Re: Different day, same story :(
Poor Slim
Cant help m8!! I'm a total DOH!! When it comes to Turbo type stuff. (in quite good on old stuff tho) its gotta be one of the multitude of lekky plugs or summat like that. Good Luck m8.
Don't worry about the throttle position switch Slim i asked the same question once as mine would run ok when it was connected or not and i was told it just detects whether the throttle is at idle, or wide open in order to trim the fuel settings.
oh right ok.
Things arnt looking good, the Mrs has been and bought a Autotrader
power to the fuel pump is via a relay this is connected (usually) to the ignition light this is general for most injected cars hope it helps i would check connections or replace relay
