2 rs2000 clocks into a standard mk2 loom?
I have asked everywhere but noone know!!
Thx for any help
Re: Hello new member
Hello and welcome to Turbosport.
It is a long time since I have shanged a set of MK2 clocks to RS ones, but I think they just plug in and the wiring is the same except you will need a wire from the coil - side to the rev counter (the connection should be obvious if you trace the wires from the multiplugs you will see the missing space)
Also you need to add a oil pressure pipe.
Hope thats right, if not let me know and I will check a loom for you.
cheers m8
it is nice to find a board with people who are willing to help, i have the oil pipe,when i wire the battery up i will plug em in and see what happens, as i relocated the battery to the boot, still gotta find some bloody battery cable!!
I spoke to mexico mark a while ago and he mentioned something about the woring being different? Probably me gettign confused (usually do).
You should be able to get battery cable from your local motoring factor? (Wilco or Partco)??
As for the wiring I havent a clue I'm afraid but it should be fairly straight forward!
Kieron
The wiring is in a different order, when I swapped the clocks in my Harrier for the RS type I cut the wires to the plugs and swapped them around, you can work it out by comparing the tracks on the pcb on the back of the clocks and swapping the wires to suit.
Good Luck
new member
thanks for reply's guys nice idea about using old clocks shame i chucked em
Electrics was never my strong point maybe i could use the wiring diagramsa and do it by colour!
Re: new member
welcome to the board. Soz carnt help with the wiring tho
