Page 25 of 25 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
Results 961 to 990 of 990
Thread: rx8 gearbox?
  1. #961
    Apr 2004
    Bangkok, Thailand, Thailand
    4,346
    479
    Re: rx8 gearbox?
    So, anyone using an RX7 box?
  2. #962
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Quote Originally Posted by therealpinto View Post
    Do you know what kind of torque you have?
    I'm a bit curious on trying an RX8 gearbox to replace my T5. But I have 280 whp and over 400 Nm from the Pinto turbo and gut feeling says the RX8 gearbox would be marginal.
    Gustaf
    what about using the rx7 box? they have the same bellhousing pattern.
  3. #963
    Nov 2004
    Sweden
    1,167
    Re: rx8 gearbox?
    OK, but are they as "easy" to find? Haven't checked but in Sweden Rx7s are thin on the ground.
    Gustaf
  4. #964
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Gustaf
    That i wouldn’d know sorry. All i know is they will bolt on the same as the rx8. Rx7 parts are pretty rare anywhere really.
  5. #965
    Tyre Kicker rsdeano's Avatar
    Jan 2006
    Mackay Australia
    35
    Re: rx8 gearbox?
    So I've read through the thread and it seems that the rx8 box is pretty strong, but not as strong as a t5 or an rx7 box.
    Does anyone have experience with matching it to the Duratec 2.0ltr?
    I had someone tell me today that the RX8 box isn't known for its nice shifting.
    How have others experienced thiers?
  6. #966
    Oct 2015
    Essex
    347
    33
    rx8 gearbox?
    Rx8 Shifts better than a t5 and even better with a quick shift
  7. #967
    Jan 2006
    Mackay Australia
    35
    Re: rx8 gearbox?
    Sounds good Ian...
    how do they go fitting in to the tunnels in mk1’s?
    are they heavy compared to a type 9?
  8. #968
    Oct 2015
    Essex
    347
    33
    rx8 gearbox?
    Fitted mine in a mk2 with just bellhousing tunnel mods :-)
    They are heavy 5kg more than a t5 so 42kg
    I paid more for the quick shifter than the gearbox and carbon prop but seems to b holding up well
    Cable clutch on mine is fine too if little bit heavy :-)
  9. #969
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Quote Originally Posted by rsdeano View Post
    They shift stunning even standard. Not as stong as the t5 that is for sure but they take revs much better. They are a great box for the price. I still haven’t mated one to a duratec i am struggling to get hold of a bottom end with a crank/starter and flywheel to sort out an adaptor plate.
  10. #970
    Jan 2006
    Mackay Australia
    35
    rx8 gearbox?
    Awesome
    That sounds good Freddy
    There are a lot of points heading me towards deciding on the rx8 box
    I’m still stuck on deciding my path for my 71 mk1 1300xl 3 speed auto shell
    Three main options
    Cozzie
    Duratec
    Zetec
    Cozzie standard (semi) with t5
    Duratec standard (semi) with a lot of extra costs for fitting and to make it fit
    Rx8 or rx7 box
    Zetec lumpy with 180 ish bhp
    Type 9 or rx8
    All with hilux rn25 diff and large single piece tailshaft modified
  11. #971
    Spanner Monkey ugg10's Avatar
    May 2014
    South Coast
    175
    30
    Re: rx8 gearbox?
    A type 9 box that will hold 180hp and have a decent 1st gear will be ove £1k.
    Rx8 box (6 speed) is an Aisin az6 which is also in
    Rx8 - 230hp, 9k rpm, not much torque
    IS200 - 200hp more torque
    S15 200sx - 250hp turbo, lots or torque
    Gt86/brz - 170hp
    Mx5 mk3 - 170hp (and a Duratec engine but iirc box/engine are at a slight angle to each other)
    The reason for using the rx8 box is that it has the same input spline as Ford so can use stock clutches on the Zetec etc.
    So, I think the general consensus is that it is probably good for 250hp, 250ftlb, and 9k rpm. This will be more than most Zetec or Duratec can put out. Ratios form 2-6 are the same as the straight cut Quaife type 9 clubman but the rx8 is helical (quieter) handles marginally more power and is 1/10 the price.
  12. The Following User Says Thank You to ugg10 For This Useful Post:
  13. #972
    Jan 2006
    Mackay Australia
    35
    Re: rx8 gearbox?
    Thanks Ugg10
    i didn’t know that the rx8 box is the same as the mx5 series 3.
    Is that the nc mx5?
    Sounds like a nice cheap box to fit.
    Are most people having to open the top of their tunnels and keep the box raised to make the box fit and line up the output shaft and the centre of the diff?
    thabks for your input
    I had been told to go for the t5 box with a close ratio set and quick shift
    but one of these boxes may well be at least as good and easier to get parts
  14. #973
    May 2014
    South Coast
    175
    30
    Re: rx8 gearbox?
    Afaik and happy to be corrected, the mk3 nc mx5 2.0l is a Duratec engine the same as the ford minded/focus and has the aisin az6 box on the back of it but the engine and box are at an angle to each other which may make fitting interesting. As for parts, in the U.K. you can pick up an rx8 6 speed box for £100-200 so not even worth opening up to fix, just buy another and replace, whereas with a £1k-2k type 9 then it is a different matter.
  15. #974
    Re: rx8 gearbox?
    Quote Originally Posted by ugg10 View Post
    The mk3 mazda nc box does fit to the duratec and is at a 10deg angle as in the mx5 the engine is tilted. So in a ford you get an angled gearbox. Adjusting the lever I believe gets over this. This gearbox is distinctly different to the RX8 gear box from appearances etc. Placement of starter motor, slave cylinder. There is also a rarer 6 speed mx5 gearbox which is a lot bigger. I suspect this is why no one uses the rx8 box on a duratec as the starter that bolts to the engine on a duratec sits right in the slave cylinder of the RX8 box.
    I have both gearboxes so this is what I have seen so far.
  16. #975
    Jan 2006
    Mackay Australia
    35
    rx8 gearbox?
    Wildo105
    So just to make 110% certain
    The rx8 box is not the same box as the mx5 6 speed?
    The mx5 6 speed is what Gordon Murray fitted to his duratec
    I’m just trying to work out what box they fitted to that car
    It would be great to hear that they are all the same box
    It’s not that they just have different bellhousings or something?
  17. #976
    Re: rx8 gearbox?
    Hi this is my take. They all have integral bellhousings so no swapping bellhousing etc. internally the MX5 6 speed may be the same as the RX8 but i do not know, but the bellhousing will be different. In the UK the 6 speed mx5 box is quite rare and a lot more expensive.
    The easiest way to fit a 6 speed to the duratec is the MX5 mk3 6 speed. They may be more available in AUS. This is only what i have found and worked out so far.
    https://www.ebay.co.uk/itm/Mazda-MX5...CRMx:rk:7:pf:0
    just for viewing
  18. #977
    3,239
    Re: rx8 gearbox?
    Big, fat suckers ain't they!
  19. #978
    Dec 2011
    Cowdenbeath
    400
    32
    Re: rx8 gearbox?
    Anyone had a issue with the thrust bearing squealing due to always hitting the pressure plate it is a zetec with a Freddy plate and a zetec flywheel drilled for pinto clutch
  20. #979
    Aug 2019
    East Yorks
    Re: rx8 gearbox?
    Anyone ever try the is200 box in the end?
  21. #980
    Apr 2020
    Tregaron
    Re: rx8 gearbox?
    Quote Originally Posted by Turboman View Post
    I as above would also like an answer to this question as i have tried everything to stop it now running out of ideas ??
  22. #981
    Dec 2011
    Cowdenbeath
    400
    32
    Re: rx8 gearbox?
    Quote Originally Posted by reeswalding View Post
    You need to modify the pivot point on the gearbox as the thrust bearing is running hard against the clutch all the time
  23. #982
    Jan 2015
    Anglesey
    Re: rx8 gearbox?
    What clutch and spigot bearing are you using
  24. #983
    Jan 2015
    Anglesey
    Re: rx8 gearbox?
    Hi I've just got one of your plates off ebay can you post a fitting guide for the xe like you have done for the ford engine
    Many thanks
  25. #984
    Jul 2012
    wiltshire
    75
    Re: rx8 gearbox?
    Re : rx8 gearbox.
    i am using a 2lt zetec with a freddy plate and a retroford flywheel with a 2lt mondeo clutch and using the rx8 hydraulic slave cylinder.
  26. #985
    Nov 2016
    Dorset
    72
    28
    Re: rx8 gearbox?
    Has anyone moved their handbrake back in the escort when fitting the Rx8 box.
    I'm about to finish my tunnel welding etc and I just wondered what you guys have done. It's pretty close to the Rx8 gear lever, so I don't want to get it all sorted and then discover I need to take it all apart again to move the handbrake back
    You can never have enough Ford toys
  27. #986
    Jan 2015
    Anglesey
    Re: rx8 gearbox?
    Hi cananyone please explain the 15mm hole in the plate to the left of the hole for the top starter bolt . In the ebay add for this plate there is a bolt in place. Can someone who has done this conversion tell me what they have done .
    I have four bolts in place and woul like one more like in the picture in the add.
    Any advice would be much appreciated.
  28. #987
    Jan 2015
    Anglesey
    Re: rx8 gearbox?
    I cut a section around the gear leaver hole and turned it around the same as you would for a T5 .
    The hand bake was fine were it was for me what engine are you running.
  29. #988
    May 2023
    Somerset
    Re: rx8 gearbox?
    Very old thread I know but did anyone manage to get the clutch to work ok using a cable from the rear with the mazda fork?
  30. #989
    Apr 2020
    East Sussex
    61
    Re: rx8 gearbox?
    Quote Originally Posted by TerryS View Post
    I'd be very interested in the answer to that.
  31. #990
    May 2023
    Somerset
    Re: rx8 gearbox?
    Well as far as my efforts went the clutch was far too heavy so I gave up and replicated the original Ford set up
Tags for this Thread
