3dr poly bushes (rear end)
This week im gonna start putting me rear bushs on . Is this a hard job to do on your own? And is there any tips
Re: 3dr poly bushes (rear end)
Which ones are you replacing ?
LOL I take it you was talking about hedge trimming
The arms on 3 doors do not have bushes but Spherical bearings so you cant do them if they are worn which I doubt on yours that they are they will cost around £70 each, the big doghnut ones are easy as long as you have the 2 piece ones going back in otherwise I wouldnt even attempt it at home.
these are the ones i got?
OK you cant use the yellow ones as your beam is already solid mounted you cant use the black ones as the arms use spherical bearings and not bushes BUT you can use the blue ones !!!!
lol i give up
Bushes, mounted and black ones !!!!!!!
This is getting more like the mens room all the time.
To quote Clint "...as your beam is already solid mounted... "
lol
slim be carefull coz i can see myself ramming those big yellow ones somewhere
ohh err
I have stirred it up enough in here Ill get me goat... no no coat
<CossieClint> I like goats <CossieClint>www.goatlovers.com
hmmmmm and we turn to this man for help
<Private Window>
<Toppy>Clint do you know any goats that are really up for it ?
I havnt seen a 3 door yet that has not got the bearings and I have also seen a few early saphs that have them also.
hmmmmm its all to much for me im just a simple person so why are these kits avilable for the 3dr i dont really mind but i forked out £170 for them what can i do with them. apart from make some nice earings for the other half
Send them back and say that the 3 doors have bearings, The rally design ones would have been less than £40 and they say on thier web site that the early cars have bearings and not bushes.
Definitely send em back, they have been supplied to you incorrectly it is the shops responsibilty, they may not give a refund but you should at least get a credit note for them.
hehe mailed the shop and he said np send them back and tell me what u want to swap them for . So what i need to know is it the bailey turbo dampner that bolts on to the rocker cover?.
You want the 2 legged turbo damper and Bailey does make one, ask for a damper to fit a 2wd turbo to a 4x4 head
Glad to hear you have had a resuly
The big yellow ones and the black ones are very funny to install.
Did it at home on my Escort Cossie... Took me a few hours...at least..
I mean 3 legged
Ahh yes clint i had a good look while doing the rear roll bar bushes. What the reason for moving the beam back abit? better handling?
