Page 5 of 25 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 ... LastLast
Results 161 to 200 of 990
Thread: rx8 gearbox?
  1. #161
    Pole Position Decade Plus User freddy686868's Avatar
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Quote Originally Posted by P9cyo View Post
    Yes but this is why I say re drill and everything is as is ,, but type9 prop fits and my kit contains new real oil seal for mazda box to use type9 prop ,,
    Only if you want to use mazda prop will you need to re drill flange .. P9cyo
    With your conversion plate is the standard ford pattern used for the mounting of a ford starter motor in the same place as the steel ford bellhousing ?on the passenger side that is.
  2. #162
    Re: rx8 gearbox?
    Yes mate it's all same as type9 so basically a straight swop ... The only thing that's different is your gearbox mounting and its electronic speedo ...
    I know this is very hard to beleave but I've sold lots of these now and it's a bolt on conversion with lots of positive comments how good this is against type9 , and so cheap .. P9cyo
  3. #163
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    i'll be checking my bank account later and if it looks healthy i will give you a shout. Thanks, John
  4. #164
    Racer Decade Plus User robrs2's Avatar
    Jun 2003
    Teesside
    2,406
    Re: rx8 gearbox?
    Any build threads with anyone fitting the rx8 box
  5. #165
    Re: rx8 gearbox?
    Have pics of a v6 24v cosworth with rx8 on it .. In earlier part of thread ..
    Will try and get some up with zetec all bolt up later this week. .. For all try and do video too if wifes got time ,, lol
    P9cyo
  6. #166
    Jul 2006
    airdrie
    1,549
    Re: rx8 gearbox?
    hi phil, have you had a chance to post the adapter yet m8
    cheers davy
  7. #167
    Re: rx8 gearbox?
    Quote Originally Posted by d8vyr View Post
    cheers davy
    Yes mate went out today ,, sorry about delay wife got stamp on by a few horses at weekend .. So had hours and days at a+e hospital ... P9cyo
  8. #168
    Jul 2006
    airdrie
    1,549
    Re: rx8 gearbox?
    cheers phil, don`t fancy getting stood on by a money pit, specially my mr`s cobs, cos they are fat fekrs with big feet
  9. #169
    May 2004
    lancashire
    80
    Re: rx8 gearbox?
    What about the 5 speed, as this is what i have in my dead rx8 192, and want to zetec turbo it.
    Suffering from "escortosis"
  10. #170
    Re: rx8 gearbox?
    Quote Originally Posted by BRIGSPORT View Post
    Yes mate I'm sure the main shafts are the same as ,ie 2.0 / 1" 23 spline .. I've put a 24v v6 cosworth in a rx8 .. Just makes them a proper toy and you now it's going to start , but if you was doing the conversion at £50 I'd bang a 6spd in it well doing it .. If your on the rx8 forum could you put a thread on there to with my details please , p9cyo,
  11. #171
    May 2004
    lancashire
    80
    Re: rx8 gearbox?
    Not on rx8 forum, im a ford man at heart.
    Eventually the floorpan will be going under mk2 escort x pack shell.
  12. #172
    Racer Decade Plus User Adam B's Avatar
    Feb 2007
    Hillingdon
    39
    2,107
    21
    Re: rx8 gearbox?
    So with the zetec, what clutch is needed? What release bearing? Does any of the above need spacing to match the gearbox spacer?
    My Project... Fiesta D-TEC
  13. #173
    Re: rx8 gearbox?
    Quote Originally Posted by Adam B View Post
    You need a 2.0 clutch which used with type9 , 1" / 23 spline .. Rx8 bearing no space as slave cylinder ajuster comes with kit , it takes out free travel on bar ... P9cyo
  14. #174
    May 2004
    lancashire
    80
    Re: rx8 gearbox?
    Bought a 6 speeder off my mate for £80, had to pay a bit more as i will be getting him to help with conversion.
    Is the rx8 prop the same between 5 & 6 speeds?
    Also got an rx7 lsd to go in the mix.
  15. #175
    Re: rx8 gearbox?
    Not sure on 5 -6 but would say there same ,I only use the 6spd kit ..some rx7 diffs are changeable all rx8 231bhp 6 spd came with lsd ...p9cyo,
  16. #176
    9,210
    Re: rx8 gearbox?
    i have been told there are 2 types of 6sp box
    before and after 2004 --------- anyone know the differences and if it matters to us ?
  17. #177
    Re: rx8 gearbox?
    Quote Originally Posted by alladdin View Post
    Hi mate I have 6 gearboxes here and there all the same , but never asked what years they were out of , best way to check before you buy is take your 2.0 clutch , 23 spline .. Or count the splines if your buying on line ... But I'd say there all the same .. I think in all mine i have before and after 2004 ...
  18. The Following User Says Thank You to P9cyo For This Useful Post:
  19. #178
    Feb 2015
    Fevik, Norway
    10
    Re: rx8 gearbox?
    Really good info to find, this
    All gearboxes here in Norway seems worn out if any has one for sale.
    And with my planned 250hp 2.9 12v in my Capri, the T9 won't last long at all...
  20. #179
    Re: rx8 gearbox?
    Quote Originally Posted by Norwegian Caprinut View Post
    hi mate can do you a gearbox and conversion plate kit ,, but the problem will the shipping cost .. You may be able to book it cheaper from your side if you want to try get price .. P9cyo 07815007836,
  21. #180
    Feb 2015
    Fevik, Norway
    10
    Re: rx8 gearbox?
    Any idea of cost if you post it?
    Postal service is in most cases cheaper than currier prices for me....
    Btw: RX8 gearboxes has silly prices here in Norway and are rare, hence price of 750 quid or more..
  22. #181
    Re: rx8 gearbox?
    Phil mate I can get a price for you but it would have to be small pallet as to heavy for post will try get for both have you a name address postcode etc please , big difference when there £100 here .. Will do my best for you p9cyo ,
  23. #182
    Feb 2015
    Fevik, Norway
    10
    Re: rx8 gearbox?
    I'm not allowed yet to send a PM (need minimum of 10 posts), will send one asap when I get past 10 posts
  24. #183
    Re: rx8 gearbox?
    Txt me if better mate phil 07815007836.
  25. #184
    Re: rx8 gearbox?
    more pics for all of full fitment of my plate kit ,Click image for larger version Name:	IMG_0142.JPG Views:	523 Size:	112.1 KB ID:	73831[ATTACH=CONFIG]73832[/ATTACH
    plate all bolted to engine .Click image for larger version Name:	IMG_0144.JPG Views:	515 Size:	97.4 KB ID:	73833
    starter bolted to plate no fit gearbox .Click image for larger version Name:	IMG_0147.JPG Views:	522 Size:	107.6 KB ID:	73835Click image for larger version Name:	IMG_0149.JPG Views:	521 Size:	107.6 KB ID:	73836Click image for larger version Name:	IMG_0151.JPG Views:	517 Size:	48.8 KB ID:	73837
    gearbox all bolted in place ..Click image for larger version Name:	IMG_0153.JPG Views:	521 Size:	95.9 KB ID:	73839
    fitting of slave cylinder ajuster ..Click image for larger version Name:	IMG_0157.JPG Views:	517 Size:	105.2 KB ID:	73841Click image for larger version Name:	IMG_0160.JPG Views:	520 Size:	109.3 KB ID:	73842
    gearbox conversion all done ... hope this helps people out ...any questions or orders for kits ..phil 07815007836..
    Attached Thumbnails Attached Thumbnails IMG_0143.JPG‎
  26. #185
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    I think now would be the time to become a member on the site or even a site sponsor. It not only helps keep the forum going but also shows you are happy to support as well as sell on here.
  27. #186
    Re: rx8 gearbox?
    Quote Originally Posted by freddy686868 View Post
    was thinking that myself matey,, possibly just sponsor i think ,
  28. #187
    Feb 2015
    Fevik, Norway
    10
    Re: rx8 gearbox?
    Awesome pictures
    Any idea of clutch master cylinder size needed?
    I may go for pedal box later on in my Mk3 Capri, as my mate..
    Oh, amd do Pinto and Ford V6 Cologne share the same bolt pattern?
  29. #188
    Re: rx8 gearbox?
    Slave cylinder is just the rx8 one standard ,
    And for the plate conversion kit the v6 is totally different to vauxhall redtop and the zetec / pinto / x flow one ,,
    Hope this all helps ,, cable ajuster for clutch is also avilible too . P9cyo
  30. #189
    Feb 2015
    Fevik, Norway
    10
    Re: rx8 gearbox?
    That means you can use your stock clutch cable or?
  31. #190
    Racer Decade Plus User evans2822's Avatar
    May 2009
    Maesteg South Wales
    2,041
    142
    Re: rx8 gearbox?
    I think you would have to convert to hydraulic clutch to run that box In an escort Shame the clutch arm Is In that position Is It possible to move the clutch arm to the right hand side like on a type 9 (cut hole In b/h?) I cant see how you could get a clutch cable to that position unless you know of a longer cable to get around to there?
  32. #191
    Re: rx8 gearbox?
    Quote Originally Posted by evans2822 View Post
    hi there my cable mount is a rear side mount to use the clutch arm were is ,
    you just need to get longer cable to go under tunnel and loop back it's the only way to do it that keeps it simple , like my plates just enough and not over engineered . And it all works just bolts on .. Should have pics up tommorrow of v6 cossie with cable clutch mount ,, bolts on bolts already around the gearbox.. ... P9cyo
  33. #192
    Re: rx8 gearbox?
    You change the cable to a longer one .. If you want cable or go hydrolic ..wet clutch ..p9cyo
  34. #193
    Re: rx8 gearbox?
    A wet clutch isn't a hydraulic operated clutch mate, a wet clutch is a clutch submersed in oil....like a motorbike....except Ducatis that have dry clutches.
  35. #194
    Re: rx8 gearbox?
    Lol thought as I posted it ..
  36. #195
    Jun 2003
    Teesside
    2,406
    Re: rx8 gearbox?
    Thanks for the pics. Makes it a bit more clear
  37. #196
    Re: rx8 gearbox?
    Hi mate based on postage to Oslo best I can get it for is £175 postage fore the gearbox and conversion plate . .. If this helps ..p9cyo.
  38. #197
    Mechanic mk2-mad-ad's Avatar
    Nov 2008
    stoke
    644
    25
    Re: rx8 gearbox?
    Looking in to doing this hopefully going to pic a gearbox Up this weekend , has anyone on hear done this conversion yet and how have you found it , how much further back will the gearstick sit in comparison to a type 9 and do these boxes have quite a short shift or not , I'm guessing there a lot nicer and smoother than a type 9 and how have people found the gearing , could anyone post me a link up so I can work out the gearing with my tyre / diff combo . 175 50 13 with a English 3.54 diff as it it with what ever gearing is in my box it's got a good long first so how do they compare .
    Where abouts in Cheshire are you bud
  39. #198
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Quote Originally Posted by mk2-mad-ad View Post
    The 6 speeder had everything. The original annoying low first gear. The 2nd gear to 5th gear is very simular to the tran x gear kit and the 6th gear is the same as the original ford type 9 5th gear.
    Here's all the working out on my thread
    http://www.turbosport.co.uk/showthre...=276802&page=8
  40. #199
    Re: rx8 gearbox?
    Hi mate I'm in winsford so not far away from you .. Your stick is more or less in the same place .. But your mount is not . If you look back in the thread I have put pics up of them side by side stood up etc etc ,, the main gain with this 6spd box is mainly the reliability and strength then the price , gearing quickshift nice smooth gearbox , and that is all the same clutch and prop so no expense there hydrolic clutch but I can do you a cable set up .. So the main things you need to sort is gearbox mount , and electronic speedo .. Other than that it's tons better than the weak crap type9 box .. But you could use
    to prop the garage door open .. P9cyo 07815007836 .. Plate kits for all types of engines .
  41. #200
    Feb 2015
    Lancashire
    39
    11
    Re: rx8 gearbox?
    Looking forward to getting my kit and test fitting it to my spare car :-D
Tags for this Thread
