Results 1 to 29 of 29
Thread: Duratec oil housing adaptor
    Spanner Monkey FlashRS's Avatar
    Jan 2003
    Bucks
    219
    Hi,going dry sump, so need the housing that bolts to the block , with 2 outlets on it. Is there anyone in the uk that does them? I can find pics on the net but no supplyers. I am using retro ford engine mounts so pretty tight for space!
    Oct 2013
    Suffolk
    47
    194
    Re: Duratec oil housing adaptor
    You only need one port to pump the oil in to the engine
    I have these plates being cast , so will have some in shock as soon as they come in
    Dec 2007
    Dubai
    1,678
    29
    Dunnell version works well
    www.gulfpetrolheads.com
    Jan 2003
    Bucks
    219
    Quote Originally Posted by Lacey View Post
    Hi, that sounds good, when do you think they will arrive? Cheers
    Oct 2013
    Suffolk
    47
    194
    Very soon mate as I need some for stock
    I will look to see if I do have one still mate
    Nov 2005
    ireland
    642
    9
    just thought i say Lacey is gentleman to deal with. its a pity everyone not like him
    Jul 2013
    Norway
    14
    Lacey, do you have these in stock now? Please post a picture if possible. Thanks!
    Oct 2013
    Suffolk
    47
    194
    I can email you over a pic mate that's not a problem just pm me your email address
    Jul 2013
    Norway
    14
    Thats great, email me on: bdatuning at gmail.com
    Regards
    Erik
    Aug 2009
    Australia
    109
    Attachment 70109I can provide an oil filer mount with oil cooler inlet & outlet ports plus 2 gauge/sender ports.
    e mail jrprmc1@bigpond.com for details.
    Attached Thumbnails Attached Thumbnails Oil filter & cooler adaptor 1.jpg‎
    Oil filter,cooler adaptor 1.jpg‎
    Sep 2010
    kent
    227
    Now that is probably the best oil filter housing ive seen. If I need to go oil cooler with my r500 spec engine later in year ill def be after this.
    Aug 2009
    Australia
    109
    Quote Originally Posted by itsawindupuk View Post
    Hi Bodger,
    I have just finished a new design (even more compact and cheaper) with the filter horizontal and still with cooler connections.
    The oil filter and hoses miss standard Escort X member and engine mounts and is also perfect in Clubmans.
    Click image for larger version Name:	377small.jpg Views:	261 Size:	134.3 KB ID:	71124
    Jan 2013
    Wellington, NZ
    208
    23
    That looks really nice, would it clear a retroford lowered crossmember? How much Aud are they? Cheers.
    Dec 2007
    Dubai
    1,678
    29
    Quote Originally Posted by nathanblaise View Post
    Looks like a very nice solutions, but would recommend using Roger's (Durescort's) Alloy engine mounts as don't think the oil filter adapter will work with the RetroFord mounts, as per the picture of mine below, which just clears the Dunnell one
    Click image for larger version Name:	e0370.jpg Views:	257 Size:	103.5 KB ID:	71149
    Aug 2009
    Australia
    109
    Yes.
    The cooler hoses easily clear over the top of the OE standard X member, so should be heaps clear of a lowered one.(all my Duratec parts, engine mounts, dry-sump kit, water outlet, bell-housing are designed to fit the OE X member with the 48mm thick Pinto engine mounts; no body or chassis mods required)
    Price is AUD $135 + P&P
    Cheers.
    Nice, can you work out the postage to the UK please.
    Jan 2013
    Wellington, NZ
    208
    23
    Thanks Roger, looking at dobuys picture and yours it doesn't look at first glance like it would fit - I'm looking at the distance from the left hand bolts to the filter plate, its less on yours than the dunnel one which just fits. I guess I should have said engine mounts rather than crossmember, sorry for any confusion.
    Aug 2009
    Australia
    109
    In that case my vertical filter type would probably clear OK.(see pics 2/6/2014 above)
    With my horizontal filter type, I don't think there is much in it; Its filter plate is in the true centre of the 4 bolt pattern, very close to the Dunnell one, but difference is mine has a smaller ID seal face, which will take the smallest diameter filters available, and would clear your engine mount bolt.
    I have also just finished a further improvement to enable fitting a (huge) VDO type pressure sender pointing towards the rear.
    Pity you didn't use my sump and engine mounts in the first place it would have saved you all the trouble of having to change X member, steering, chassis mounting, etc etc ! LOL
    For Eric, I will get the postage to UK and advise.
    Cheers.
  19. #19
    Jan 2013
    Wellington, NZ
    208
    23
    Thanks Durescort, is the price the same? Glad I could make you laugh :-)!
  20. #20
    Jul 2006
    bristol
    10,882
    892
    Hi guys bit off topic but I have a pace dry sump system ready to go on mine but the pump fits the inlet side I would really like it on the exhaust side. I've found pictures of them fitted that side but can't find anywhere that sells a fitting kit?
    Anybody else you them that side?
  21. #21
    Oct 2013
    Suffolk
    47
    194
    Pace do the kit for both sides give them a call
    If that don't work them send me a pm and I will see if
    I can get you sorted mate
  22. #22
    Aug 2009
    Australia
    109
    Quote Originally Posted by eric View Post
    Postage to UK is AUS$18 for the horizontal filter type and AUS#38 for the vertical filter type (because it is heavier)
    Roger.
  23. #23
    Aug 2009
    Australia
    109
    Vertical type is a bit dearer because it is a bit trickier to machine and is AUS$195 + $20 to NZ.
    I will take an 'as installed' pic. and try to attach it later.
    Email me on jrprmc1@bigpond.com so we can exchange info.
    Roger.
  24. #24
    Aug 2009
    Australia
    109
    Click image for larger version Name:	Oil filter vertical1.jpg Views:	189 Size:	103.6 KB ID:	72110Click image for larger version Name:	Oil filter vertical2.jpg Views:	189 Size:	97.9 KB ID:	72111Click image for larger version Name:	Oil filter+ adaptor clear.jpg Views:	190 Size:	90.4 KB ID:	72112
    Some more pics showing vertical type filter installation.
    Please note: Both types are for engines with internal oil pumps; ideal for most people who want all sizes of spin-on filter types with addition of an oil cooler with minimum complication and minimum space requirement.
  25. #25
    Jan 2009
    Bristol
    187
    do you mean 'for engines with external pumps' ?, as per both pics ?.
  26. #26
    Aug 2009
    Australia
    109
    Quote Originally Posted by Dr Dub View Post
    Sorry to be answering so late:
    Both my oil filter adaptors are for engines with internal pressure pumps, (like OE type and my dry-sump systems) and for people who want to fit an oil cooler.
    Cheers,
    Roger.
  27. #27
    Aug 2009
    Australia
    109
    A bit more clarification: The pictures show my dry-sump system which uses external scavenge pump but still uses the OE internal pressure pump (a la Corvette) It's simpler, cheaper and more compact that way.
    Roger.
  28. #28
    Nov 2005
    ireland
    642
    9
    But can you use it with a external pace dry sump system
  29. #29
    Oct 2013
    Suffolk
    47
    194
    I have a oil in plate on the shelf mate
    You would need a remote filter head
    Which I also have
