Re: blue Rs
going a bit old school with this engine, the rods are yb cosworth, they have been checked for alignment and resized,
its been a while since i had the scales out, all the recent engines i have done either used totally standard rods or steel rods no balancing required in either case, these i balanced, they werent bad, but werent the best either i have had sets of yb rods so close weight wise i didnt have t touch them
no surprise but when i did a dummy piston fit the pistons stuck out the bore just over 0.050" which is about what you would expect as yb rods are round 0.060" longer than pinto, and i had refaced the block, what i was pleased about is the protrusion on all the pistons was very similar. i dont usually skim blocks or even heads for that matter as although you can on my milling machine its a bit of a pain to do and easy end up with it pissed and one end of the block taller/thicker than the other.
i normally machine pistons in the lathe, but today i did it in the Bridgeport on a jig i made for holding pistons to do valve cutouts, its a bit of a faff to get it set up to do the first piston, but once set up the other 3 are nice and quick
The Following 2 Users Say Thank You to Graham For This Useful Post:
Re: blue Rs
Been throwing a bit of paint around
Re: blue Rs
Engine is back from Graham this is the fuel pump for the 44 ifs no fuel presure regulator required complete fitting kit arrived next day from webcon £76.68
Re: blue Rs
Sorry there has been no updates had my van stolen with all my tools at the start of september so everything escort is on hold at the moment
Re: blue Rs
Sorry Bru, thought crime was just hard in SA.
The Following User Says Thank You to Shauns For This Useful Post:
The Following User Says Thank You to Andy Corne For This Useful Post:
The Following User Says Thank You to jbr39 For This Useful Post:
Re: blue Rs
Radiator upgrade with offset water galleries for better cooling will paint the radiator top before it's fitted
Re: blue Rs
some nice parts collecting going on there.
The Following User Says Thank You to wildo105e For This Useful Post:
