Page 6 of 25 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 LastLast
Results 201 to 240 of 990
Thread: rx8 gearbox?
  1. #201
    Jan 2006
    Norfolk
    934
    Re: rx8 gearbox?
    Well, I have been following this thread with interest.
    I`ve been looking at the IS200 version of this box for a while, with a view to making a new front casting to give a type 9 interface
    But now, with the Rx8 sharing splines with a type 9, I have just brought an RX8 box to investigate.
    The IS200 box has a smaller, shorter tail section, and a remote lever arrangement, but the lever position is further back.
    output splines are different too
    More info later
  2. #202
    Jan 2006
    Norfolk
    934
    Re: rx8 gearbox?
    Quote Originally Posted by ugg10 View Post
    I have spent a bit of time google but not found anything so.....
    Can anyone who happens to have an RX8 6 speed or has already measured one, let me have the dimensions as follows -
    Engine mount face to bellhousing split
    Engine mount face to gearstick
    Engine mount face to other end (total length)
    Also has anyone got/can post on here a photo of the engine end without the bellhousing on as I can't seem to find any pictures of a gearbox in this state.
    Thanks in advance
    Do you still need these Ugg ?
    I`m looking at this box now for my Sigma motor
  3. #203
    Spanner Monkey ugg10's Avatar
    May 2014
    South Coast
    175
    30
    Re: rx8 gearbox?
    CR500Dom - I think I am OK at the moment, I think this may be a later update, I have come to the conclusion that having spent a load of £ on the Sigma/Type 9 bell housing I will just use the stock Type 9 for now and then if the 1st gear is so bad that I can't stand it I may go down this route. However, having looked at the ratios etc. for the Cosworth T5, this may be another, simpler options (may be a bit more expensive though) as I can probably still use the Sigma/type 9 bell housing with an adaptor plate.
  4. #204
    Re: rx8 gearbox?
    Hi mate I'm doing lots more engine plates kits now , and may do a sigma type plate to suit the rx8 box ,
    Will have large display of engines and boxes kits etc next month at stoneleigh kit car show .. And lots of other shows too throughout the year , classic car show at Santa pod , ford fair silverstone .. And have these kits now on ebay too .. P9cyo plates . Phil
  5. #205
    Jan 2006
    Norfolk
    934
    Re: rx8 gearbox?
    Quote Originally Posted by P9cyo View Post
    Cheers Phil, but I have a nice Big Lasercutter at work to profile it and a CNC Machining centre to put the holes in accurately afterwards.
    The Rest of the build is nice, so I want the adaptor plate to keep the same standards If you see what I mean ?
    Dom
  6. #206
    Re: rx8 gearbox?
    Quote Originally Posted by Sweetcorne View Post
    P9cyo
    Do you do the kit for a C20XE mate
    Hi yes mate we have them for the red tops give me a call , phil 07815007836
  7. #207
    Bodger mike77cos's Avatar
    Sep 2010
    Cornwall
    97
    10
    Re: rx8 gearbox?
    Interesting conversion, might have to keep aeye out for a RX8 box
  8. #208
    Jun 2008
    Dunfermline, Fife
    459
    61
    rx8 gearbox?
    Excellent converssion !!! Can you use a clutch cable set up with this converssion ? If so do you have any details or pics ? Cheers
  9. #209
    May 2007
    762
    Re: rx8 gearbox?
    It seems the 5 speed is more available in Belgium, are they any good ? Any info somebody ?
  10. #210
    May 2004
    lancashire
    80
    Re: rx8 gearbox?
    Have the drilling problems been addressed?
    Suffering from "escortosis"
  11. #211
    Sep 2004
    Poland
    Re: rx8 gearbox?
    Hi, do you do the kit for a Lancer Evo Engine ?
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    502
    Re: rx8 gearbox?
    So we've established that the box can be mated to a Ford engine and you need to do some work on the crossmember to bolt it up but nobody has said what you need to do to the tunnel to make it fit.
    I saw this at the pod today and it makes a type9 look like a chicken drumstick. I've got an auto tunnel in my car(mk1 escort)but I can't even see it fitting in there.
    Has anybody actually got one in a working car to see if it physically fits?
  13. #213
    Re: rx8 gearbox?
    Quote Originally Posted by BRIGSPORT View Post
    Hi there
    Hole issues only happen now and again were template has worn and we always on the end of the phone to help .. And replacement will always be there at no cost .. But now due heavy demand for these kits we are now looking into
    Having them cnc cut so they will be right every time and we can keep up with demand ...
    P9cyo ��
  14. #214
    Re: rx8 gearbox?
    We could do the kit for that but we wouldn't have engine in stock
    But if you sent your engine flywheel clutch box etc on a pallet we can do this and send it back no problem ..
    Most engines we have on stock so can work with them . But the more expensive ones customer need to supply ..
    Please ring me to discuss more 07815007836.
    We will shortly have a new website with shop and drop down menus .. With pics and possibly videos ... P9cyo ��
  15. #215
    Re: rx8 gearbox?
    Size of gearbox
    The rx8 and type9 face to face bellhousings are the same size in diameter ... The length is more or less the same and the stick is in the same place as the type9 ... So if you have type9 in the rx8 goes in .. But the gearbox mount is 8 inches further back ..
    So the rx8 doesn't fit in a standard tunnel as the type9 doesnt ..you have to modify the mounts and holes as you would with the type9
    New kits avilible with clutch arm same as type9 ... So you can run normal cable clutch .. Please ask .
  16. #216
    Mechanic Bigfish's Avatar
    Dec 2009
    Beds
    891
    Re: rx8 gearbox?
    Size of gearbox
    saw this at the pod and as like a lot of use would like to do this in the future, have you got any pics of it fitted in a mk1 I want to see how much room there is for the clutch cylinder
    thanks
    1974 MK1 Escort - Work in Progress
  17. #217
    Re: rx8 gearbox?
    Quote Originally Posted by Bigfish View Post
    thanks
    high will do my best to pull a mk1 out next week and get a engine and box sat in for all to see .. With some pics and measurements if possible ..please bear with me as the only mk1 I hhave in is
    buried and will have to move about 15 motors to get it out ... P9cyo
  18. The Following User Says Thank You to P9cyo For This Useful Post:
  19. #218
    May 2015
    Macclesfield
    10
    Re: rx8 gearbox?
    I'm looking at fitting an RX8 box to a 2.8 Cologne engine using one of Phi's adaptor plates It's a standard carb engine with around 140bhp. I'm converting the car from a C3 auto-box and was originally looking for a V6 T9 from a Capri until I came across this thread for an RX8 box.
    I've run the ratios for both the 5 speed and 6 speed boxes through a spreadsheet and have come to the conclusion that the five speed box will be a better set of cogs in this application. Especially as 6th is a lower ratio than 5th on the five speed box (which surprised me).
    Can anyone confirm if the two boxes have the same bellhousings, input shafts and fittings. From studying photos I would say yes, but it would be good to have it confirmed.
    _____5 Speed ___6 Speed
    1st ---3.483 ----- 3.760
    2nd ---2.015 ----- 2.269
    3rd ---1.484 ----- 1.645
    4th ---1.000 ----- 1.187
    5th ---0.762 ----- 1.000
    6th –--- ---- ----- 0.843
    Reverse __3.288 ------ 3.564
  20. #219
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Quote Originally Posted by scimitarcars View Post
    If i was you i would run the 6 speed the 5 speed doesn't look anywhere near as robust to take big torque and the diff ratio on a v6 is already 3.09 at a guess with a final drive orlf around 0.83 type 9 5th gear that is about a top speed of 180mph why would you want to make 5th/6th any longer that it already is.
  21. #220
    Lightbulb Re: rx8 gearbox?
    Just a bit of info that I have from a very good sorce and from someone who's racing rx8 with 600bhp ,
    is that he kept blowing the 5 speed boxes and changed to the 6speed which is a lot stronger and bigger to to it .. And has not had problems since ..
    So so you need to use the 6speed if you want to run big power and torque ..
    He also said that he runs 5-30 mineral oil in the box as this works better on the track .. When box is hot .. As this will better at hotter temps ...
    Also so few people asking over the prop although your type9 is 1" 23 spline and fits into the box diameter is a problem as you will get weave and will do the box in .. So you have to run the rx8 input for this to run correct without issues .. P9cyo.
  22. #221
    Re: rx8 gearbox?
    P
    We also now have duratec kit in . But gearbox will require mods . Or we can supply box mod done ..
  23. #222
    May 2015
    Macclesfield
    10
    Re: rx8 gearbox?
    You make a fair point, but this is for a Scimitar GTC. The final drive is 3.54. Originally Reliant specified 3.31 for the Essex engines, but when they replaced them with the Cologne for the later cars, the ratio was changed to take account of the lower torque figure. The tyre circumference is 1985mm which gives a theoretical speed in RX8 5th of 82mph at 3000rpm, which is exactly where it will feel comfortable. With the Auto it's currently doing around 70mph at approx 3100 rpm (not nice). The car only has 140BHP, so it won't be breaking any 0-60 records or being thrashed to within an inch of its life, I have a DET turbo sprint car for that .
    The manual cars had a 4 speed box with overdrive available on 3rd and 4th. Anyone who has driven one will agree that the ratios are perfect for the car.
    These are :-
    1 - 3.160
    2 - 1.942
    3 - 1.412
    3 O/D - 1.098
    4 - 1.000
    4 O/D - 0.778
    R - 3.35
    Which are pretty dammed close to the RX8 5 speed. To make the six speed work better, I could go to a 3.07 CWP as found in the SE5A, but I'm sure the 5 speeder with what I have will be more in keeping with the character of the car.
  24. #223
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    These are :-
    1 - 3.160
    2 - 1.942
    3 - 1.412
    3 O/D - 1.098
    4 - 1.000
    4 O/D - 0.778
    R - 3.35
    All your saying makes sense to me now i thought you were running a capri with the 3.09 diff, sorry. The .7 5th with a 3.54 will be fine then.
  25. #224
    Re: rx8 gearbox?
    just caught up with all this, did you ever get the dimensions of the cosy fly wheel. I have one i can measure if you need. Also looking at the slave cylinder may cause space issues what about a central hydraulic clutch. If suitable behind a mild cosworth YB i would be quids in opposed to the ever more expensive T5 have 6 gears and the prop should be able to be made to work if it is shorter by 20mm.
    Just what clutch plate to use
  26. #225
    Re: rx8 gearbox?
    Hi boys ..
    Lots gs of people saying slave is a problem on the road cars not so much track ones with large tunnel etc .. We now can modify boxes to run the cable set up like standard cossie .. But you will not be able to run the centre hydraulic like in the t5 box .. As the rx8 is totally different and has a big bolt in web that hold the gears in .. But we can also realocate the rx8 arm and have it hydraulic on the outer ... Will get some pics up some time next week .. As very bizzy keeping up with all my orders for kits .. P9cyo, any questions. Give us a bell .. Here to help ..
  27. #226
    9,211
    Re: rx8 gearbox?
    what does that mean ? i dont understand what your saying ?
  28. #227
    May 2007
    762
    Re: rx8 gearbox?
    The rx8 propshaft is almost the same length as the RS2000 single piece prop, I think people just change the bottom flange to mate to their atlas axle.
    Anyone knows if the rear UJ of both have the same sizes ?
  29. #228
    Re: rx8 gearbox?
    Yes you can run the rx8 prop on the escorts as length it ok . You have to redrilled you diff flange to suit ..
    And the weave I mean .is just like putting a smaller bolt in a hole it will winggle around .. Well it's the same kind of thing with the rx8 box .. Wear you 23spline type9 prop will fit into the box on the splines you can put smaller oil seal in but it will cause a problem .. Wear as the rx8 is the right one right diameter and so fits correct with no issues .. Hope this sets it out better for everyone ..p9cyo .
  30. #229
    Mar 2009
    sussex
    447
    Re: rx8 gearbox?
    So what your saying is don't use the seal I got with my gear box conversion plate
    Instead look for a rx8 prop
  31. #230
    Re: rx8 gearbox?
    [QUOTEJust what clutch plate to use[/QUOTE]
    research I have done says it is a 1" 23 spline so i assume this is the same and should fit straight into a coworth clutch.
  32. #231
    May 2007
    762
    Re: rx8 gearbox?
    Clutch plate can be the 2.0 pinto or 2.0 cosworth, no problem
    I like to know how if the rear flange of the original rx8 prop can be changed (I don't like the idea of redrilling it)
    The rx8 prop is a lightweight CARBON part, so like to use this !
  33. #232
    rx8 gearbox?
    Clutch plate can be the 2.0 pinto or 2.0 cosworth, no problem.
    That's what I thought👍. I like the idea of the prop.
    Well I'm in
  34. #233
    Re: rx8 gearbox?
    just for info i have just tried cosworth yb flywheel in the bell housing and it drops in easily. just need to verify the starter position compared to an rs2000 bell housing (i have both in stock) i suspect it is different so may require a slightly different pattern to the pinto plate.
  35. The Following 2 Users Say Thank You to wildo105e For This Useful Post:
  36. #234
    Bodger bazza77's Avatar
    Feb 2011
    lancs
    64
    Re: rx8 gearbox?
    just have a prop made using the rx8 front piece job done
    ill stick some pics up when i take some tomorrow of mine fitted to zetec st170 (mine is fitted level not on a slant)
  37. #235
    May 2007
    762
    Re: rx8 gearbox?
    Where did you have it done bazza ?
  38. #236
    Feb 2011
    lancs
    64
    Re: rx8 gearbox?
    the prop? my local propshaft company
    i made the conversion plate etc
  39. #237
    Feb 2011
    lancs
    64
    Re: rx8 gearbox?
    this is mounted so the gearstick comes through the tunnel straight and the slave cylinder bolts in its original position
  40. #238
    rx8 gearbox?
    Bit more to my puzzle
  41. #239
    Re: rx8 gearbox?
    Hi bazza77,
    I assume that is a zetec ? how did the input shaft measure up ? I am measuring up a cosy T5 and the RX8 and they seem to be about the same length which makes a spacer a plate a little bit awkward. I have a t9 on an rs 2000 bell housing so going to measure that swell to see how that looks just a pain throwing gearboxes around the garage
    P9cyo sent you a pm regarding making a plate for a YB i have all the parts for measuring etc
  42. #240
    Jun 2003
    Teesside
    2,406
    Re: rx8 gearbox?
    Got a CAD drawing started for the ford to RX8. Need to check its right for an upright gearbox position. starter bolt holes need a little correction too
Tags for this Thread
