Page 11 of 25 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 LastLast
Results 401 to 440 of 990
Thread: rx8 gearbox?
  1. #401
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Quote Originally Posted by Automax2010 View Post
    I think once people have used them for a while and realise they are pretty good there will be more of a demand. As long as the common engine conversions are covered I.e XE, duratec, zetec, cossie, s2000 etc.
    the xe and cossie plates have been drawn up now. i have plans to make a 2wd version of the cossie and a 7degree version of the vauhall engine too.
    4x4 cossie
    o degree XE pattern
  2. #402
    Dec 2013
    Lancashire
    22
    Re: rx8 gearbox?
    How long will they be mate? could do with mocking my engine and gearbox im my car. Cheers
  3. #403
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Quote Originally Posted by benw456 View Post
    I will have a text plate by the end of the week hopefull so once the changes are made so it is perfect i will run some finished batch off b
  4. #404
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Looks like i will be making one to fit the 2wd flywheel too.........
  5. #405
    Re: rx8 gearbox?
    funny ho the the starter motor hole seems the same but the bolt holes differ
  6. #406
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    The 4x4 and pinto starter are the same. The 2wd starter has a different hole pattern on the starter motor too.
  7. #407
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    the vauxhall test plate all cut
    and the final draft of the 4x4 cossie plates are done (limited numbers of 3 as a trial to see if they sell)
  8. #408
    3,641
    Re: rx8 gearbox?
    I saw a couple of ads on ebay the other ay for Vaux XE ones, is it you thats selling them?
    All Cossie bolt paterns are the same as a pinto are they not?
  9. #409
    Re: rx8 gearbox?
    The 6 engine block mounting holes are the same, the starter mounting holes seem to be different between 2wd and 4wd. It must be down to using the 4 x 4 gearbox and flywheel etc
  10. #410
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    My vauxhall ones aren't finished yet they are still in the test period at the moment. They will be ready with in a week or two.
    The cossie block is obviously the same. The start holes are the same pitch as the type 9 pinto starter on the 4x4 but futher out for the bigger flywheel. The 2wd starter has a different starter hole pitch and is in a different possition yet again to the 4x4 starter.
  11. #411
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    What you said.
  12. #412
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Have you got an XE plate in the making?
    Nearly there now!
  13. #413
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Quote Originally Posted by longy View Post
    So have you any dates on when we're going to
    Receive the plates
    I hope you have your plate as it looks like someone is selling old stock off cheap. ;P
  14. #414
    Dec 2013
    Lancashire
    22
    Re: rx8 gearbox?
    Let me know when the xe one is complete mate and ill get the money over to you.
    Jan 2005
    up north
    670
    Re: rx8 gearbox?
    does the rx8 5/6 speed box cope with cossie power or is the rx7 the one to use,and is the same adaptor used
  16. #416
    Re: rx8 gearbox?
    that is the big debate no one seems to be able to answer. I will be going sensible cossy power so hopefully it will be ok.
  17. #417
    Jan 2005
    up north
    670
    Re: rx8 gearbox?
    duraescort on the other thread reckoned the rx7 5speed was good for 450 so would that one not be best for a cos install,is the rx7 5speed the same as the rx8 5speed?
  18. #418
    3,641
    Re: rx8 gearbox?
    Rx7 is the obne that handles big power.
  19. #419
    9,204
    rx8 gearbox?
    There are more than one jap box that will handle huge power
    The point about the rx8 is that it CAN BE FITTED to a ford engine. At reasonable cost in uk
  20. #420
    3,641
    Re: rx8 gearbox?
    BMW M3 box is a popular conversion for cosworths.
  21. #421
    Re: rx8 gearbox?
    maybe, but still got a rubbish 1st gear lol!
  22. #422
    3,641
    Re: rx8 gearbox?
    Not so much for a cossie with a high final drive, i reckon Gertrag boxes are the best production boxes out there.
  23. #423
    Oct 2013
    Doncaster
    116
    Re: rx8 gearbox?
    I've broke one with abit of power think there's gonna be disappointed people soon they don't seem to be able to take the torque , maybe rx7 is the one to have , was told by power torque the mt82 transit rwd box will fit on to duratec and can take loads of power just a shit first gear if anyone looking for gearbox for high power duratec
  24. #424
    Sep 2015
    Benfleet
    225
    Re: rx8 gearbox?
    What power do you have?
  25. #425
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Quote Originally Posted by Lmr025 View Post
    You have said you have broken one in a previos post but when i asked you never said how much power you are running. It would be interesting to know what car you are running one in with what engine and what sort of tyres you have.
  26. #426
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Other news is i have fitted up the XE plates to an engine and they are cock on. I have a couple of hole sizes to change but apart from that it is spot on.
  27. #427
    Oct 2013
    Doncaster
    116
    Re: rx8 gearbox?
    If you look back I replied it's a 2.5 turbo duratec running 335 Hp at wheels 299lbs feet it's broke a n7 Mazda gearbox 5 speed , and the 6 speed one then went on to rx8 box after all the hype about it bought adaptor plate off the founder of them , it lasted 3 weeks about 130 miles , 215/45/13 tyres all way round
  28. #428
    Oct 2013
    Doncaster
    116
    Re: rx8 gearbox?
    It's in a mk2 escort by the way
  29. #429
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    What did you break about it? Not the input shaft bearing by any chance?
  30. #430
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Road going tyres or slicks too.
  31. #431
    Oct 2013
    Doncaster
    116
    Re: rx8 gearbox?
    No it broke teeth off
  32. #432
    Oct 2013
    Doncaster
    116
    Re: rx8 gearbox?
    Khumo v700 tyres
  33. #433
    Dec 2011
    Cowdenbeath
    400
    32
    Re: rx8 gearbox?
    Once the box is bolted up and in car what mods are required to the prop shaft if you have your old t9 one and a Mazda one
  34. #434
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Quote Originally Posted by Turboman View Post
    I had my escort prop shortened 2" and the end changed to an rx8 one by BAR Props ine Neath, South Wales. They do a brilliant job.
  35. #435
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Broke the teeth off of what? The gears? If so what gear? Was it the gears on the end of the input shaft? Your not very forth coming with information considering your trying to help people out.
  36. #436
    Oct 2013
    Doncaster
    116
    Re: rx8 gearbox?
    Dont know when I drained oil out to remove it 6 teeth came out haven't stripped the box yet but it lost 2nd and 4 th
  37. #437
    3,641
    Re: rx8 gearbox?
    I struggle to see how these boxes could be that strong, the engine they are intended for produce very little torque, why would Mazda go to the expense of over engineering a mass produced part. An Rx8 produces 156 lb/ft at 5500 rpm, thats the same as my Pinto at slightly higher revs, why would an RX8 need a strong box?, its close ratio to keep a small light engine spinning, thats the only benefit i can see.
  38. #438
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Interesting. Keep us updated when you strip the box. My fear is that the old style plates didn't line the input shaft up properly which would lead to the input shaft bearing failing or the teeth on the input shaft breaking off. I haven't heard from anyone apart from yourself breaking one of these gearboxes yet even with the poorly made adaptor plates.
  39. #439
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    We have to push the boundries in life and this time it is to see what these gearboxes can do. If we all denided everything before we tried it like you are doing nothing would be tested and it would all struggle to see what could be done. These base boxes are also on the back of an s2000 and people turbo and supercharge them with out box issues.
    All i can safely say is it suits my needs as i have given this box a hammering and i would imagine there are many more people who will be running high torque high reving n/a engines that will suit this gearbox better than the type 9.
  40. #440
    3,641
    Re: rx8 gearbox?
    Honda S2000 makes around the same low torque. Most folk that are rallying with high revving NA engines run dog boxes, for me its the only way to go if your running decent torque and don't want the synchro reliability issues, a helical cut gear will always be stronger than a straight but synchro's will always be a weak point in any gearbox.
Tags for this Thread
